#2479 | ||
Drives: 2013 SWP BRZ
Did you have any symptoms prior to the coil pack going? from what I saw Bill at @DeliciousTuning has said, it seems theres a constant flat spot in power in the same RPM that throws no code, then after a while a code will come. I'm experiencing this "flat spot" right now, at first I thought it was the tune or maybe the car breaking loose just enough to where it wouldn't kick on the traction control light, but now i'm thinking its this. How much did the coil pack cost? I might just buy one to have in case. Quote:
Thanks for sharing, unfortunately i've already replaced them but this is good for everyone else on the forum. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | whataboutbob (01-03-2014) |
#2480 |
AutoX-10/10ths every run
My motivation to find the fittings increased with the amount of down time on the car. I'm at 2+ weeks and going through SERIOUS withdrawls...
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#2481 | |
right now for me, its the damn snow we are getting at the moment. suppose to get 8-10 inches tonight... ![]() I know I used NPT fittings, but I made sure to spray the fittings to check for leaks and had none so I won't complain. But definitely would have used BNPT if I realized that prior. Its funny, the NPT fittings I used to replace the plastic ones screwed in so much easier than the stock brass fitting in there that comes with the kit. Thing was TIGHT. I thought it wasn't correct at first lol. |
#2482 |
IC install. Here's photos of my pain.
#2483 | |
#2484 |
bob, better get that thing put back together before the autox
| The Following User Says Thank You to DriftEm For This Useful Post: | whataboutbob (01-03-2014) |
#2485 |
anything holding you up or just limited time to work on it?
I am hoping I can just drop the plastic tray on bottom and not remove my bumper. Haven't taken it off yet and don't plan on it. Hate how it sags after removing it so much, I had this issue with my sti. I used quik latches on it after a while because the sag drove me crazy
#2486 |
#2487 | |
I've just ordered the straight ones I linked to on McMaster-Carr and will use a 90 deg elbow to get it all connected together. The straight ones will let me put everything back together without having to take more parts off the blower.
#2488 |
Innovate told me to check the ground, I took off the ground, cleaned the area and reinstalled it. So far so good, but I'm going to do what Bob did and install a relay box so I get power straight from battery.
#2489 | |
#2490 |
Me too. I've got RCE T2s, Raceseng CASCAMS/Shock Tops, Whiteline bumpsteer kit, Mishimoto Oil cooler, SS brake lines, and a bunch of other misc stuff to finish after the IC is working.
#2491 |
hmm..wonder how the ground would do that other than being loose or maybe a bad connection or something. I haven't looked at the installation guide in a while to see where that ground goes, but seems odd it would pop it.
#2492 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Thanks for heads up. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
