Old 01-16-2014, 01:03 AM   #2689
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
That's why I'm wondering if you have actually tested your boost with 70mm with the IC kit you may find you get more boost. Kits are the same so I not sure why I would get 12 psi and you 8 psi with a 75mm
I'm getting .7 bar 12 psi on 75mm
Hence I want to do the trial to see what I get with the smaller pulleys and do it on the dyno to see the gains achieved.
.7 Bar is 10.15 psi
Sellout is offline   Reply With Quote
Old 01-16-2014, 01:44 AM   #2690
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Originally Posted by TemeCal View Post
@whataboutbob (or anyone else who has needed a pulley)
Did Innovate have the idler pulley in stock? I screwed up big time tonight. I received a new bearing, which I was going to replace the squeaky one with.
I tried popping the bearing out with a press, not realizing the bearing is recessed...held in by a lip on both sides. Unfortunately, I snapped the pulley in half!
I'm not happy with myself right now. I leave Sat for a track event on Sunday. I'm REALLY hoping Innovate has these in stock, so I can request a next day air shipment.
So, back to my question, does Innovate stock these? If they don't, does anyone else have them? Infamous? Anyone in the SoCal area willing to sell me one??
Thanks!
Call Innovate. They got me one quick when I needed it. Don't think Infamous has them.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
The Following User Says Thank You to whataboutbob For This Useful Post:
TemeCal (01-16-2014)
Old 01-16-2014, 02:38 AM   #2691
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by Sellout View Post
.7 Bar is 10.15 psi
you are correct.
i was meant to say im got .7 bar on the dyno and 11 to 12 psi on my boost gauge.
not sure which is 100% accurate.
what boost are you guys getting with IC with 70mm pulley?
Ryan86 is offline   Reply With Quote
Old 01-16-2014, 08:34 AM   #2692
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Ryan86 View Post
you are correct.
Same or different altitudes?
Old 01-16-2014, 08:36 AM   #2693
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by xxscaxx View Post
Have fun. Make sure to check the clamps in case you need to run to the store to buy new ones. Get your hands ready to burp the system too. No joke my hands were killing me after
Saw that. I've got a bunch of those clamps around already in my macguyver box, and ordered some more from amazon just in case.
Old 01-16-2014, 09:29 AM   #2694
Ryan86
Road Warrior
Ryan86's Avatar
on the coast.
Ill check what happens when new pulleys arrive.
Old 01-16-2014, 09:45 AM   #2695
xxscaxx
Drives: 2013 SWP BRZ
on the coast.
I'll check it out as well, but I remember never seeing over 9psi on the 70 without the IC.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Ryan86 (01-16-2014)
Old 01-16-2014, 12:35 PM   #2696
TemeCal
Drives: 86
I called Innovate, and they were extremely helpful with my idler pulley issue. They didn't have any in stock. However, they gave me the part number. It's a standard/generic idler pulley that can be found at any local auto part store. O'Reilly's happened to have 2 in stock for $20 each.
Amazon sells them for $12 shipped, if any of you want to have an extra on hand. So, for those interested, here is the part number:
IDLER PULLEY:
Gates 38018
[ame="http://www.amazon.com/Gates-38018-Tensioner-Pulley/dp/B000C2YAOS/ref=sr_1_1?ie=UTF8&qid=1389889297&sr=8-1&keywords=Gates+38018"]Gates 38018 Tensioner Pulley : Amazon.com : Automotive[/ame]
TemeCal is offline   Reply With Quote
The Following 3 Users Say Thank You to TemeCal For This Useful Post:
Lawnik (01-16-2014), sw20kosh (01-16-2014), swift996 (01-16-2014)
Old 01-16-2014, 06:33 PM   #2697
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
@DarrenDriven To add to my tags/links in the first post.
My build link.
http://www.ft86club.com/forums/showthread.php?t=24596
My baseline 206hp/158tq before supercharger.
After supercharger will be in a couple days!
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
DarrenDriven (01-19-2014)
Old 01-16-2014, 08:21 PM   #2698
xjohnx
Grip>Slip
xjohnx's Avatar
is it sunday yet? just added a robispec oil cooler/radiator to the list of parts getting installed sunday.
The Following User Says Thank You to xjohnx For This Useful Post:
Old 01-16-2014, 08:35 PM   #2699
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
is it sunday yet?
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-16-2014, 08:52 PM   #2700
phloozy
phloozy's Avatar
Drives: Scion FR-S
dynoing also?
phloozy is offline   Reply With Quote
Old 01-16-2014, 09:02 PM   #2701
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by phloozy View Post
dynoing also?
yes, but not this weekend.
Old 01-16-2014, 09:06 PM   #2702
phloozy
phloozy's Avatar
Drives: Scion FR-S
boo, should do a before and after! Also I forget are you running on e85?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
