| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Great install. Got one going on our silver car.
#16 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Fantastic write up as always Victor. Hmmmm maybe I should have tried this myself..
[CENTER]
Build thread |
#17 |
Drives: MY11 Maxima 350st, MY15 BRZ
Great article! I assume the total portrayed by the scale includes the wooden plank so the weight difference between the two is not quite as great?
#18 | |
Metric Units here..
![]() Also the weight difference between the two is around half(as stated) I just calculated it(I'm working out my own personal weight loss regime for my car atm - I'm bored): STOCK: 11.181035kg CF DSS: 5.599032kg
[CENTER]
Build thread |
| The Following User Says Thank You to stevo_12v For This Useful Post: | Mim (07-24-2013) |
#19 |
This is certainly one of the mods I'm looking forward to myself, once I finally get my own 86. I like the idea of reducing drive train power loss and improving the underlying performance prior to upgrading power.
Lighter 17x8 rims, brace kit, cf drive shaft, lighter pulley kit and diff ratio are the first mods I'd likely make. |
#20 |
Just wanted to say thanks to Victor for stopping by the shop and taking some pictures. I think we were each able to knock out the work that needed to get done to our vehicles.
#21 |
Just a dude
Drives: Scion FR-S 2013
Now you've had this for awhile can you comment on thoughts of performance and NVH and so on please? Very curious to hear as I am doing mine soon as well. I know some fellows with the aluminum ones have commented on increased NVH or vibrations and having to turn 90-180 degrees on back plate to rid of and wondering if there are any concerns on the CF version?
| The Following User Says Thank You to OICU812 For This Useful Post: | pjpetrozelli (12-25-2013) |
#22 |
Drives: 2013 Scion FR-S Raven
How much fluid will leak from an Automatic Transmission during this conversion?
How do you refill?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#23 | |||
#24 |
Drives: Challenger R/T, CRX SI,
A few in car videos of the l aluminum DS noise would be awesome. On a car without headers and has at least one cat. :P
#25 |
Drives: 2013 Scion FR-S Firestorm
#26 |
Boosted
Drives: Not a supra....yet
#27 |
8SiX
Drives: FRS 10series
Does that collar (or whatever that piece is that bolts in the middle of transmission tunnel) offer any structural advantage to the chassis? Should you reinstall something to bridge that gap, that was once bolted together with the stock drive shaft?
#28 |
I don't see why it couldn't hurt to add a brace. Just have to get one made. I don't notice any negative side effects at the moment.
| Tags |
| diy, driveshaft, driveshaft shop, dss |
| Driveshaft Shop Carbon Fiber Shafts Explained | Driveshaft Shop | Engine, Exhaust, Transmission | 121 | 11-17-2017 12:57 PM |
| Driveshaft Shop Axles & Upgrades for Scion FR-S!! MVP Motorsports | RobertatMVP | Transmission and Driveline | 39 | 07-11-2014 02:48 PM |
| Driveshaft on a DD FRS | Bullnettles | Engine, Exhaust, Transmission | 31 | 10-06-2013 02:22 PM |
| The Driveshaft Shop Custom Axles and Shafts | Sportsguy83 | Engine, Exhaust, Transmission | 26 | 01-11-2013 05:55 PM |
| Automatic Carbon Fiber Driveshaft? Yes! | RallySport Direct | Engine, Exhaust, Transmission | 13 | 12-15-2012 01:40 AM |
