Old 06-24-2013, 07:18 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I asked before and did not receive and answer so I'll ask again:
Originally Posted by robispec View Post
Works with Full blown kit/ Vortech SC/ AVO/ Innovate SC...
Stock bumper beam stays stock and in stock location.
Are you absolutely sure it fits the AVO kit? I measured the gap between the top condenser bracket bolt and the AVO IC, and it was less than 9 mm of space. Not trying to argue or anything, but I've already tried with two different radiators and no dice, they don't fit... Would it require reworking the AVO IC location? The main problem with the AVO IC and bigger radiators is the top driver's side condenser bracket bolt.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Nasty Sausage (04-11-2014)
Old 06-25-2013, 01:19 AM   #16
sw20kosh
Drives: 2013 Black FR-S
how hard would it be to move the avo IC? I didn't take any measurements but it looked like everything bolted up easily in the stock location. @robispec would be best to answer this question. Have you tried phone'ing him?
Old 06-25-2013, 01:28 AM   #17
robispec
Drives: Black frs project
the condensor standoffs are 1.75" long and only need to be .75 to mount the condenser closer to the radiator. I looked at the avo Kit in vegas and also got the impression by the AVO reps there that the solution would fit.
I have not test fit the radiator on a AVO car but there is now if I shorten the condenser stand off brackets more than enough room...almost 2"
robispec is offline   Reply With Quote
Old 06-25-2013, 08:36 AM   #18
mad_sb
Drives: 2013 Asphalt FR-S
Is there a change in distance from the front of the motor to the engine side of the rad? I'm waiting for nameless to release the long tube tri-y headers and they are talking about including and aluminum fan shroud and slim line spal fans so that has me worried about clearance issues if the rad pokes into the engine bay any father than stock..
Other than that concern, i love this solution!
Old 06-25-2013, 10:05 AM   #19
Sportsguy83
Drives: Limited BRZ
So, do you supply the shorter standoffs, do I need to modify the stock standoffs, what would I need to do?
Sent from my HTC One X using Tapatalk 2
Old 06-25-2013, 10:07 AM   #20
robispec
for you I would modify the standoffs !
The Following User Says Thank You to robispec For This Useful Post:
Sportsguy83 (06-25-2013)
Old 06-25-2013, 10:24 AM   #21
Sportsguy83
Drives: Limited BRZ
Awesome! We'll be talking via PM soon. Now go back to sleep, it's too early for you.
Old 06-25-2013, 10:43 AM   #22
jamesm
i wish this would fit with my turbo kit. it might, but i'd have to buy one to find out
Old 06-25-2013, 10:46 AM   #23
Sportsguy83
Drives: Limited BRZ
Step into it. I've already bought and test fitted two which didn't fit :-D
Old 06-25-2013, 11:36 AM   #24
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I will send you a PM too, I ordered the AVO kit (waiting on ETA) and I want this radiator/oil cooler combo.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
robispec (06-25-2013)
Old 06-25-2013, 03:36 PM   #25
robispec
Wonder if it'll fit with a Nameless header...
the lower edge of the radiator is in the same plane as the stock radiator so we could reuse the fans.
I would asume that since the lower radiator fan shroud is is the same location the trimming would be the same.
Old 06-25-2013, 06:25 PM   #26
Pete
Pete's Avatar
Drives: 22 BRZ
This cooler is on the short list Robi, I hope to pick it up this summer. Kudos on the solution. @OrbitalEllipses I hope it does fit with the nameless headers, and the headers fit with my vortech kit, I still haven't gotten a straight answer on that.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 06-28-2013, 06:42 AM   #27
FAER
Drives: Silver BRZ
bump for the best cooling solution around bang for buck and effectiveness
FAER is offline   Reply With Quote
The Following User Says Thank You to FAER For This Useful Post:
robispec (06-28-2013)
Old 06-28-2013, 08:24 AM   #28
robispec
Price goes up July first.
Search this Thread:
Advanced Search
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 05:27 AM
Robispec Suspension Installed: A Review sw20kosh Tracking / Autocross / HPDE / Drifting 57 08-17-2013 02:12 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-22-2013 12:18 AM
Shout out to Robispec sw20kosh Southern California 2 05-22-2013 04:44 AM
ROBISPEC@ FT-86 CUP GARAGE #1 Buttonwillow robispec Tracking / Autocross / HPDE / Drifting 7 02-20-2013 11:11 PM
