#3123 |
Drives: Frs
Sorry I'm a noob at this!!!...so will I feel the torque if I'm driving normal n shifting around 3300~ Or will I only feel it when I'm at wot
#3124 |
Drives: Subaru BRZ with Delicious Innovate
You will only get more power over stock when the recirculating valve closes.. This is only dependent on throttle position. NOT RPM.. I don't know what % of throttle will start to close the bypass valve and boost will be generated (maybe around 1/4 to 1/5). You CAN build boost at idle. but you don't have to.. that is the point i am trying to make..
| The Following User Says Thank You to calispec For This Useful Post: | Powersfrs (02-02-2014) |
#3125 | |
Drives: Raven FR-S
This explains exactly why I feel what I would call a "hesitation" around 3k under 1/4 and increasing throttle input. It has to be the bypass valve closing and going into boost. I know it's not the tune....delicious tuning is excellent.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3126 |
I am tuned by delicious as well. I don't have much of a hesitation at all. But it might have something to do with it. Make sure you have the most recent tune by him. The intercooler may help because it displaces some of the volume that would need to be compressed.
#3127 |
Drives: 2016 Subaru WRX
^^ I had this issue for the longest time. Revised ROM from Toni at FA20club took care of it now. Car down low drives like it did stock.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#3128 | |
Drives: fr-s
Sent from my Nexus 5 using Tapatalk |
#3129 |
I bought a flowmaster cat-back and will install and hit the dyno (hopefully before the weekend).
For those interested in the boost plot, this is on e85 with the 72.5mm pulley (intercooled)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3130 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
72.5mm gave me 10.8psi on 91oct. So the kits are performing pretty much on par
#3131 | |
NW Region Moderator
Drives: FR-S No More
#3132 |
Again! WARNING on those supplied bolts. Opened my hood to check my coolant level and two of the bolts broke. The tops just came right off. They were properly torqued.
| The Following User Says Thank You to swift996 For This Useful Post: | Calum (02-03-2014) |
#3133 |
Drives: small
Ouch! They should be supplying those higher grade bolts with the black oxide finish at a minimum. Thermal change and vibration must be too much.
| The Following User Says Thank You to Boxer486 For This Useful Post: | Calum (02-03-2014) |
#3134 | |
Drives: 86
Let me know how successful you are extracting the bolt. I've been putting off extracting them. |
#3135 |
Road Warrior
I mentioned this problem awhile back, got told I over tightened.
I replaced all the bolts with black high tensile as Boxer 486 picture. Especially the pulley nuts, which I've snapped 2 with changing pulleys. My mechanic used a hex head, knocked into the broken bolt and came out easy. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | TemeCal (02-03-2014) |
#3136 |
Also FWIW, I tried to merge two logs I captured from EcuTek on some pulls with the 72.5mm (intercooled) and the 75mm (non-intercooled), take it with a grain of salt:
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
