86WORX
Old 09-22-2013, 04:35 PM   #1765
ft_sjo
Drives: GT86
Unicorn update.
The goods news. The thermistor integrated in the 2.5 bar Bosch MAP sensor which Sprintex supply with their charge cooler kit has the same linearisation curve as the OE sensor on the car. Plug'n'play (with cal change for offset/range). I'll even tell you what pin it is on the MAF plug if you spread magical sprinkles.
The bads news. High charge temperatures. Heat exchanger doesn't seem to be putting much heat into the water, if any. In 30-120mph testing I am seeing charge temperatures as high as 70C which is unacceptable in my opinion. It only gets worse with subsequent pulls. The water in the chargercooler (measured in the overflow bottle) did not exceed 28C during load. Ambient temperature 17-20C. I've fed this back to Sprintex.
I'm not sure i'd consider it fit for purpose, unless your application is just drag racing.
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
calispec (09-22-2013), Calum (09-22-2013)
Old 09-22-2013, 05:15 PM   #1766
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Originally Posted by ft_sjo View Post
Unicorn update.
Care to explain that for the more technically challenged?
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 09-22-2013, 06:31 PM   #1767
Calum
That Guy
Drives: 2013 asphalt FRS MT
Unicorn update.
First he starts off with the positive update. And that is, the temperature sensor in the manifold absolute pressure sensor that is supplied with the Sprintex version of this kit has the same change in resistance per change in temperature. You will have to calibrate the it, but you wont have to completely remap it. He'll even tell you which pin, on the mass air flow sensor, to splice in the temperature sensor so that the original equipment manufacturer's electronic control unit can read the aforementioned temperature. (The reason this is advantageous over the factory temperature sensor in the mass air flow sensor, is that the sensor in the manifold absolute pressure sensor is after the compressor, which generates a lot of heat, thus making temperatures reading much more accurate and meaning full.)
The negative part of his update is that intercooler is doing very little to effect the temperature of the air going into the motor. The water circulating through the air to water intercooler isn't getting warm and the air isn't getting cooled.
Basically, if you plan to run this kit with 91 octane, or even with 93 I'd say, go get a meth kit.
Old 09-22-2013, 06:55 PM   #1768
xjohnx
Grip>Slip
xjohnx's Avatar
Unicorn update.
I'll be interested to see how @FA20Club.com's numbers compare with the larger core.
Old 09-22-2013, 07:20 PM   #1769
vgi
Drives: frs
Unicorn update.
could you pls write a DIY on this?
vgi is offline   Reply With Quote
Old 09-22-2013, 07:28 PM   #1770
xjohnx
Grip>Slip
xjohnx's Avatar
Won't do you much good in the US unless you specifically source that map sensor. The Innovate kit reuses the stock sensor.
Old 09-22-2013, 07:46 PM   #1771
vgi
Drives: frs
my understanding it could be either of the 2:
- get this 2.5 bar Bosch MAP sensor instead of IAT plate
- hope that Innovate will supply this sensor with their intercooled kit
besides, not only us folks in US read this forum
Old 09-22-2013, 08:14 PM   #1772
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Can you supply us with a part number or picture of the Bosch sensor so I can take a stab at finding one? I am looking at getting a larger MAP sensor any way and wouldn't mind killing two birds with one stone.
calispec is offline   Reply With Quote
Old 09-23-2013, 12:10 AM   #1773
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Unicorn update.
Interesting... When we tested Innovates their laminova intercooler with on their test mule we were seeing temps drop as much as 100 degrees over the stock temperatures seen on the Innovate Supercharger without the intercooler. We also did some serious testing, out to the desert in the middle of the summer (Chuck Walla Raceway) and the temps stayed consistently low and allowed us to keep the tune more aggressive and of course that that made more power.
Definitely speak to Innovate or Sprintex about this. Something seems amiss.
Also do you know what temps you were seeing on the vehicle with out the intercooler?
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
xjohnx (09-23-2013)
Old 09-23-2013, 01:02 AM   #1774
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I have ordered the IAT plate from FA20Club should arrive shortly, was something they recommended.
I have the 2.5 bosch sensor on the Intercooled version that comes with the kit.
Im having a issue where we cannot get the car to idle, just keeps stalling as the rpm goes under 1000rpm.
been a long 4 days car standing.
Ryan86 is offline   Reply With Quote
Old 09-23-2013, 01:06 AM   #1775
xjohnx
Grip>Slip
xjohnx's Avatar
which fuel pump, injectors and tuner?
Old 09-23-2013, 01:17 AM   #1776
Ryan86
Road Warrior
Ryan86's Avatar
I was told that the stock fuel pump and injectors must be used dont need to change.
Fa20Club tuning
Tony been working all weekend and we just not winning.
Old 09-23-2013, 02:18 AM   #1777
ntaphse
Drives: beater
Okay I'm trying to get through this thread but only on page 40. I'm seeing tons of custom tuning being done on these kits, yet Innovate offers the system with a canned tune. Is it possible to bolt the kit up, load the canned tune from Innovate via ECUTek and have a good driving car? Just wondering if you guys are tuning so much to make more power or to make the car run right.
ntaphse is offline   Reply With Quote
Old 09-23-2013, 02:20 AM   #1778
brianhj
Drives: 2017 Camaro 1SS
I'd like to know this as well... My car is stock
brianhj is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
