Old 10-11-2013, 11:52 AM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by JustBoostin View Post
I cut stock brz vents for mine. And only left one clip. I put double sided foam tape around the edges and it holds flawlessly, and releases a ton of hot air. I'll update my post later with pictures!
*EDIT*
I'll follow your lead on this one soon
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
ftc~brz (10-16-2013), JustBoostin (10-12-2013)
Old 10-11-2013, 11:54 AM   #86
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I like that quite a bit. I think I might give it a go as well. I just didn't want to spend $400 or how much ever they cost for the Prova chicken wire ones.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
ftc~brz (10-16-2013), JustBoostin (10-11-2013), Sportsguy83 (10-11-2013)
Old 10-11-2013, 12:28 PM   #87
JustBoostin
Drives: Asphalt FR-S 6MT
I just used a dremel with a nice cutting wheel and painted the exposed metal and inside the fender hole. It even looks better lol
JustBoostin is offline   Reply With Quote
The Following User Says Thank You to JustBoostin For This Useful Post:
Old 10-11-2013, 12:34 PM   #88
mike the snake
If the high heat takes it's toll on the double-sided tape, an alternative to the tape is this glue called "Amazing Goop", it's like "Shoe Goo", a rubbery based glue that holds better than epoxy, but has some give to it.
It's easily undone with toluene on a Q-tip which won't hurt the paint.
The Following 7 Users Say Thank You to mike the snake For This Useful Post:
Anthony (10-12-2013), ftc~brz (10-16-2013), gdrider77 (10-11-2013), JustBoostin (10-12-2013), kmbkk (10-16-2013), Sellout (10-11-2013), Sportsguy83 (10-11-2013)
Old 10-16-2013, 04:39 PM   #89
Supermassive
Supermassive's Avatar
Originally Posted by DAN_BRZ View Post
are u saying a vented fender would be a better option then a vented hood??
I think the combination of both would be ideal. A vented hood in this car really does nothing aerodynamically, but it does keep the engine bay cooler. The vented fenders would help keep air pressure under the hood lower to keep the hood from flexing as much as I have seen them do so. Of course most FR-S/BRZ's won't be running around at 120mph+ but in the cases that do I think that the combo would be beneficial.
Supermassive is offline   Reply With Quote
Old 10-16-2013, 06:33 PM   #90
ftc~brz
Done
Drives: WRB BRZ
I was talking with another member today about making those functional vents on our personal cars…I'll wait until spring to give mine a try. Right now I have a vented deck lid.
ftc~brz is offline   Reply With Quote
Old 10-16-2013, 10:08 PM   #91
wallace03
wallace03's Avatar
Drives: WRB BRZ
Just to make sure, Vented hoods aren't beneficial for an innovate SC right?
wallace03 is offline   Reply With Quote
Old 10-16-2013, 10:49 PM   #92
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Vented hoods are beneficial on any car to help prevent heat soak and also aid with aero by reducing lift.
kask2_6.0 is offline   Reply With Quote
Old 10-17-2013, 12:28 AM   #93
wallace03
wallace03's Avatar
Drives: WRB BRZ
I guess i should have been more specific. Would it be similarly beneficial on a SC as it would be to a turbo?
Old 10-17-2013, 12:48 AM   #94
Ethan
Drives: Subaru BRZ
I am not an expert, but I think it depends on whether you have an intercooler and what kind of driving you are doing. And also the kind of gas you are using. I have the innovate sc, no intercooler, and crappy 91 octane gas. My car is a DD and on hot days I get heat soak. I would hope that a vented hood would help somewhat for that, especially in stop and go traffic where not a lot of air is flowing through the heat exchanger (once I get an intercooler). So, I am planning to do both the vented hood and an intercooler.
Ethan is offline   Reply With Quote
Old 10-17-2013, 12:57 AM   #95
wallace03
wallace03's Avatar
Drives: WRB BRZ
It is to my understanding from reading on the innovate SC thread that these cars start to drop in performance after a number of dyno runs due to the heat it builds up from the lack of an intercooler, which was why i asked the question about SC and vented hoods. Obviously the lack of intercooler = high heat, but it cools the SC in a different fashion since it doesn't provide direct air on to the unit itself. Would this direct air flow be similarly beneficial on a twin screw unit as it would be on a turbo? I'm guessing not, but i am wondering if it helps moderately enough to purchase a vented hood.
Old 10-17-2013, 01:12 AM   #96
vinh
Drives: a car
what happens if the vents let water get on to the air filter of the turbo?
vinh is offline   Reply With Quote
Old 10-17-2013, 01:21 AM   #97
SuperGTS
FOXTROT-ONE Founder
SuperGTS's Avatar
Drives: 12 Toyota 86 GTS,13 Subaru Forester
I believe Varis Japan has some nice vented hoods. Maybe you could find a vendor or a website because I'm not sure where I can get one :P
Proud owner of a Satin White Pearl 2013 Subaru Forester and a Pegasus White 2012 Toyota 86 GTS. --> **Garage**
Previous: '05 Evo 9, '05 S2000, '00 Civic, '02 VX HSV, '04 Z HSV, '08 E HSV, '90 EXA Coupé
SuperGTS is offline   Reply With Quote
Old 10-17-2013, 01:23 AM   #98
redsuns03
redsuns03's Avatar
I don't quite remember exactly but there's a vendor on here since I got a quote for a varis body kit. Just so you know, it'll take a couple months to make since they only do made to order.
Sent from the Underground Lair of Arizona 86 HQ
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 05:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 03:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 44 07-22-2012 11:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 10:57 PM
