#575 | |
Drives: 2013 FR-S Matte Orange
There's already a BOV on this kit. It recircs though
#576 |
Drives: 2013 Hot Lava FR-S 6 MT
Jesus ... Where is my mind ... Ive only read that a million times ... Sorry!
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#577 | |
I have mine. Just give them a shout. They should have them. Not required for the install so hurry up already and install. Make sure to read my notes in the owners topic to make things easier.
#578 |
Yup I just went thru your notes and I have two more issues so far. The rotrex is cocked the wrong way like yours was and I dont think an installation manual/instructions came with my kit. I went thru the rotrex manual and it said something about voiding the warranty if you open it, so fixing the issue will void the warranty if I do it myself? I emailed them about but I'm still waiting for a reply. Where did you find the instructions for fixing the rotrex?
BeastCoast.US feature http://beastcoast.us/2013/11/28/all-the-right-moves/
Build Thread http://www.ft86club.com/forums/showthread.php?t=8204 ![]() |
#579 | |
| The Following User Says Thank You to digital_assassin For This Useful Post: | PRORICAN (01-21-2014) |
#580 |
Thanks! Also did your kit come with installation instructions? Mine didn't unless I missed it.
#581 | |
#582 |
Drives: 2013 BRZ, WRB
Looking over the compressor maps, I'm puzzled as to why anyone is even messing with the C30-94. The C38-61 appears to do everything the C30-94 does, with greater peak efficiency, broader optimums and a fair bit more headroom.
The surge limit is hardly any different at all. It's hard to tell from the maps, but the smaller blower might be better at reduced rpm (say half of whatever you choose for your redline condition). ![]()
| The Following User Says Thank You to Ralph Spoilsport For This Useful Post: | OjiGeorge (01-25-2014) |
#583 |
Drives: White 2013 FRS
Looking at those maps, I agree... C38 appears to be the way to go. Having that extra headroom down the road would be very nice indeed.
#584 |
Indeed! Using a few pieces of information (the C-30 makes 10psi at 93k rpm) we can tell that our little FA20 works through about 0.37 kg/s of air at redline.
You could rig up a C-38 to move 0.37 kg/s of air for your 1.7 pressure ratio (i.e. make 10psi at 7400rpm) but it would only be spinning about 72k rpm. That seems great until you realize that you have no usable boost until 3000 rpm when the blower finally speeds up to its minimum 30k impeller speed. In fact, the car is slower than stock below 3000rpm due to parasitic loss and does not match the compression of the C-30 until 5000rpm. You could rig up the C-38 to start making usable boost at 2000 rpm like the C-30 does, but then you would be over-spinning the impeller by the time you were at 5800 rpm. You could rig up the C-38 to redline at the same time as your engine. It would still only make usable boost at 2400rpm but that's not too shabby. Then, when you were at 7400 rpm you would have 26psi blowing you up. This is probably why Kraftwerks and Jackson have both stated multiple times that the C-38 is only going to be a viable choice for well-built engines. |
#585 | |
). My rough rule of thumb from tuning awd turbo Scoobies is 1 WHP per g/s of airflow. The twins have rather lower drive train losses, so let's guesstimate (in the absence of dyno logs) 1.1. For 300 RWHP, that suggests airflow around 0.272 kg/sec, so I think the range of interest for street guys at peak power is going to be in the 0.25 - 0.3 kg/sec range.From this and the known maximum impeller speeds on the current C30 kits, we can infer that the pressure ratio at the blower is closer to 2.3, due to some combination of intake, intercooler and plumbing losses (or, curse my curmudgeonly thoughts, optimism in the map). Picking the max pressure / mass flow point on the C38 map at 2.4 / 300 g/s tells us we need 80k rpm at the impeller at redline. So at half of redline, you'll get (ballpark) 1.2 PR at the blower and something a little less than this at the manifold. Doing the same "analysis" on the C30 shows me that we might expect as much as 1.3 PR at half of redline, but there's enough Kentucky windage on all this handwaving that I don't think we'll know for sure how a C38 system works in the real world until someone builds one. Probably, there's enough difference to show up on a dyno and probably there's enough difference to say "C30 is better for street", but it looks to me as though the difference might be small. I'm certainly interested to find out. Last edited by Ralph Spoilsport; 01-26-2014 at 01:15 PM. |
| The Following User Says Thank You to Ralph Spoilsport For This Useful Post: | kroyoftheempire (01-26-2014) |
#586 |
#587 |
#588 |
#1819
Drives: Lightning Red Subaru BRZ
I tried searching. Is this thing CARB legal? Thanks
| [TX] DFW General Discussion | feedbag | Southwest | 1488 | 06-18-2022 08:25 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 04:28 PM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 06:57 PM |
| Rotrex kit - why no build? | MindtheGap | Engine, Exhaust, Transmission | 5 | 10-26-2012 08:01 PM |
