Old 04-24-2014, 12:23 AM   #57
Fonzie517
Autocrosser
Drives: Asphalt 6-speed FR-S
I am not certain about using the LEDs as DRLs, because I had the dealership turn off the DRLs long before installing the 10 Series headlamps. The lights are controlled entirely by the stalk on the steering column. The only time the LEDs or HIDs turn on is when I turn the stalk 1 click and 2 clicks respectively.
Fonzie517 is offline   Reply With Quote
Old 05-04-2014, 11:20 AM   #58
FRSHunter
Drives: Asphalt FRS
Sounds like 10 series headlights would have to remove the parking + on the FRS body side and replace with a custom wire from the DRL + up to both headlights where the white wire (LED Strip) is to achieve DRL functionality, but lose parking led light.
FRSHunter is offline   Reply With Quote
Old 05-10-2014, 01:47 AM   #59
FRSHunter
Drives: Asphalt FRS
Anyone found a way to wire up the 6 pin 10 series headlights for full functionality + the DRL? Simply rewiring the 6 pins will not give drl functionality, but instead it will function like the JDM 86 where they have no drls. As seen as in this video
[ame="https://www.youtube.com/watch?v=aIaY7hOk0CM"]https://www.youtube.com/watch?v=aIaY7hOk0CM[/ame]
As far as I know: JDM = 6 pin no drl, LEDs turn on with Lowbeam HID (LED pin = weaker led wire available)
USDM = 6 pin with DRL, LEDS do not turn on with Lowbeam HID (LED pin = stronger led wire available)
Europe Spec = 7 pin with DRL, LEDS also turn on with lowbeam (Has both LED pins thus the 7 pins instead of 6)
Old 05-10-2014, 05:54 AM   #60
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Here you go
http://www.ft86club.com/forums/showthread.php?t=44066
N1rve
Old 05-10-2014, 06:04 AM   #61
FRSHunter
Drives: Asphalt FRS
Thanks, but I think it might be different for non 10 series frs with 10 series headlights
Old 05-27-2014, 04:20 PM   #62
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
I just picked up a set of 10 series lights. I previously had the dealer turn the daytime running lights off with techstream also.
Am I correct in that the LED strip is the daytime light and comes on when you put the lights up one click. When you turn the headlights on the LED strip turns off?
jadewbj is offline   Reply With Quote
Old 05-27-2014, 10:00 PM   #63
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
The led strip will stay on with one click (parking mode) and two clicks (low beam). The led strip will not function as a true drl. Make sure you unplug the drl resistor when installing the lights. You got it disabled but best to be safe than sorry. Can fry your new headlights.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
The Following 2 Users Say Thank You to Calavera For This Useful Post:
Fonzie517 (05-29-2014), jadewbj (05-29-2014)
Old 05-27-2014, 10:08 PM   #64
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Is it easier to get a set of 10 series lights from the dealer now? Have not checked on it recently.
AVodka14 is offline   Reply With Quote
Old 05-27-2014, 11:11 PM   #65
Calavera
Calavera's Avatar
Online it is. Dealers might be too since monograms have them as well. Still pricey I think
The Following User Says Thank You to Calavera For This Useful Post:
AVodka14 (05-27-2014)
Old 05-29-2014, 11:36 PM   #66
Fonzie517
Autocrosser
Just the LEDs will turn on with one click, but they will stay on with the HIDs when you turn the stalk two clicks.
^^^What he said.^^^
Old 05-29-2014, 11:49 PM   #67
Fonzie517
Autocrosser
I had no issues purchasing 10 Series lights from the local Toyota dealer. I walked up to the parts counter, gave them the part numbers (SU003-04630 & SU003-04631), and they placed an order. At the time, there were none in the US, so I had to wait a few weeks, but as soon as they arrived, I got them with no questions asked.
They aren't cheap, but they are OEM HIDs, so that's to be expected. Winjets were not around when I made the decision, but even in hindsight, I'm glad I bought the factory units versus the replicas.
The Following User Says Thank You to Fonzie517 For This Useful Post:
AVodka14 (05-30-2014)
Old 07-10-2014, 12:21 PM   #68
jupillam
jupillam's Avatar
Drives: White out Scion Frs
What color wire from the headlight that need to tap to the 12v resistor line? to get DRL running constantly?
THanks
jupillam is offline   Reply With Quote
Old 07-10-2014, 10:35 PM   #69
iniguez310
Cool Guy
THanks
It's not on there bro. The 12v wire coming from the DRL resistor goes to the white wire coming from the headlight assy
iniguez310 is offline   Reply With Quote
Old 01-10-2015, 07:32 PM   #70
Brofessor
Drives: 2015 Halo FR-S
So the standard 6 pin harness doesn't physically fit into the 8 pin harness size-wise at all - I'm confused about how re-pinning it will work? Wouldn't you have to also buy an 8 pin harness? Sorry if I'm just having a dense moment here.
Brofessor is offline   Reply With Quote
Search this Thread:
Advanced Search
WTT: FR-S headlamps for BRZ Nothing Southeast 2 03-30-2013 07:41 AM
Auto-Off Headlamps nktech Scion FR-S / Toyota 86 GT86 General Forum 12 12-10-2012 10:51 AM
Purple/Blue headlamps BMWDavid Other Vehicles & General Automotive Discussions 0 11-24-2012 02:40 PM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:08 PM
limited 86 headlamps SuperDave FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 08-04-2012 04:41 AM
