go_a_way1
Old 07-25-2020, 11:02 PM   #10865
BlOody_BoOger
BlOody_BoOger's Avatar
Originally Posted by 86TOYO2k17 View Post
Interesting. I know ecutek it only reads 19.9 total psi with stock map, which minus 14.7psi ambient is 5.2 psi. With my scangauge it’ll read to 5.6psi. My mechanical gauge however says i am at 12.5psi. I don’t remember what OFT map reads. I know stock sensor is very limited though. I would stop doing pulls until you get a new MAP sensor or at least boost gauge to see real numbers. Maybe you are really making about 7psi. It would be surprising to me at least with bypassing intercooler if you didn’t. But that intercooler should have a 1-1.5 psi drop.
Thanks yea I'll be sure to install it before I start tunning the car. So once I'm doing hard pulls I'm reading accurate numbers.
BlOody_BoOger is offline   Reply With Quote
Old 07-25-2020, 11:14 PM   #10866
Urmyson
If the boost is holding at the higher rpms it should be a win. When I'm around 7k the boost goes down to about 1.5 psi and there really isn't a lot of top end. If you're above 4 psi at 7k it should make a pretty big difference.
Are you running the proceed controller where you can adjust the ESC motor with the RPMs? If so maybe change it where the motors ramp up a little slower and aren't at 100% until you are at 4kish. I would think the stock ESC tune could handle that because you really shouldn't be hitting over 5-6 psi of boost.
Urmyson is offline   Reply With Quote
Old 07-25-2020, 11:20 PM   #10867
BlOody_BoOger
I don't have the proceed controller. Which I'm kinda ok with since the hit almost feels like a shot of NOS I do have it set to go off at 90% throttle so when I go full throttle it comes on right around 3500. Here's a question though should I keep the intercooler on? Would the colder air despite losing a lil bit of boost produce more power than having it off and making that extra boost?
Old 07-25-2020, 11:32 PM   #10868
Urmyson
You will need to find out the intake temp and see how high it is. I wouldn't think it would be needed but it's hard to say without knowing the temp. You could always try it for a day with it and then without it and see how it feels.
Old 07-25-2020, 11:36 PM   #10869
BlOody_BoOger
Yea was I begin tunning it I can talk to the tuner and have him see. It's actually pretty easy for me to swap it in and out since I have the grill off so no need of having to take the hole bumper back off
Old 07-26-2020, 12:06 AM   #10870
86TOYO2k17
Drives: 2017 toyota 86
If you are running E85 take it off no point at such low boost levels. E85 Is so knock resistance it’s not worth the pressure drop.
If on pump gas it might be beneficial for the track. But if just Hwy pulls / back roads / canyons I don’t think it’s needed.
IAT temp is taken from the MAF which you have post blowers, so it should be pretty easy to test before and after temps with OFT doing a pull of each.
Also how much boost the intercooler drops will factor in. If it’s dropping temps from 20 above ambient to 5 above (15f drop) but at the expense of 1.5psi definitely not worth it. 20F to 1psi would be a decent compromise. But again with E85 not needed. Really 7-9psi is the “cross over” where an intercooler starts to really be beneficial, but that’s with a traditional FI which typically run a lot hotter then an ESC would.
Also intercoolers are sized and rated to match the flow rate of your FI system, a too large of cooler will just create unnecessary pressure drop.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
CY86 (08-17-2020)
Old 07-26-2020, 12:13 AM   #10871
BlOody_BoOger
Good input. I think I'll keep it off for now. Hopefully by next week I can start the tunning if the guys at OFT aren't super backed up.
Old 07-26-2020, 12:47 AM   #10872
86TOYO2k17
My personal experience with custom OFT tune with OFP from about 2 yrs ago it took 3+ weeks per revision after sending logs. My NA tune took almost 6 months needed 7 revisions. Several other forum members with more recent tunes had same experience. Steve99 and Wayno also do custom OFT tunes. At least you already have the base ESC tune so it’s probably a few minor adjustments and might only take 1-2 revisions to dial in.
Old 07-27-2020, 08:44 PM   #10873
86TOYO2k17
Curious, when you bypass intercooler how do you have the pipes routed?
If you did want to add in an intercooler i would use one of these. Almost no psi drop and still very effective at reducing temps. This would most likely be a total net HP gain, and prevent heat soak in tougher conditions.
http://www.frozenboost.com/?searchstring=Long+flow.
You would need a water pump, reservoir, and radiator. For pump Use a tap a fuse to an on switch source for hot wire (several options in cabin fuse box) and ground to chassis or negative battery. Lots of places to mount the reservoir, and mount a small radiator where your intercooler is now, or get a chase bay windshield washer reservoir to relocate windshield washer reservoir and put the radiator behind driver fog light. That’s what i did for my trans cooler works great. Would be a cool little project to finalize this dual ESC project of yours.
CY86 (08-17-2020)
Old 07-29-2020, 10:30 PM   #10874
BlOody_BoOger
Does anyone here know how I update my OFT to the flex fuel template so that it can read the ethenol content off my flex fuel kit?
Old 07-29-2020, 11:03 PM   #10875
86TOYO2k17
@steve99 probably does
Old 07-29-2020, 11:04 PM   #10876
BlOody_BoOger
Lol he's currently working on my tune he told me to update my tablet
The Following User Says Thank You to BlOody_BoOger For This Useful Post:
86TOYO2k17 (07-29-2020)
Old 08-02-2020, 11:13 AM   #10877
jflogerzi
jflogerzi's Avatar
I think you need to contact shiv
2013 Series 10 FRS #553
Old 08-02-2020, 11:30 AM   #10878
BlOody_BoOger
We got it already, the templates were on the website. I'm currently now working with Steve on a tune we've ran into a few prob. But it seems we're on the right track. It was just a of miscommunication. But yes we're going through revisions and it's great cuz he's in Australia and I'm in California. So when I wake up I have a new tune and when I go data logging after work and send him the logs. He's just waking up and starts working on the revisions
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
