Old 01-04-2014, 12:02 PM   #2507
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's not like the pipe is immovable. It's very flexible and there is enough movement to get it out the way when required. I really wouldn't see this as an issue. Anyway, I've got my update: 183lb.ft and 230bhp at the hubs (Dynapack). I'll get graphs scanned in and uploaded shortly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-04-2014, 01:27 PM   #2508
Kodename47
Kodename47's Avatar
Drives: UK GT86
75mm Pulley:
Comparison between my old N/A Tune. For reference my stock tune with replacement panel filter made 166bhp on the same dyno, same day.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 4 Users Say Thank You to Kodename47 For This Useful Post:
Alabang 86 (02-06-2014), bestwheelbase (01-04-2014), DriftEm (01-04-2014), swift996 (01-04-2014)
Old 01-04-2014, 07:22 PM   #2509
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Drift-Office / @DeliciousTuning or anyone else, any ideas why there's a slight drop 4/4.5k? Its not something that bothers as I don't feel it, more intreagued. The tuners car does similar but not quite as much. Different exhaust config though. For reference mine is decat manifold, Berk HFC and all else stock.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-04-2014, 07:42 PM   #2510
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by xxscaxx View Post
Does the coolant hose from the front of the inlet on the supercharger route on top of the oil filter, or behind it? Hoping its behind it, as I have the Forester XT oil cooler so it sits a few inches higher than the stock setup..
Mine doesn't i installed a Mocal oil cooler (identical to a perrin one).
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 01-04-2014, 09:52 PM   #2511
xxscaxx
Drives: 2013 SWP BRZ
I see you have a clamp on that hose in one of the bolt holes for the ac cover. Was that supplied with the kit? Seems like that may be the reason its pulling it back some.
xxscaxx is offline   Reply With Quote
Old 01-04-2014, 09:56 PM   #2512
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I never saw my kit before it was install (supplied and installed by the shop). I wasn't charged for any extra clamps either so i would assume it is in the kit.
Build thread
Old 01-05-2014, 06:16 AM   #2513
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by swift996 View Post
Thanks for all the updates. I will be interested in seeing it all on there. Does it look like there is adequate room to mount the oil cooler in the center? The reason I ask is I'm running the Perrin oil cooler and plan to upgrade to the intercooler here soon.
I have a mocal custom ordered kit, pretty much the same i just miss out on the fancy perrin mount.
Mines a bit further back but there is plenty of room.
Build thread
The Following User Says Thank You to Khorne For This Useful Post:
swift996 (01-05-2014)
Old 01-05-2014, 12:39 PM   #2514
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Finally got the time to fit mechanical ProSport boost gauge to the Sprintex Sc.
Can finally measure boost, 11PSI on 75mm pulley.
Managed to get gauge same color as the dash lights and keep vent functional.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
DarrenDriven (01-06-2014)
Old 01-05-2014, 04:18 PM   #2515
Kodename47
Kodename47's Avatar
Drives: UK GT86
Dyno Run:
[ame]http://youtu.be/l71J1cIDPR0[/ame]
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-05-2014, 04:29 PM   #2516
Ryan86
Road Warrior
Ryan86's Avatar
What SW and tuner have you used, as the dip around 4000rpm is not normal for this kit.
Old 01-05-2014, 06:43 PM   #2517
Kodename47
Kodename47's Avatar
Drives: UK GT86
Actually I've looked at a few graphs from the 1st post and it does appear to be there on all of them, the dynapack graphs do exaggerate it though.
It's done on ECUtek by Abbey Motorsport.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-05-2014, 07:15 PM   #2518
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
On some of the earlier tunes we did, yes there was a dip, but we have been able to remove the dip and have more of a flat torque curve. Though we did play around with the tune in that area in order to make that happen. Here is a link to the more recent tune most everyone us running.
Note these are Dyno Dynamic numbers, which read a little lower than a DynoJet.
Cheers,
William Knose
Old 01-05-2014, 07:18 PM   #2519
DeliciousTuning
Like I stated in my previous post I believe it is going to be in the tune. You can play around with the cams, timing, fueling and get it dialed out. It does take a fair amount of time to figure it all out though.
Cheers,
William Knose
Old 01-06-2014, 04:43 AM   #2520
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks Bill! I figured it may be cam timing, however it's really not something that bothers me, certainly not enough to warrant paying for more dyno time. If you look at this below, where I've created and scaled a graph similar to most other dynos and you can see how insignificant it really is:
Here is Abbey's own car, similar map:
You can see that there really isn't a dip if it was scaled out like my plot above and would actually look very similar to the @DeliciousTuning dyno graph. IMO it must be to do with the removal of the cat in the manifold.
.: Stealth 86 :.
Kodename 47 DJ:
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
