#8765 |
daGangsta
Drives: 2013 FR-S 6MT
@Shiv@Openflash is there any way we can use our OFT Dollars towards the purchase of the Procede Controller?
#8766 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
@Shiv@Openflash
Does anyone who received their PROcede have an issue with the female 3.5mm aux cable? Mine is way too small for some reason and the pedal button cable will not go in.
#8767 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
There's a joke in here... But I'm holding back. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#8768 |
Addicted
Lol. I had the same thought writing that post.
| The Following User Says Thank You to l0aded For This Useful Post: | Sojhinn (05-05-2015) |
#8769 |
Did my suggestion work? Sent from my iPhone using Tapatalk
#8770 | |
Drives: WRBrz
I'm running into the same issue...was thinking about taking a drill bit to it, but iono if that's a good idea..
EBSC - dt.FF - MXP CompRS
#8771 |
Ok sounds like the wrong size was bought. Quick solution: run to RadioShack and buy an adapter 1/8" female to 3/32" male. Mino or stereo should be fine
#8772 |
Drives: WRBrz
Just my luck... Radioshack near my house closed down lol
#8773 |
Best buy? Sent from my iPhone using Tapatalk
#8774 |
Drives: WRBrz
won't make it in time, i'll give it another go tomorrow.
#8775 |
Addicted
Per Sojhinn's instructions, go to Fry's/Radioshack/Bestbuy etc and get a 2.5mm (male) to 3.5mm (female) adapter. Fits like a glove after. Hopefully nothing else goes wrong.
Also the 10mm screws with the thing attached in the beginning... yeah I don't have those for some reason. Luckily I have spare screws but kinda weird. Am I missing something important? What is the black box in the video? I do not have one in my car. Update: T-Tapped green/black to the 1st of the 4 connectors. T-tapped green/yellow to the 3rd of the 4 connectors. Grounded the hook wire. T-tapped the power fuse slot. When I start my car the ESC digital display turns on (28.5) but when I drive the ESC never activates (stays ~28.5) and it feels like there are dead spots similar to when you first flash a new tune. I'm assuming that either one of the two ECU taps went wrong or something is up with the activation 3.5mm plug. When I remove the plug from the PROcede harness the ESC activates so it works as it should as far as I know (plugging it back into the foot switch still works as well). Any ideas on what is going on? Is it possible Shiv forgot to load the map or the map is wrong? I double checked all my connections and they seem fine. Is there possibly an issue with the activation switch since it came with a 2.5mm connector and I used an adapter?
#8776 | |
Drives: Scion FR-S A/T, Whiteout
#8777 | |
#8778 | |
Make sure your adapter isn't stereo to mono, and is just stereo to stereo. (Mono to mono should work too but just in case) Second theres a possibility that the map wasn't loaded. Snag the software and tune from shiv's site. Also what black box? Can you tell me what time in the video? For anyone that needs help. Either PM me or quote me so I see the notification pop up on my phone. Work is slow today since my students are taking AP tests all day.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 05-05-2015 at 12:25 PM. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
