Old 02-19-2014, 09:03 AM   #3501
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Im battling to establish the correct plug to go 1+ colder.
OEM Denso plug is equivalent to 9 NGK heat
Im told to use NGK R2558A-10
anyone changed there plugs to 1+ colder, what heat you went for and which plug.
Many Thanks
Ryan86 is offline   Reply With Quote
Old 02-19-2014, 09:18 AM   #3502
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
If there's any possibility of maximizing gains with a perrin CAI, that would be awesome as I want to keep it for the enhanced whine. While heel/toe downshifting, blipping the throttle had always been laggy with the perrin intake, both while I was NA and now that I'm boosted. Not sure if anything can be done about that but if there is I'd like to see some improvement with that intake.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
xjohnx (02-19-2014)
Old 02-19-2014, 09:59 AM   #3503
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
So the 355 and 210 model numbers may be the torque output instead of a random model number?
Liters per second. Its a measure of how much air the supercharger is capable of moving.
Sellout is offline   Reply With Quote
Old 02-19-2014, 11:07 AM   #3504
Bonks86
Drives: Gt-86
Originally Posted by evan View Post
Interesting. I just switched to the Airaid setup, but am awaiting a retune and dyno. Let us know your thoughts on whether the stock snorkel hinders performance or not. Airaid is convinced that removing it will net more power.
pic of the setup?
Bonks86 is offline   Reply With Quote
Old 02-19-2014, 11:34 AM   #3505
xxscaxx
Drives: 2013 SWP BRZ
I almost bought a used Airaid intake to swap out the box, but wasn't sure it was worth it. Curious to see if it yields any more power (and possibly increase that whine? )
xxscaxx is offline   Reply With Quote
Old 02-19-2014, 11:43 AM   #3506
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Given that the airraid intakes were showing a loss in power NA I'd probably avoid them for the innovate setup
Nolan
pheoxs is offline   Reply With Quote
Old 02-19-2014, 11:56 AM   #3507
evan
Drives: fr-s
I don't quite believe in the loss of power result. I think it's all in the tune. It's just a box and cone filter. A well designed one at that. I see and hear so much loss of power bullshit without substantiating the actual cause. It just takes one person or test to ruin something. I know the magazine test you are probably referring to where they tested a bunch of intakes. Besides, there are SO many factors in chassis dynameter testing that errors are bound to exist in the result.
evan is offline   Reply With Quote
The Following User Says Thank You to evan For This Useful Post:
ntaphse (02-20-2014)
Old 02-19-2014, 11:56 AM   #3508
evan
Drives: fr-s
Originally Posted by Bonks86 View Post
pic of the setup?
I'll post one later.
Old 02-19-2014, 12:00 PM   #3509
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Not to mention Bill had already experienced an additional 10whp when he put the airaid box on his car before it got the innovate blower. All in the tune
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
evan (02-19-2014)
Old 02-19-2014, 12:00 PM   #3510
xxscaxx
This may be true but NA and FI are two different entities. But I will say it is a reason I didn't take a risk and get it.
Old 02-19-2014, 12:04 PM   #3511
evan
Drives: fr-s
Also.. In MY case I'm not using half the Airaid setup since the intake path is now different. The elbow that ships with the kit is still sitting in the box. I have an aluminum pipe going from the supercharger/throttle body to the Airaid box. This alone changes everything. Any test out there is now invalid in my case.
Old 02-19-2014, 12:07 PM   #3512
pheoxs
That makes sense, and yeah you are correct I am probably referencing the same article as most people. I would love to see one tuned and see how it does.
Nolan
The Following User Says Thank You to pheoxs For This Useful Post:
evan (02-19-2014)
Old 02-19-2014, 02:31 PM   #3513
xjohnx
Grip>Slip
xjohnx's Avatar
So i'm pulling my blower tonight to make sure the rubber strip seals on top of the IC are still in place properly. For those of you that have removed the blower post IC install ( @Ryan86 maybe?), what's the least messy way of disconnecting the coolant lines that feed the intercooler?
Old 02-19-2014, 02:46 PM   #3514
swift996
swift996's Avatar
Why remove the lines? You can take the blower off without doing that.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
