Old 11-14-2013, 12:16 AM   #85
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
They need to replace the shitty brass synchros with carbon fiber synchros.
Muaddib is offline   Reply With Quote
Old 05-10-2014, 05:47 PM   #86
Paewrblue
Drives: BRZ WR Blue, E85, Fully modified.
I have this issue too when I drive around 100km/h in 6th and needs to downshift to 5th to overtake it would grind. But, if I drive at the lower speed such as 70-80km/h in 6th and downshift to 5th it wouldn't grind. I also do rev-matching or even heel and toe to make shifting goes smoothly still it doesn't work. This problem occured to me a week ago, after getting my 10,000km maintenance at the local Subaru Dealer.
I guess, I should take my car to do some inspection for this issue before it leads to another big problem.
Is there any update to fix this issue yet ?
Paewrblue is offline   Reply With Quote
Old 05-12-2014, 01:56 PM   #87
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
That is exactly the problem I had on my first tranny.
My second one has 2nd and 3rd grind now so I will be trying Pentosin 75W-80 once I have dealer approval, and then if that doesn't work it will be time for another replacement.
As far as I know, there is still no fix (see links below).
Take yours in and get them to check the tranny fluid - it will have metal shavings in it and that will be the justification they need to replace it.
Good luck!
http://www.ft86club.com/forums/showthread.php?t=16604
http://www.ft86club.com/forums/showthread.php?t=61827
http://www.ft86club.com/forums/showthread.php?t=8437
http://www.ft86club.com/forums/showthread.php?t=31929
EL_to_TBD is offline   Reply With Quote
Old 05-24-2014, 12:37 AM   #88
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
any update on this? 6th gear on my car is starting to grind with 15,000 miles on it. Aftermarket clutch, Aftermarket fluid, short shifter, and bushing. I have to many modifications to take it back to the dealer for this kind of problem. Is it possible that I could buy the synchros and replace them myself?
Rocket.BRZ is offline   Reply With Quote
Old 05-24-2014, 12:54 AM   #89
sierra
Drives: Skoda Yeti DSG diesel 4x4
The danger might be that once the symptoms appear the oil is already contaminated and other damage has started?
With mine it was a 5th gear grind and they didn't hesitate to replace the gearbox under warranty, soon after those symptoms appeared. Less miles than yours, about 9000.
If replacing the syncros was a fix why would they fit a new box?
sierra is offline   Reply With Quote
Old 05-24-2014, 12:57 AM   #90
Rocket.BRZ
My guess is that they wanted to take the gearbox back for analysis. I wouldn't think a dealer is going to tear down and replace a synchro right in the shop for time and reliability sake. Quite possible damage may have been done but I don't believe subaru is going to take back my gearbox based on my circumstances.
Old 05-24-2014, 01:05 AM   #91
sierra
That's exactly what they did. The gearbox was shipped back to Japan.
I like to think they have modified future gearboxes based on that policy, which might mean any spares could be to a different spec and could upgrade repairs?
I would drop the oil first, to see what's in it, if anything?
Old 05-24-2014, 01:08 AM   #92
Rocket.BRZ
Ok ill order some new fluid. Drain the fluid and replace it. I know the first time I drained the transmission it had a small amount of metal shavings but that was from break in I would assume. If it does contain metal what should I do. Subaru won't take it back.
Old 05-24-2014, 01:44 AM   #93
sierra
I would stop driving it and get a good transmission specialist to pull the box out and strip it, based on the symptoms, to see what they find. It's a conventional box with old fashioned brass or phosphor bronze syncros I think? You might be able to upgrade them with something better?
Are you sure it's nothing to do with the clutch not releasing fully?
Old 05-24-2014, 09:24 AM   #94
Rocket.BRZ
If it was the clutch I would think it would grind in every gear not just 5th
Old 06-30-2014, 11:40 PM   #95
Rocket.BRZ
Hey guys I wanted to update that I switch from pentosin to redline with 1 quart of shockproof. 5th gear grind is completely gone and its shifts like butter.
Old 07-01-2014, 12:05 AM   #96
sierra
Was it 5th or 6th gear?
You might pass that on to Toyota and Subaru to try instead of changing gearboxes.
Old 07-01-2014, 12:08 AM   #97
Rocket.BRZ
5th gear. I have an aftermarket clutch and my car is supercharged so I don't believe they will work on it.
Old 07-01-2014, 12:25 AM   #98
sierra
I meant just for their information, as something that worked for you and could work for them.
Search this Thread:
Advanced Search
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 10:39 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 03:47 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 03:41 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
