#2997 | |
Drives: shiny side up.
After some searching I noted others were similarly afflicted. I contacted innovate and they stated they had updated their tunes from earlier versions but still were retarding timing down low to compensate for boost ramp up. Others have suggested the problem stems from the throttled volume of the intake without the intercooler which might be solved by a blanking plug down the road. I've decided to hold off until innovate sorts this further. I laud their goal of a near-OEM seamless upgrade. The car drives so well and is so much fun unmodded I am unwilling to sacrifice in the quest for more torque. Clearly the stumbling on takeoff can be mitigated by further refining the tune but that represents an additional expense and not all of us have access to a capable tuner. I will be following closely to see what you wind up finding out. I am given to understand the intercooled kit is actually smoother but have not had the chance to test. |
| The Following User Says Thank You to dontpanic For This Useful Post: | APS86 (01-30-2014) |
#2998 | |
Grip>Slip
#2999 | |
Drives: Subaru BRZ with Delicious Innovate
| The Following User Says Thank You to calispec For This Useful Post: | APS86 (01-30-2014) |
#3000 | |
Drives: beater
What height are your GC spacers? They sent me 20mm initially and they damn near touched the hood. I told them about it and they said they would make them 15mm tall now. |
#3001 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | NickFRS (01-30-2014) |
#3002 |
Just the tip
Question:
I'm fairly sure that if I purchased the intercooler kit and put it on my car my self that I wouldn't need to worry about tuning it as far as daily driving, at least not right away? I'd just eventually need to get a tune to get the most out of it?
#3003 |
Drives: UM86 - 6MT
A tune is required. Otherwise... FAILURE
#3004 |
Drives: Raven FR-S
Anyone know what parameters to log after supercharging the car?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3005 |
Just the tip
So much for installing the intercooler kit myself unless I want to have it towed to the mechanic/tuner.
#3006 | |
Drives: 2013 Scion FR-S Manual in Whiteout
Assuming you already have the supercharger installed with a tune you should be okay. I installed my intercooler kit and flashed the intercooler specific tune a week or so later. |
| The Following User Says Thank You to 1010110 For This Useful Post: | stockysnail (01-30-2014) |
#3007 |
WUB WUB
Drives: 2013 Firestorm
Well, popped another belt.
Sent from my VS840 4G using Tapatalk
#3008 |
Just the tip
That's what I thought. I think the other guy was assuming I did not already have the supercharger on, which I do.
#3009 | |
Just the tip
#3010 |
WUB WUB
I did. Secondary belt is on now. That makes 3 stock sized belts, and one smaller belt. Really starting to grow old
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
