Old 09-14-2013, 03:14 PM   #43
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
So I may have a dumb question, but do the LED strips stay lit then at night? Do they receive constant power or do they still turn off when the headlights are turned on?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 09-14-2013, 04:11 PM   #44
DC-FRS
Drives: Whiteout FR-S
Not sure if JDM/EDM/10Series are the same across the board but mine which are the 10Series version are constant power. they are like this:
DRL: LED Strip
Low Beams(Just turning headlights on): HID (Low) with LED Strip on too.
High beams: HID (High) with LED strip on too.
DC-FRS is offline   Reply With Quote
The Following User Says Thank You to DC-FRS For This Useful Post:
MemphisR (09-15-2013)
Old 09-14-2013, 07:46 PM   #45
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by DC-FRS View Post
Same as GT86 wiring except for the green wire in this DIY is a white wire on the 10 series light. And theres no 7th wire to splice into the resistor plug. SUper easy. Did mine last night in about an hour!
Attachment 51367
Attachment 51368
Gotcha. Is there a leveling switch? Is access to the 10 series lights easier now?
AVodka14 is offline   Reply With Quote
Old 11-28-2013, 12:01 AM   #46
Fonzie517
Autocrosser
Drives: Asphalt 6-speed FR-S
I'm installing 10 Series headlights and I'm curious about the resistor y'all are taping into. The 10 Series lights only have 6 wires, not the extra 7th wire. Do I still need to remove the resistor or should it remain plugged in?
Fonzie517 is offline   Reply With Quote
Old 12-27-2013, 08:23 PM   #47
Memento
Memento's Avatar
Drives: 2013 Whiteout Scion FR-S
That is a good question, I actually I'm trying to figure out the same thing.
I got my hands on the series 10 headlamps and am trying to figure what wiring I need to buy to get them installed and how to properly do it!
Memento is offline   Reply With Quote
Old 12-27-2013, 08:35 PM   #48
Fonzie517
Autocrosser
The 10 Series lights are a breeze to install compared to the Euro/JDM lights. You just repin the six wires from the 10 Series headlight into your factory plug(taken from your stock headlights) and that mates with the body control side. Don't worry about the 7th wire mentioned, but do remove the large resistor as instructed. You shouldn't need anything other than what comes in the box with the headlights from Toyota and what came installed on your car from the factory.
Old 12-27-2013, 08:51 PM   #49
Memento
Memento's Avatar
Awesome this is starting to make more sense. The only thing the box from Toyota is the actually headlamp, no wiring what so ever. Is that correct?
As you can tell i don't know my way around car electronics lol, every little bit helps!
Old 12-28-2013, 10:20 PM   #50
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
Yes, just the headlights come in the box. get these bro. you will be glad you did and please DISCONNECT the resistor behind the bumper by the passenger head.
http://www.ft86club.com/forums/showthread.php?t=53493
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
The Following User Says Thank You to Calavera For This Useful Post:
DeOppressorLiber (12-31-2013)
Old 12-28-2013, 10:25 PM   #51
Memento
Memento's Avatar
haha I already ordered it! He is making a set for me right now!
The Following 2 Users Say Thank You to Memento For This Useful Post:
Calavera (12-28-2013), DeOppressorLiber (12-31-2013)
Old 12-28-2013, 10:28 PM   #52
Calavera
Calavera's Avatar
You will be pleased with how your ride will look. Now get ready for everyone to ask you, "are those Winjets bro?!" lol if i hear that one more time i will
Old 12-28-2013, 11:30 PM   #53
Memento
Memento's Avatar
GTFOWINJETBRUH
Old 04-22-2014, 04:25 AM   #54
FRSHunter
Drives: Asphalt FRS
If you only pin the 6 wires without pinning the live 12v wire from where the resistor normally plugs into, how are you getting DRL functionality? I could only see the LED's turning on with Parking Lights, Low beams, and High beams since those are the Live wires and Ground Wires for the 6 pins.
FRSHunter is offline   Reply With Quote
Old 04-23-2014, 01:54 AM   #55
kincito
Drives: Raven FRS
I just installed the 10 series headlights into my car and you do need the white wire tapped into the 12v positive side of the drl resistor harness to get the drl led strip to light up. I just made the mistake to simply repin the 6 into the frs plug and the led strip drl did not come on.
kincito is offline   Reply With Quote
Old 04-23-2014, 01:59 AM   #56
FRSHunter
Drives: Asphalt FRS
If you simply just repin the 6 wires the LED's would only turn on with parking lights correct?
Search this Thread:
Advanced Search
WTT: FR-S headlamps for BRZ Nothing Southeast 2 03-30-2013 07:41 AM
Auto-Off Headlamps nktech Scion FR-S / Toyota 86 GT86 General Forum 12 12-10-2012 10:51 AM
Purple/Blue headlamps BMWDavid Other Vehicles & General Automotive Discussions 0 11-24-2012 02:40 PM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:08 PM
limited 86 headlamps SuperDave FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 08-04-2012 04:41 AM
