#85 |
Drives: White FR-S
Presumably to have the headers refaced you would have to remove the turbo from them, right? Would that require a new turbo gasket to put back together? Maybe it doesn't even need to be disassembled. I don't know how the surfacing process works.
I haven't installed mine yet but I'd hate to have to buy a new turbo gasket before I even knew if there was a problem. |
#86 | |
Drives: Subaru BRZ Limited
| The Following User Says Thank You to gdrider77 For This Useful Post: | qtwre (02-12-2014) |
#87 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 2 Users Say Thank You to King Tut For This Useful Post: | OrbitalEllipses (02-12-2014), SkAsphalt (06-04-2014) |
#88 |
I just Drive.
Drives: in the womb still
getting them refaced isn't that simple. You need them to be on the same plane I presume, therefore when you bolt it up..it is not "bending" to meet the head causing it to be under more stress to break a weld.
So it would be a pita to do.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#89 | |
Drives: 2013 "AVO Orange" FR-S
So the two flanges not being on a absolutely flat plain is not uncommon unless you went to a cast exhaust manifold. Even then, the Subaru cast manifold has a flex in it. Which has had cracking issues. And that's also what we've discovered over two decades of making and fitting Subaru exhaust manifolds, flex joints will fail. Furthermore, once the exhaust manifold heat cycles, the pipes are naturally going to start moving. That's inherent to the Subaru design. We know what the issue is with the leaking gaskets. The issue is that people are re-using their stock standard used gasket, which should be thrown out and replaced with new gaskets. There are many different aftermarket gasket thicknesses out there, and if they are too thick, they'll cause a height distance between the flanges at the exhaust manifold and at the bracket at the turbo that mounts to the block, which can pull the exhaust manifold up to 4mm. As a consequence, we will be supplying future kits with new exhaust manifold gaskets to make sure this won't happen. Current customers of our kits, if they've fit a Grimmspeed or similar extra-thick gasket, they will need to put a washer between the turbo-side bracket and the block to space it out correctly so that it's not pulling down on the exhaust manifold. |
| The Following 3 Users Say Thank You to AVOturboworld For This Useful Post: |
#90 | |
Ridge Racerrrrrrrrr
#91 |
It's not the end of the world - check if there is tension on that bracket next to the turbo, if there is, unbolt and use a washer or two to take the tension out of it. It's to take the load off the manifold at the exhaust port end, not to hold it down tight.
| The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | SkAsphalt (02-13-2014), ZionsWrath (02-15-2014) |
#92 | |
Ridge Racerrrrrrrrr
#93 |
yeah, as paul suggested, i put in a couple washers. Mine had about a 3mm gap due to the larger grimmspeed gaskets.
| The Following User Says Thank You to gdrider77 For This Useful Post: | SkAsphalt (02-14-2014) |
#94 |
Ridge Racerrrrrrrrr
Sounds like a very easy fix (cause who does not have a million washers laying around) so I wrote this down on my install guide and will do it once the weather here is not abysmal
#95 |
grimmspeed gasket here and it is definately leaking...
Will most likely change it again when I change the oil soon |
| The Following User Says Thank You to tiny41 For This Useful Post: | Sportsguy83 (02-23-2014) |
#96 |
So just pulled off my old exhaust and having a new custom 3" one done. One issue i had with spacing out the manifold with the thicker gaskets is that now the overpipe wouldnt fit without banging on the crossmember. So rather than keep fighting that, i decided to have a custom 3" overpipe back made.
It was really tight before with only a few mm gap, and so just spacing out the manifold by that 3-4mm really made it off. I see this as an issue for others that use thick gaskets, and then decide to put a larger overpipe in there. There is room for a larger overpipe, but getting it to line up with the discharge pipe might be an issue for some. Will post pictures once done. |
#97 | |
Living the dream
Drives: Fensport AVO Turbo GT86
#98 |
What is the issue you currently have with this?
| Tags |
| avo, bov, brz, turbo, uel |
| 2013 Hot Lava FRS "Drift build" | THA STI GUY | Member's Car Journals | 58 | 04-25-2015 05:55 PM |
| The RaceComp Engineering BRZ "Clubsport" Build | Racecomp Engineering | Member's Car Journals | 100 | 12-18-2014 03:18 PM |
| KO's Raven FR-S Build: Name "Raven12s" | KO | Member's Car Journals | 3 | 07-18-2013 03:09 AM |
| Whiteout "8ROKU" build from Dallas (Frisco) | jacobzking | Member's Car Journals | 23 | 06-27-2013 02:56 AM |
| Norsamerican's WRB BRZ aka "Backdraft" Build | norsamerican | Member's Car Journals | 2 | 06-20-2013 08:16 PM |
