#2535 |
Drives: Toyota 86 GTS
Hey guys,
Wondering if anyone can tell me if this knocking noise I get is normal. U can really hear it at the end of the clip. Thought it might have been oil, so in drained it and out new oil in, but noise remains. Seems to only be at idle. [ame="https://www.youtube.com/watch?v=4t958LgZCuE&feature=youtube_gdata_player"]Super charger sound - YouTube[/ame] Also is the oil meant to be exactly at the engraved line on the dip stick? |
#2536 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Wow that is a nasty sound and not normal.
The booklet say fill 5.31 US fluid ounces or 157 milliliters. When I check mine it is just on that line on the dipstick. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | Tobz (01-07-2014) |
#2537 | |
Just a dude
Drives: Scion FR-S 2013
| The Following User Says Thank You to OICU812 For This Useful Post: | Tobz (01-07-2014) |
#2538 |
That Guy
Drives: 2013 asphalt FRS MT
Aren't guys having trouble going to a smaller pulley because the 75mm pulley is already making 11 psi? I don't think more boost would help, atleast not to the point of 300 whp on pump gas. I'm guessing they'd have to be making the compressor more efficient to get those results.
#2539 |
I'll try the 800 rpm thing tmrw. But if you guys think of anything else that would be awesome.
#2540 | |
Super 86
Drives: Red 86 GTS
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#2541 | |
Drives: frs
well, considering it is supposedly a fairly easy bolt-on and looking at what some folks have done could it be something like 3" CAI, 68 or 70 mm TB, bored out supercharger intake manifold and maybe some stuff to reduce the IAT like self adhesive insulation to the under side of the discharge manifold? but doubling the HP of the intercooled kit on the same blower is just hard to believe. PS add an oil catch can as well as it seems people are able to advanced timing a bit (up to 1*) when oil vapor doesn't make it into blower. |
#2542 | |
Drives: 2013 SWP BRZ
Happy about this but bummed because I wanted to go get dyno tuned in a couple weeks. I know I will go get tuned, then whatever this "secret" is will come out, and I will have to go back again Last edited by xxscaxx; 01-07-2014 at 02:38 PM. |
#2543 | |
Drives: Scion FR-S
My build thread, slowly but surely http://www.ft86club.com/forums/showthread.php?t=40509
#2544 | |
Road Warrior
So the guys at altitude are using 70mm and getting 11psi boost. |
#2545 | |
Road Warrior
#2546 | |
Super 86
Drives: Red 86 GTS
And as i said earlier i have no idea if Innovate is going to bring this to the US as well.
#2547 | |
#2548 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
For the record we just run some 255 Goodyears 240 treadwear and don't get too wild with launch control. It is just power pulling it loose above 3500 in higher gears. In the summer it was 200 UNCORRECTED tq, so figure at least 220-240 in the cold on e85 with the JDL unit. Car is dramatically faster in the cold without the IC, and we're able to run some seriously advanced timing on e85 in these temps. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
