#169 |
#170 |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Just pointing out that a lot of people bought the car in spite of it's woeful power output as there are no other options.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#171 |
#172 |
i kill cones.
Drives: around cones in a parking lot
bump... I want to keep reading this discussion. most interesting thread on the forum
2013 SSM BRZ Limited 6MT
#173 | |
Drives: Subaru BRZ Sport Tech Satin White
So is torque at low rpm. There is no torque dip, there are two torque peaks. This results from VVT that isn't continuous. The Porsche Cayman flat 6 exhibits EXACTLY the same torque curve patterns and nobody whines about that. FIAT may have the answer with their multi air design. This uses variabke hydraulic valve lifters to vary the valve lift and duration by changing the height of the hydraulic valve adjusters. Exceptionally ingenious design but patented to FIAT Powertrain. The result is a theoretically infinite cam profile. The tricky part is response time. |
#174 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
(That having been said, I agree with your basic point - just because people are whining about it doesn't mean that I think they are justified in their complaints) |
#175 |
Drives: MR Spyder/GT86
The Torque dip is fixable with a good header and a tune so why would someone live with the dip when you can do something about it
#176 |
| The Following User Says Thank You to chrisl For This Useful Post: | BRZ21 (10-14-2013) |
#177 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
After owning my G35 for a while the only thing I hate about it is I wish It was 300-400 lbs lighter. That's it but I can rarely feel that weight unless I hit a corner aggressively. This is one reason why I believe folks take more to GT's than Lightweight 4 cylinder Sports cars. As a daily driver the compromises is not that bad but as a track beast it would probably understeer more. I would rather bitch about my car needing to be 300 lbs lighter than needing more power/torque. I owned a RSX and I hated that engine with a passion vs the weight I hate in my G35.
#178 | |
This engine is tuned to drive well around town when you generally short shift into fourth or fifth at 30 mph and to drive extremely well whenever you can run the engine up to red line. The minor torque drop at sound 4,000 rpm is very easy to avoid or just drive through. You will need to use a lower gear than you think to accelerate to pass on the highway though. No aftermarket tune will fix that unless it also involves a supercharger. |
#179 | |
Drives: FR-S 6MT
Power doesnt make up for COG or mass. You can overcome the weight with power to accelerate , but its still there when you have to change direction or slow down. its all compromises.. everyone wants more power.. but the FRS already has enough to be very entertaining in stock form.. |
#180 | |
#181 |
Drives: FR-S 6MT
#182 |
| New rumor: 1.6-liter turbocharged engine one year after initial introduction | Clode | Scion FR-S / Toyota 86 GT86 General Forum | 208 | 12-16-2016 08:14 PM |
| Frs not being produced in auto? | camelflage | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 04-17-2013 09:50 AM |
| VR6 engines... | dem00n | Other Vehicles & General Automotive Discussions | 29 | 01-25-2013 02:41 AM |
| 100 hp/l NA engines | einzlr | Other Vehicles & General Automotive Discussions | 95 | 11-15-2012 08:55 PM |
| So you think you know engines? | Ryephile | Other Vehicles & General Automotive Discussions | 43 | 02-04-2012 04:49 AM |
