Old 01-29-2014, 04:09 AM   #2969
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by wrxgoose View Post
okay, so y'all know i'm a big proponent of this supercharger, i really do love it.
BUT!
it makes the car almost undrivable in the snow! normally i could creep in 2nd gear from a stop and be fine, but having so much torque immediately makes it spin way too much. i ended up having to ride my wheel along a curb just to get unstuck, and nearly spun twice.
Sort a tune out for it! My mode 4 is a low traction mode, full pedal is only equivalent to 30% throttle, you barely even notice a light touch of the throttle. I'll probably never use it but it's nice to know its there
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-29-2014, 04:12 AM   #2970
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
In case anyone needs conformation that the ground control strut bar setup works here it is. The spacers they sell separately ARE A MUST! Name:  ImageUploadedByTapatalk1390983099.399192.jpg
Size:  148.6 KBName:  ImageUploadedByTapatalk1390983112.349383.jpg
Size:  295.6 KBName:  ImageUploadedByTapatalk1390983123.650118.jpg
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-29-2014, 04:15 AM   #2971
CK_Bladesmith
Drives: Raven FR-S
Innovate Supercharger Owners Topic
As you can see the bottle is touching the bar, which makes it a bit of a pain in the ass to take off, but it's doable. The bar also sits on the rubber connector for the intake/TB (can't even fit a sheet of paper between them) but I see no harm in this.
Old 01-29-2014, 04:22 AM   #2972
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
be very cautious with your bottle cap being so close to your brace, remeber the engine moves while under load and you might crack your bottle.
you dont need to blow into it I just did to ensure.. Plus not very safe thing to advise someone to do I guess so rather dont.....
the system really will feed itself after 20 min or so. you hear the pump go quiet and run smooth, water flowing through the bottle.
Ryan86 is offline   Reply With Quote
Old 01-29-2014, 04:28 AM   #2973
CK_Bladesmith
Drives: Raven FR-S
The pump seems to be running smoother and I hear no bubbles churning through it. Coolant seems to be flowing into the bottle as it should. More testing tomorrow and hopefully a dyno soon. Delicious tune btw.
Old 01-29-2014, 05:05 AM   #2974
Ryan86
Road Warrior
Ryan86's Avatar
William is phenomenal with this kit. You going to enjoy his latest tune.
Old 01-29-2014, 08:43 AM   #2975
swift996
swift996's Avatar
BUT!
Try driving on Direzza Z2s, it's like getting in a ring with a bull.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-29-2014, 08:56 AM   #2976
APS86
Drives: GTS86 Manual
HI all,
Have had my sprintex kit fitted one week ago and amazed by how it has transformed the car - really appreciate all the info on this thread.
Have noticed that the car is a bit jittery in 1st and 2nd gear - I did notice that others have mentioned this ..... is it from tune or from torque
cheers and thanks
APS86 is offline   Reply With Quote
Old 01-29-2014, 09:45 AM   #2977
RyanITV
RyanITV's Avatar
Drives: 2013 FR-S 10 Series
Originally Posted by APS86 View Post
HI all,
cheers and thanks
Define "jittery" ?
RyanITV is offline   Reply With Quote
Old 01-29-2014, 10:17 AM   #2978
APS86
I suppose by "jittery" I mean that the throttle response is not what it should be - feels a bit laggy
Old 01-29-2014, 10:25 AM   #2979
Ryan86
Road Warrior
Ryan86's Avatar
Jittery = Hesitation???
who is your tuner?
First recommend you check for leak at the back L connectors, get some Quick Start spray and spray the connectors if you hear the idle go up you know the connectors are not sealed.
if all good then this is what im noticing now with hestitation between 1000 to 3000 rpm under normal driving
Shell or BP fuel
extremely hot days, we in summer now..
if I add some Octane Booster +3 Liqui Molly, it goes away. Some reason the SC does not like to run on our base 95Ron in heat.
Old 01-29-2014, 11:09 AM   #2980
RyanITV
RyanITV's Avatar
Aaah - yeah, I'm seeing the same thing, non-intercooled withe the Innovate supplied tune. Just got some starter fluid yesterday to test the vacuum connections at the back.
My intercooler upgrade kit *should* be here today if UPS makes deliveries after last night's snow. During that install, I planned on swapping the plastic fittings on the back with proper brass ones. I did notice that the vacuum line that connects right under the throttle body is pretty loose - it came off when we first tried to connect the other end to the back of the intake manifold. I plan on clamping it when I do the IC install.
Weather is 20-45 degrees F here, fuel is 93 octane BP (10% ethanol).
Ryan
Old 01-29-2014, 11:30 AM   #2981
Ryan86
Road Warrior
Ryan86's Avatar
Are you mixing 10% Ethanol into your 93 ??
If I'm understanding 10L Ethan to 40l 93 pump?
Old 01-29-2014, 11:33 AM   #2982
RyanITV
RyanITV's Avatar
It's dispensed that way at the pumps; all fuel locally is E10 (10% ethanol).
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
