#127 |
King of Kiwi Palace
Drives: Faster than you
The naca scoop will direct air into the engine bay, the side vents pull air out. Without the naca scoop you wont have a circular air venting system and you'll just have to rely on heat rising out the vents.
#128 |
Drives: Scion FRS Firestorm
I remember reading something about making any kind of scoop would disrupt the flow of air going through the radiator and that having vents alone are more effective at keeping the air flowing through the radiator and out the vents? Or maybe that was speculation and there isn't that big of a difference.
#129 |
Drives: Subaru BRZ
I replaces my BRZ faux vents with the Prova real ones. I had a body shop do the work. It looks completely stock unless you are a twins owner and know what you are looking at. All it took was cutting a hole and then sealing the newly exposed metal with primer. The Prova replacement part took a bit of sanding on the backside too to get a factory looking fit. As to how much heat does it evacuate? I did not do a before and after on engine bay temps so could not really say. I can tell you that when it is 80 degrees outside and I drive the car hard, after I park I will put my hand over the vent and the heat is substantial. I presume that when I am moving, even more heat is being sucked out because of negative pressure created by the shape of the molding in front of the vent opening. If anyone knows of a tape that changes color based on temp, I would get some and stick it to the vent as a test.
As to potential water damage, I don't think so. Water would have to be going at a weird upwards angel to get into the engine bay through the side vent. I would worry about a vented hood and water damage, but not the side vents. Finally, the real reason I did it was I hated the faux vent. |
| The Following User Says Thank You to Ethan For This Useful Post: | bama_brz (07-18-2014) |
#130 |
Drives: Hydra EMS Powered FRS Raven Black
Scoops bad, vents good. Anything you can do to exhaust the fenders and the engine bay will improve cooling and downforce.
#132 |
Junior
Drives: a car
how much did that cost? if its less than a vented hood then that's definitely do able as a cooling option for me.
#133 | |
NASA SpecE30 Racer
![]() http://www.rallysportdirect.com/Prov...rld-Rally-Blue
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#134 |
If you are handy with a dremel, you can make basically the exact same vents out of the BRZ fender garnishes for no $$.
#135 | |
Drives: Sterling BRZ Ltd
#136 |
Junior
Drives: a car
Those are fine, I was talking like Seibon CF vented hood price lol
#137 |
I Love custom Turbo kits
Drives: Limited BRZ
Like a BOSS.
#138 |
Boosted
Drives: Not a supra....yet
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Sportsguy83 (03-14-2014) |
#139 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | raven1231 (04-03-2014) |
#140 |
| The Following 2 Users Say Thank You to mike the snake For This Useful Post: | kmbkk (03-16-2014), Sportsguy83 (03-14-2014) |
| snails and turbos | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 12-27-2012 05:44 PM |
| Turbos making less power down low? | subatoy | Forced Induction | 40 | 10-03-2012 03:30 AM |
| Carbon Fiber Hoods. | Asterisked Accolade | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 09-25-2012 05:44 PM |
| Why does the aftermarket love turbos? Why not superchargers? | ahausheer | Other Vehicles & General Automotive Discussions | 44 | 07-22-2012 11:27 AM |
| For those crying about turbos | Mari0 | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 06-15-2012 10:57 PM |
