#1807 |
Drives: GT86
You need to disable another DTC in the calibration to stop P0420 being generated.
I'm interested in seeing dyno graphs from those with UEL headers installed. |
#1808 |
NW Region Moderator
Drives: FR-S No More
Thanks ft_sjo... I will pass that to my tuner if it trips again.
#1809 |
Grip>Slip
![]() Just waiting on the map sensor and a tune that has been adjusted for the IAT sensor. |
#1810 | |
Drives: LS Swapped BRZ
I know with my header code will come on and off... every few days... I forgot to have Delicious Tuning disable 420 code. I might ask them to do that when I send some him some logs of my car for a touch up. |
#1811 |
Drives: Subaru BRZ
#1812 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Ethan (09-24-2013) |
#1813 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#1814 |
Drives: 2013 SWP BRZ
it goes right next to the IAT sensor, to the right of it in that pic.
Would have to guess OMNI 3 Bar MAP Sensor. |
#1815 |
Drives: GT86
For those with charge coolers fitted, keep an eye on the de-gas hose near where it goes back up to the overflow tank. It can rub on the fuel injector cover and wear the hose down. Mine lost a couple of mm in just one week! Needs reinforcement or tying up somewhere.
#1816 |
Super 86
Drives: Red 86 GTS
Serial number and dat sexy supercharged engine bay.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
| The Following User Says Thank You to Khorne For This Useful Post: | DarrenDriven (09-25-2013) |
#1818 |
Road Warrior
Identified the problem, map sensor loom/harness for the 2.5 map had a pin missing. Harness was under the manifold so could not identify while checking.
I've heard rumor this problem has been identified, so double check your harness before connecting. |
#1819 |
Grip>Slip
#1820 | |
Drives: GT86
| The Following User Says Thank You to ft_sjo For This Useful Post: | DarrenDriven (09-25-2013) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
