Old 02-13-2014, 08:19 PM   #3389
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by CK_Bladesmith View Post
What causes the coil packs to go out?
Since this hasn't been an issue with any other FI kit, the elephant in the room is that the intercooler water pump is the cause. I'd love to see a wiring diagram, but most cars power their injectors and coils off the same supply, and just switch the grounds individually.
Old 02-13-2014, 08:26 PM   #3390
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
My #1 coil went out and I have a non-intercooled kit.
Sent from my DROID RAZR using Tapatalk
Area86 is offline   Reply With Quote
The Following User Says Thank You to Area86 For This Useful Post:
Calum (02-13-2014)
Old 02-13-2014, 08:35 PM   #3391
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by xxscaxx View Post
For clarification, I think Bill is the only one currently who has utilized the stock injectors with a 70mm pulley with/without the intercooler combo on e85. I haven't seen anyone else do this.
We can do this no problem for people who prefer to stick to OEM injectors.
Xero-Limit is offline   Reply With Quote
Old 02-13-2014, 09:13 PM   #3392
Powersfrs
Drives: Frs
Can all the coil packs be change easily?
Powersfrs is offline   Reply With Quote
Old 02-13-2014, 09:38 PM   #3393
Calum
That Guy
If you feel that lifting the engine is easy, yes.
Old 02-13-2014, 09:39 PM   #3394
jamesm
You definitely don't have to lift the engine to get the coil packs out.
Old 02-13-2014, 10:02 PM   #3395
Powersfrs
Drives: Frs
So can I as the noob I am change coil 3,4 as well although I've only heard of the first one ,cylinder one going bad? Does anyone know y they're going bad?
Old 02-14-2014, 02:38 AM   #3396
APS86
Drives: GTS86 Manual
Hi all,
I have had the sprintex kit on for about a month now and continue to love it - at the moment still have stock headers, overpipe and front pipe. I have the TRD quad tip hi flow muffler.
I am interested in yiour advice re headers, over pipe and front pipe - I want to keep the noise down as it remians my daily driver. My tuner recommends going as big as possible but I am a bit committed because of the quad tips and TRD body kit which I really like ..... also concerned about noise!
APS86 is offline   Reply With Quote
The Following User Says Thank You to APS86 For This Useful Post:
Hallucin8 (02-16-2014)
Old 02-14-2014, 03:20 AM   #3397
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by APS86 View Post
Hi all,
Headers, especially catless headers will make it much louder. If you add a overpipe, front pipe with hi flow cat then it will be even louder. I have a lot of sound dampening in my car with catless JDL UEL headers with Nameless overpipe with hi flow cat and helmholtz resonator and it's just on the edge of bareable for daily driving. When I go up a hill it's too loud. Everyone says it's super loud when I'm on the gas that's behind me. I'd say get a catted header if you want the noise to be less, but it will be louder the more exhaust stuff you do. If you just want sound just stick with the axle back. If you want more power spend your money on a supercharger or turbo as the exhaust won't get you much for your money as far as horsepower. Do exhaust after forced induction if you're on a quest for more power. Listen to other locals to get an idea of what you'd be getting yourself into with exhaust mods if possible.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
APS86 (02-14-2014)
Old 02-14-2014, 03:23 AM   #3398
stockysnail
Just the tip
I'm going with the 70mm pulley and intercooler. Would all of you recommend the blue gates performance blue belt? Would anyone say I should not get it or not need it? I've read mixed thoughts on a slightly shorter belt that the blue gates would provide. Some said it's great and some didn't seem to need it. It's kind of expensive so if I don't need it why get it, but if it will prevent issues better than the stock Innovate belt then I should get it.
Old 02-14-2014, 03:41 AM   #3399
APS86
Thanks for that ..... some of the changes you have done to your car I have been thinking of so really good advice. I am happy with my power increase after the supecharger/intercooler install but once you do it you always want more power!!!!!
Old 02-14-2014, 01:06 PM   #3400
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Car will throw code for each coil pack if they were faulty.
If you lifting the engine take the chance to change plugs, if you can.
Ryan86 is offline   Reply With Quote
Old 02-14-2014, 01:07 PM   #3401
Ryan86
Road Warrior
Ryan86's Avatar
What I would suggest is cut the cats out of your OEM header, open the flow up.
Old 02-14-2014, 01:08 PM   #3402
Ryan86
Road Warrior
Ryan86's Avatar
After long search finally found the correct oil for the SC,
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
