#2843 |
Grip>Slip
We had to substitute worm clamps for some of those, not sure if we had to for all though.
#2844 |
Drives: 2013 SWP BRZ
I was given 6 larger clamps (two for on the water pump, two for those lines coming off the pump to the heat exchanger, then two for the inlet/outlet of the supercharger) and none fit. The rest were fine, but then again the only ones I used at that point was the one under the coolant bottle, and the 3/8 line).
#2845 |
Grip>Slip
Radium dual catch can kits start shipping next week.
#2846 | |
Little more info, I reached out to Radium.
#2847 |
Drives: 2005 kia spectra 5, 2004ford tauras
Why are the catch cans $425 and the duel catch can kit for the s2000 only $254.00?
#2848 |
Grip>Slip
#2849 |
Does anyone know the specs of the hose that runs out of the rear of the crank and into the supercharger?
EDIT - I found them: http://www.ft86club.com/forums/showthread.php?p=588959
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2850 |
Drives: Subaru BRZ with Delicious Innovate
It may have not been clear in my earlier post but the catch can I found is really similar to the radium catch can at less than half the cost. The little basket threads into the top. Air coming through the can passes through the basket, into the can and out the fitting at the top. I added part of a copper scrubber that you can get at a grocery store to help collect the suspended oil. Radium uses similar stuff on the S2000 can. All the oil falls into the cup and can be checked with the dip stick. I am not saying radium doesn't make an awesome product but I would rather spend $200 bucks on a track day and some fuel. You could even mount two side by side similar to how the post quoted did. I would buy two sealing washers and an o ring for the dipstick.
[IMG] [/IMG]If you want an easy install and are willing to pay for it by all means radium is the way to go.
| The Following User Says Thank You to calispec For This Useful Post: | CK_Bladesmith (01-23-2014) |
#2851 |
http://www.mcmaster.com/#93786a225/=qdqdwl
Sealing washer.. should be able to pick them up at a hardware store
#2852 | ||
Drives: 2018 Golf R
Yep, the only spring clamps supplied that we could use were the smaller ones on the way too small overflow tank hose. The others were one size too small. Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | xjohnx (01-23-2014) |
#2853 |
How many bolts are on the bottom of the elbow? I see 3 on the top.
#2854 |
#2855 | |
Getting to those lower bolts on the elbow is easier than the supercharger bolts? I'm not seeing how that makes it easier to remove.
#2856 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | swift996 (01-23-2014) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
