#141 |
Registered you sir
Drives: 99 impreza coupe
Everything can screw up, bent valves already happen during engine failures so its something we can foresee, though their computer is no slouch.
Energy lost? You mean the energy you spent to make those gears and cams turn? The air system doesnt have that. Did you watch it through, it can become a near perpetual system. I really hope that technology gets widely applied, crazy factory/aftermarket tuning implications. |
#142 | |
Drives: '06 AM V8V Coupe
The air system has to push the valve against the spring, loading the spring takes energy. When that valve bounces back there's no good way to capture the energy so it's dissipated into some kind of shock absorbing system. Pumping air or hydraulic fluid to push the valve can be even lossier than the mechanical friction of a cam; The cam loses some percentage of the energy you put in to friction (but the forces are greater when the cam surface is at an angle), but the air pump and valving is likely to see very low efficiency. One possible solution is an electromagnetic actuator with additional hydraulic damping of some sort, but the challenge is of course getting a magnetic field that is strong enough to apply significant force to the tiny valve. Last edited by serialk11r; 10-03-2013 at 04:42 AM. |
| The Following User Says Thank You to serialk11r For This Useful Post: | df.dima (10-03-2013) |
#143 | |
A long >12.3 degree incline is very common on back roads across this country not talking highways. Why not downshift? Well this is a 2012 build date, no 01C calibration available for these cars. Just examples of why the Fa20 is not on my list of the best 2L engines ever produced. Though I think that it has potential via the aftermarket long term.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#144 |
Registered you sir
No wasting energy on turning the gears and cams themselves. Theyve Already proved it to be over 20% more efficient than conventional motors and the tuning potential is nearly limitless when you dont have to be bound to a cam profile
#145 | |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#146 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
(Feel free to list a specific road though - it's easy enough to verify slope with Google Earth) |
#147 |
lol, 12% grade is ridiculously steep, especially for a heavily traveled road. I'm doubtful of this. I don't think I've ever encountered anything over 5% when driving in the mountains.
#148 | |
Essentially though, you only need to vary either lift and duration together to get most of the benefit, and with roller followers or whatever they're called the friction is reasonably low, so I would bet on some kind of cleverer hydraulic lift adjustment system supplanting the current ones. F1 has used pneumatic springs, but they still have cams. In fact, a fixed cam. Stupid regulations killing innovation and progress. |
#149 | ||
You guys need to get out more. This is just cities listed below, in the country these 300 year old PA roads are very steep and my FRS won't pull past 4200rpm up the hill up toward my house in 3rd (no I'm not posting where I live and yes its got a 20 mph speed limit, not proud of that .) :Quote:
JMHO but either the FA20 is lacking a little or the FRS weighs too much. I honestly think they designed this engine around a 2500 lb curb weight but when the chassis ended up over target and the engine ended up under target it was too late, just a guess.
| The Following User Says Thank You to regal For This Useful Post: | WolfpackS2k (10-04-2013) |
#150 | |
Registered you sir
Rollers are physically bound to keep repeating the same lift and duration upon every rotation, with their air system both of those conditions can be changed hundreds of times in a single second with no need to follow the shape of a physical roller. The reason no one is doing it yet is the same reason no one was doing hybrids in the 90's, the technology is still just too fresh. |
#151 | |
Registered you sir
#152 | |
I've watched the video. How do you know that thing isn't using a lot of power? You don't. You can't tell from watching the video because there's no power meter anywhere. Poppet valves represent a significant amount of reciprocating mass in an engine, they have a lot of kinetic energy since they move so quickly, and a pneumatic actuator has no means of recovering any of that. Cams only have frictional losses, if you can control the friction then you don't lose that much power. Again, this system is definitely better in every single way except power consumption. At high engine speed cams have extremely significant friction losses, but at low engine speeds the acceleration of the valves is much lower, and it's likely that these pneumatic valves are consuming more power. At higher torque levels as well, increasing lift means compressing valve springs more and thus losing more power. In a typical car where you don't use high load or high speed often cams probably use less energy (but make the engine run worse, so you'd have to compare specific engines to be able to say which system works better). |
#153 |
Not recommended to drive up a hill over 6k rpm with a 2012 build date FRZ, I found out the hard way. Anyway its just odd to require a downshift over 4k rpm in a sports car. Regardless quirks like these keep the FA20 off the best 2L ever produced list. Not a bad engine but not on a best of all time list. Times are tough with corp goals to meet current and upcoming emission/economy regs, sacrifices were made imho. But hopefully tuning and catless headers can undo these sacrifices.
#154 | ||
Drives: '23 BRZ
Power required to drive a conventional valvetrain at, say, 7000rpm is not going to be insignificant... |
| New rumor: 1.6-liter turbocharged engine one year after initial introduction | Clode | Scion FR-S / Toyota 86 GT86 General Forum | 208 | 12-16-2016 08:14 PM |
| Frs not being produced in auto? | camelflage | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 04-17-2013 09:50 AM |
| VR6 engines... | dem00n | Other Vehicles & General Automotive Discussions | 29 | 01-25-2013 02:41 AM |
| 100 hp/l NA engines | einzlr | Other Vehicles & General Automotive Discussions | 95 | 11-15-2012 08:55 PM |
| So you think you know engines? | Ryephile | Other Vehicles & General Automotive Discussions | 43 | 02-04-2012 04:49 AM |
