Old 12-23-2013, 05:07 PM   #2395
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've just replaced plugs and coil pack on cylinder 1.
Charger is now using water I'm topping up after every drive for 3 days now. Looked everywhere can't find a leak.
Any suggestions?
Ryan86 is offline   Reply With Quote
Old 12-23-2013, 07:34 PM   #2396
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Any suggestions?
Any local companies specialize in finding leaks?
Old 12-23-2013, 07:44 PM   #2397
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any suggestions?
Remove the SC so you can get a good look at the intercooler, run the pump, and take a look.
Sorry to hear this man. Good luck.
Old 12-24-2013, 10:02 PM   #2398
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Sorry if this is a re-post - http://www.motoiq.com/MagazineArticl...torsports.aspx
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
akuhei (12-25-2013)
Old 12-25-2013, 08:24 PM   #2399
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by mit_peid View Post
Did i read that right, they didn't run a new tune with the intercooler and smaller pulley?
Old 12-25-2013, 09:06 PM   #2400
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Thats what it says. "Didnt have to retune the ECU".
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 12-25-2013, 09:52 PM   #2401
xjohnx
Grip>Slip
xjohnx's Avatar
just arrived yesterday and i've been holding off on the install because i'm waiting for the tune from delicious....now i'm tempted, but i'll probably hold off because i'm a big sissy.
Old 12-25-2013, 10:09 PM   #2402
akuhei
akuhei's Avatar
I'm jealous. I really want the whole setup and cant yet. I look forward to hearing how it goes and how it changes after the upgrade.
Akuhei's Blog
"Inconceivable"
Old 12-26-2013, 10:06 AM   #2403
xjohnx
Grip>Slip
xjohnx's Avatar
I'll be sure to post impressions and dynos as soon as I'm able to get it installed. The tune is the only thing holding me back right now.
EDIT: doh, forgot i still need catch cans. i wonder if radium has finished up their 86 kit yet. last i heard it was due in january sometime.
The Following User Says Thank You to xjohnx For This Useful Post:
akuhei (12-26-2013)
Old 12-26-2013, 03:35 PM   #2404
swift996
swift996's Avatar
Does anyone have any tips on the intercooler install? I've been reading some issues with lose connections and leaks. Just wondering what the latest lessons learned are? I plan to order mine shortly after the new year. I just got some aesthetic stuff on order so will put that stuff on first.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 12-26-2013, 04:46 PM   #2405
xjohnx
Grip>Slip
xjohnx's Avatar
Feel free to come help with mine if you'd like
From what I'm reading, it's best to replace the plastic fittings on the back of the manifold with metal ones. Someone else has a post on which ones they used. I went ahead and ordered these fittings from Amazon, assuming they will fit:
[ame="http://www.amazon.com/gp/product/B007IIXQ9E/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1"]SRP 90 Degree Barb Fitting 1/4" Pipe to 1/4" Hose - 22906 : Amazon.com : Automotive[/ame]
[ame="http://www.amazon.com/gp/product/B000CNB8MO/ref=oh_details_o05_s02_i00?ie=UTF8&psc=1"]Earl's 984206 Blue Anodized Aluminum 90-Degree 3/8" Hose Barb to 1/4" NPT Male Elbow : Amazon.com : Automotive[/ame]
Interested to hear what other tips people chime in with.
swift996 (12-26-2013)
Old 12-26-2013, 05:02 PM   #2406
Raven604
Any Dynos other then the carb tune showing intercooler 70mm on stock exhaust?
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 12-26-2013, 05:05 PM   #2407
xjohnx
Grip>Slip
xjohnx's Avatar
Is a dual catch can setup recommended for this kit with IC? or is a single catch can sufficient?
Old 12-26-2013, 05:25 PM   #2408
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Those plastic fittings are BSPT. I've been working on getting my intercooler in over the last week and will be replacing the 2 plastic fittings with new ones without the 90degree bend.
To quote an email I got from Innovate on this:
"The plastice fitting specs are the following brake booster or closest to passenger side is a 1/4BSPT to 10mm barbed 90deg fitting, the EVAP or closest to the drivers side is a 1/4BSPT to 8mm barbed 90deg fitting. If you choose to replace please make sure that the thread specs are replicated as severe damage will occur to threads on the casting if failure to do so."
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
