86WORX
Old 01-13-2014, 11:08 PM   #2661
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
[IMG][/IMG]
ADD W1 from eBay. I think it was $80 shipped. Us seller. Built VERY well. I would say it is VERY comparable to the radium catch can. One issue. They don't provide sealing washers for the nipples. They do give you 2-9mm and 2-15mm so it is perfect for our application. Buy a couple sealing washers from McMaster and you are golden. I opted to put the provided O ring on the OD of the canister threads because I believe it will seal better. I also put a small O ring on the dip stick.
[IMG][IMG]http://i332.photobucket.com/albums/m340/sickcis/BR-Zed/61672266-B795-4876-A59B-437***C60FD7_1.jpg[/IMG][/IMG]
I added a little extra baffling as well. I think radium uses a screen but this will do the same thing. Don't add too much because you don't want to restrict flow. Just something extra for the oil to stick to.
[IMG][/IMG]
[IMG][/IMG]
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following 2 Users Say Thank You to calispec For This Useful Post:
CSG Mike (01-14-2014), OmarGC (01-14-2014)
Old 01-14-2014, 12:52 AM   #2662
xxscaxx
Drives: 2013 SWP BRZ
For those of you who have installed the intercooler kit, is there some kind of voodoo magic I need to perform to get the hose clamps onto the intercooler posts in the front and back of the charger? Got home late so I couldn't finish up but I was trying to get the lines on and the provided clamps BARELY fit over the hose, and I can't get them over the nipple of those posts. Not sure why they would provide a pressure clamp like that with such little clearance.
xxscaxx is offline   Reply With Quote
Old 01-14-2014, 12:58 AM   #2663
olorin
olorin's Avatar
Drives: GBS Premium
I loosened the clamp:
Does yours have the same clamp?
olorin is offline   Reply With Quote
Old 01-14-2014, 02:09 AM   #2664
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I bought new hose clamps, the ones that came with the kit seemed to be really tight and I didn't want to deal with it.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 01-14-2014, 02:10 AM   #2665
whataboutbob
Here's a shot of those brass fittings I linked to installed.
I used 2.5 in of hose between the straight fitting and a brass elbow.
I also relocated the wire harness as there just wasn't enough room for me to get everything together back there with it in place. I stacked it on top of the smaller connector which is closer to the firewall and coupled them with zip ties.
Old 01-14-2014, 02:52 AM   #2666
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
with the pipes pointing down it creates so much more space to work behind the SC. Got me thinking....
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
whataboutbob (01-14-2014)
Old 01-14-2014, 03:15 AM   #2667
whataboutbob
And the twisting motion won't over tighten the plastic parts and make them loose. Oh yeah, and you won't need to pull the blower to replace them. Just cut the old ones off in place.
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
Jrdad (01-14-2014), Ryan86 (01-14-2014)
Old 01-14-2014, 03:56 AM   #2668
Ryan86
Road Warrior
Ryan86's Avatar
can you get to the allen keys bolts with the connectors you have used.
The L Connectors are almost directly infront of them making it difficult to get too even with the ball end allen key.
i also noted that the brake boost connector, no matter how many times i sealed it, due to heat it still comes loose. This time I have used plenty Teflon and loctite, seems to be holding out.
Old 01-14-2014, 10:41 AM   #2669
xxscaxx
Nope, mine came with these.they are so tight I don't know how you could get them over, but I don't like worm drive clamps so I'd rather use these but might have no choice and have to switch. Name:  ImageUploadedByTapatalk1389710464.689747.jpg
Old 01-14-2014, 11:38 AM   #2670
whataboutbob
I just went out and got the ball tip of the long side of an allen key in each. I'm not going to say that I'd be able to actually loosen those bolts with the blower on.
Old 01-14-2014, 11:46 AM   #2671
olorin
olorin's Avatar
Drives: GBS Premium
I'm not a fan of the worm drive clamps either, makes it look like a sprinkler system. I just got my kit so maybe they realized they those were to small.
Old 01-14-2014, 12:07 PM   #2672
xxscaxx
I literally got my kit yesterday.. lol. Do you still have the parts sheet, could you tell me what size clamps those are? I'm bummed because I prefer the pressure clamps but I just don't see how i'm getting them on. maybe @mines13 can chime in.
edit: Just gave Innovate a call, assured me I got the right clamps. Said to give it another shot and if I have an issue call back.
Old 01-14-2014, 01:08 PM   #2673
olorin
olorin's Avatar
Drives: GBS Premium
SAE 12 18-32mm, I separately picked up 2 smaller ones for the overflow line since that has a smaller diameter and I didn't want a huge tail.
Hope the spring clamps work.
Old 01-14-2014, 01:11 PM   #2674
xxscaxx
Thanks for that.
Yeah hopefully, but I'm not stupid and if it didn't work last night I don't believe it will today but maybe i'll come back on here and eat crow, or so I hope lol
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
