#2465 |
Drives: WR Blue BRZ, 240Z
Which make and model relay did you use?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#2466 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#2467 |
Drives: Subaru BRZ
I used this relay from Radio Shack: 12VDC Coil DPDT Miniature PC Relay
Model: 275-249 | Catalog #: 275-249 $4.97 |
#2468 |
Drives: Whiteout FR-S
Has this been tested on an auto? I'm assuming the transmission should be able to handle the extra power fine, but would the stock tune work?
#2469 | |
![]() Sent from my HTC One using Tapatalk |
#2470 | |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
The relay is in a project box in the glovebox and is enabled 10 seconds after the accessory power comes on. It's been perfect for the last 5 weeks. |
#2471 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#2472 |
Small update:
Took my car by Rob's shop yesterday to try a blow through maf design. Rob sourced a factory sized pipe for which we could mount the MAF. Unfortunately this aftermarket pipe caused our MAF sensor to be raised up about a quarter of a inch. While installing it we didn't think anything of it.... On first start the engine sputter to life and then promptly died.... This slight raising of the maf caused the car to not even run... We were not expecting such a small change to have such a large impact..... Back to the drawing board . All in all it was a learning experience and Rob is now looking to make a housing that will be a factory replica as far as dimensions go. Once we get a blow through maf working with a MAP boost stop it should help any of those people wanting to run the ESC on stock tune. It will also help to really fine tune with ecutek and brz edit with IAT being post compression. The blow threw maf will also get rid of some of the false maf reading we are getting very low in the rpm range. So for anyone thinking I only post the good... This is a little road block we ran into ![]() As always... Stay tuned for further updates and developments. ![]() Sent from my HTC One using Tapatalk |
#2473 | |
#2474 |
#2475 | |
Drives: 2013 FR-S Argento
Sent from my iPad using Tapatalk - now Free |
#2476 | |
#2477 |
Drives: Subaru BRZ
After driving with the ESC and tune for 10 days it's my opinion that this model is just about ready for production. The one little problem I had was the arming switch not turning off with the ignition (and the possibility that you could drain the starting battery) but that problem was solved. Other than that the BRZ drives normally until you hit wot and the car takes off. A much greater boost than you get with vtec on a Honda. It does move you back in the seat and tells you immediately that there is something different about this car. My gas mileage seems to be identical to what I was getting before the installation. The drag reduction works seamlessly and never even notice that it is operating. Absolutely no complaints.
#2478 |
Drives: 2014 Toyota 86 GTS
Have spent hours late at night reading through this thread, has been really interesting to see what can be achieved with this "Electro" Charger.
Keep up the good work guys. -PB |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
