#2633 |
Drives: GBS Premium
For a dual catch can setup it would be that plus the breather line in the back of the SC. Meaning one can between each line. I think if you were only running one you would do the breather line in the back but with FI dual catch cans would be best.
| The Following User Says Thank You to olorin For This Useful Post: | Calum (01-13-2014) |
#2634 | |
Drives: 2013 Black FR-S
Dual catch would be best of course. You could always run both lines to the same catch and then vent it to air. Actually I wonder if you could plump both lines to a catch can and then plumb that to the nipple at the back of the supercharger. Is it ok if both breather hoses receive vac? |
#2635 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | sw20kosh (01-13-2014) |
#2636 |
Drives: GBS Premium
Yes, the real short one in the back of the SC
#2637 |
That Guy
Drives: 2013 asphalt FRS MT
With FI you'll want an air/oil separator between the block and the intake manifold, and another between the block and the intake pipe.
#2638 |
Does a one way check valve not work for Innovate owners?
#2639 |
#2640 |
#2641 |
Still confused about how you would do this. Never heard of this being done in place of a can.
So you would place a check valve in the lines and point them down to the ground? Oil/vapor would be able to escape out of the lines but nothing would be able to enter? |
#2642 | |
Unless I'm misunderstanding the intent here. |
#2643 | |
We are concerned with the oil that is being spit into the supercharger plenum/intake tract from the PCV/breather. A solution is to put a can in-line so that the oil never makes it to the intake tract. |
#2644 |
My solution would be to use a check valve to prevent the air/oil mixture from reaching the supercharger via the PCV/breather.
#2645 | |
Drives: WRB BRZ
I have seen this being used in other applications before. And generally will be a cheaper solution than a catch can. Worth researching and seeing if it works.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#2646 |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
