Old 02-08-2014, 06:16 PM   #3291
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Two questions, 1 technical (maybe?) and 1 opinion.
Technical
Are the bolts that hold the pulley on the same M6 X 20 that hold the blower to the manifold?
Opinon
I want to run a smaller pulley and am undecided between the 70mm and 72.5mm. I've been leaning more towards the 72.5mm so I won't be running the supercharger at its maximum at all times. But I know with running the 70mm you get a decent bump in power. Those running either or have run both, suggestions?
Dustin is offline   Reply With Quote
Old 02-08-2014, 09:28 PM   #3292
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Technical
Opinon
What you are referring to is not the maximum. It is the continuous rating of the blower. Yes. You will go past the continuous rating with the 70 but only by a little. And that is at redline. How often are you going to be at redline? The blower should be able To operate at that continuous rating rpm for forever. If you daily your car it will be perfectly fine. If you track it. Maybe get the 72 but it shouldn't be a problem either way. There is only a couple hundred rpm difference.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
Dustin (02-08-2014)
Old 02-08-2014, 09:39 PM   #3293
choi0706
Drives: t
at what rpm is the continuous rating?
choi0706 is offline   Reply With Quote
Old 02-08-2014, 10:33 PM   #3294
evan
Drives: fr-s
Don't rail on me if I'm wrong, but I believe it is 15k rpm.
evan is offline   Reply With Quote
Old 02-08-2014, 10:35 PM   #3295
Dustin
Twin Screw You
Dustin's Avatar
Thank you for wording it better. That's what I was referring to, but the way you said it is more accurate. Thanks for your input.
The Following User Says Thank You to Dustin For This Useful Post:
calispec (02-09-2014)
Old 02-08-2014, 10:59 PM   #3296
choi0706
Drives: t
and what rpm is that on the motor? with a 70mm pulley
Old 02-09-2014, 02:43 AM   #3297
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by Ryan86 View Post
The small silver screw at the back of the charger is where you can hook up boost pipe. I fitted a ProSport mechanical gauge as Delicoius Tuning use the Stock MAP sensor and can't read boost off the ECU.
Here is a pic.
We had to taper the hole bigger to get the fitting we have locally in.
Is there a DIY somewhere for installing a boost gauge? I see you put it there but what fittings, hose, and other stuff did you use? Where did you wire the electrical for the boost gauge? Sorry if I'm a newbie with boost gauges.
stockysnail is offline   Reply With Quote
Old 02-09-2014, 09:37 AM   #3298
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Here is a DIY for the boost gauge option I went with.
http://www.ft86club.com/forums/showthread.php?t=36643
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
stockysnail (02-09-2014)
Old 02-09-2014, 11:50 AM   #3299
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Originally Posted by ntaphse View Post
I used to live down in Tempe, wish we had an E85 supply up here.
This is where I get my E85:
22111 North Scottsdale Rd, Scottsdale
It's just a few miles north of the 101 on Scottsdale Rd.
alexand3r is offline   Reply With Quote
Old 02-09-2014, 03:21 PM   #3300
calispec
calispec's Avatar
I did a little math and it looks like the blower is getting pushed past the 15000 continious rating by about 550 rpm at the 7500 rpm shift point with the 70mm pulley.
www.GT86Mounts.com
The Following 2 Users Say Thank You to calispec For This Useful Post:
Dustin (02-09-2014), swift996 (02-09-2014)
Old 02-09-2014, 08:57 PM   #3301
choi0706
Drives: t
so lowering the redline to to what rpm makes it even at 15000?
Old 02-09-2014, 09:49 PM   #3302
calispec
calispec's Avatar
7234. If my numbers are right. I'll have to go back and make sure but it sounds right.
www.GT86Mounts.com
Old 02-09-2014, 10:05 PM   #3303
swift996
swift996's Avatar
That sounds about right. You could either set a rev limited via EcuTek, I tend to shift around 7k-7.1k anyways though.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-09-2014, 10:28 PM   #3304
Dustin
Twin Screw You
Dustin's Avatar
I'll probably do the same. Have my shift light come on at 7k and shift shortly after that. Went ahead and ordered the 70mm pulley today. If we're only talking about the last couple hundred rpms in the rev range, I'm not gonna worry about it. @swift996 you went with the 72.5mm correct? How are you liking it?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
