| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
X Rated
Drives: 2017 BRZ Series.Yellow
![]() The left is the car color, the right is their "alternate color" for the white. It's a much closer alternate than some of the other colors they offer.
| The Following User Says Thank You to The359 For This Useful Post: | chanomatik (12-04-2013) |
#16 |
Glorious BRZ Master Race
Drives: Subaru Libird
I've got a Cusco antenna on order. Here are @mechaghost's pics of it (not mine):
Only because I wanted the JDM antenna for its similar shortness til I realized it's it tilts/folds requiring a different base that won't support sat radio which the USDM base does.
#17 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
I don't know about anyone else, but I hate the satellite antenna. I had an aftermarket satellite radio in my old 3 series, and that thing never dropped it's signal on the way to work (I drive through heavily wooded areas of I-5). Now this thing consistently drops signal in several spots, any time the South/South East has any serious tree obstruction.
I work with satcom at work, there is almost no reason for it to be dropping the signal as often as it is, I think it's mainly because they integrated it with the FM antenna or because the housing is poor. I really can't wait to try another option when it comes out, or I'm just going to drop satellite radio. |
#18 | |
Drives: 2013 Satin White BRZ Limited
#19 |
#20 |
Look in the radio section of the forums. I've tried several antennas and the FM reception is less than stellar with all the ones I tried. http://www.ft86club.com/forums/showt...ht=White64Goat
#21 |
SLOW BRZ
Drives: 2013 328i xDrive; 2013 BRZ
beat sonic for days!
#22 |
Drives: World Rally Blue BRZ Limited, MT
I have a WRB BRZ! I will be getting a Beat Sonic for sure!!!
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear |
#23 |
Drives: '13 BRZ
how hard is it to install these aftermarket antennas? I have a feeling the fin will be a little bit difficult, but the stubs r just twist on and off? not sure if im correct
#24 |
Drives: '13 DGM BRZ Limited
Yup. Twist off, twist on the new one. Even the fins are easy. Just twist off stock, twist/screw on the connector for the fin, wipe down the area the fin will sit on with IPA, line it up the way you want and then peel and stick.
#25 |
I actually used some blue painters tape to line up the fin with the center of the car, then mounted it as you mentioned. Took me all of 10 minutes.
#26 |
I should have specified, I'm having a problem with the Sirius XM antenna, not the GPS antenna. Mine was produced after the fix. Or is there a TSB for the Sirius antenna too?
#27 |
Mine was also produced after the problem was supposedly fixed. When I took it in for a service, I told the tech about my intermittent problems with reception etc. when they checked it, they discovered that the upgrade had NOT been performed on my car even though the vin# was after the problem range. Subaru authorized the fix and since then everything works perfect.
#28 | |
Drives: BRZ limited GBS
| Torn on Antenna Options. | 2pt5RS | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 02-18-2014 07:16 PM |
| Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 02:35 AM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 01:53 PM |
| WTT: Beat-Sonic Antenna for Modelista Antenna | joergasm | Canada Classifieds | 4 | 12-10-2012 10:13 AM |
| Antenna Options | Re~Mix | Electronics | Audio | NAV | Infotainment | 10 | 07-20-2012 01:02 PM |
