Old 06-28-2013, 08:53 AM   #29
FAER
Drives: Silver BRZ
Doh! My birthday isn't till the 5th
FAER is offline   Reply With Quote
Old 06-28-2013, 09:50 AM   #30
robispec
Drives: Black frs project
650 layaway deposit keeps the pricing
Robi
robispec is offline   Reply With Quote
Old 06-29-2013, 12:51 PM   #31
kster1
kster1's Avatar
I hope @sw20kosh doesn't mind me adding to his thread.
From the San Francisco bay area, I drove down to Robispec's shop yesterday to get his radiator installed; it was also nice meeting Robi and a couple of other FRS/BRZ owners. While driving south, I was seeing cruising oil temps in the 220s (F) that would peak to 245F when driving uphill. The ambient temps were in the 85-90F range.
On the way home after the install, it was initially a bit warmer (probably 95-100F) and I was seeing cruising oil temps in the 205F range with a peak of 215F while accelerating uphill in fourth gear. As I got closer to home, and the ambient temps were down to the 70s, my oil temps were down to the 195F range.
Coolant temps barely ever moved.
This is a quality product that simply works and I'm very happy that Robi has this option for us; I drove 13-14 hours yesterday for it.
kster1 is offline   Reply With Quote
The Following 5 Users Say Thank You to kster1 For This Useful Post:
createluck (01-30-2014), ImperiousRex (06-29-2013), ultra (01-02-2014), whataboutbob (07-03-2013), WillRacer1jz (07-03-2013)
Old 06-29-2013, 01:08 PM   #32
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
Nice meeting you @kster1! Was nice to see all the installations of the cooler yesterday as it deserves to be on every 86
ImperiousRex is offline   Reply With Quote
Old 06-29-2013, 01:21 PM   #33
kster1
kster1's Avatar
Great meeting you too @ImperiousRex. Having you guys around make the waiting time go much quicker with our car/track talk.
Old 06-29-2013, 02:00 PM   #34
TemeCal
Drives: 86
Nice meeting you as well. I got home around 9:30pm, which still put me home prob 3-4hrs sooner than you!
The quality of his cooler is incredible, and extremely stealth. The only way I can tell that something is different, is the sandwich plate beneath the oil filter. Huge props to Robi (and Junior) for such a great product.
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
createluck (01-30-2014), whataboutbob (07-03-2013)
Old 06-29-2013, 04:07 PM   #35
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Robi
I wish I had the money to hold a deposit. But all my money is going to make my supercharged celica run cooler. I am converting it to use e85 because she cant deal with temps above 85
clayrush is offline   Reply With Quote
Old 06-30-2013, 11:55 AM   #36
karlsson
Drives: seat ibiza
What about the occasional oil-change?
wouldn't you need to drain the radiator seperately because the oil needs to flow up into the sandwichplate and therfore won't drain through the oil pan?
karlsson is offline   Reply With Quote
Old 06-30-2013, 12:33 PM   #37
BRZ NA
Drives: WR blue
Really? it doesn't block off the airflow for the radiator?
BRZ NA is offline   Reply With Quote
Old 06-30-2013, 12:54 PM   #38
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Draco_PR23 View Post
I will send you a PM too, I ordered the AVO kit (waiting on ETA) and I want this radiator/oil cooler combo.
Haven't forgot about you, AVO kits are coming and this would be a great add on if Sportsguy can get it to fit I would go for it.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
Draco_PR23 (06-30-2013)
Old 06-30-2013, 03:45 PM   #39
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Cant wait for the kit and I already spoke with Robi about it (:
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
JoeBoxer (06-30-2013)
Old 07-03-2013, 10:57 AM   #40
karlsson
Drives: seat ibiza
what about that?
Old 07-03-2013, 11:31 AM   #41
djdnz
1337
Drives: 2013 BRZ WRB S/C
This would be the same for any of the oil coolers at the moment. The quantity of oil in the cooler would likely be minimal, so it would just mix with the new stuff at a low dilution. Valid concern though, hadn't thought of it before.
djdnz is offline   Reply With Quote
Old 07-03-2013, 01:24 PM   #42
robispec
I remove the fill line at the take off plate cap the fitting and gently apply air to the fill line this pushes most of the o out of the cooler.
Your other option is to remove the alum pan. Remove the return line at the take off plate and just lower the hose into your drain pan. This will gravity drain the cooler.
The Following 2 Users Say Thank You to robispec For This Useful Post:
DAEMANO (07-19-2014), whataboutbob (07-03-2013)
Search this Thread:
Advanced Search
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 05:27 AM
Robispec Suspension Installed: A Review sw20kosh Tracking / Autocross / HPDE / Drifting 57 08-17-2013 02:12 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-22-2013 12:18 AM
Shout out to Robispec sw20kosh Southern California 2 05-22-2013 04:44 AM
ROBISPEC@ FT-86 CUP GARAGE #1 Buttonwillow robispec Tracking / Autocross / HPDE / Drifting 7 02-20-2013 11:11 PM
