#16 |
LMGTFY
Drives: 13 FRS, 91 Miata
The more I read the more it sounds like the shop doesn't know what they are doing.
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Hyper4mance2k (04-06-2018), Tristor (04-19-2018) |
#17 | |
![]() right now u r a) removing the helper spring to counter act the effect of the added stack height by ur camber plates since its not going as low as u would like b) by removing the helper spring, the main spring is now too short to be properly preloaded thus going to the max height setting c) by the sounds of things, u are essentially loosing a lot of suspension travel just to get the ride height u want id suggest u get proper camber plates and correct the preload/height settings according to KW recommended settings to fully take advantage of the KW V3, or get another coilover setup that is meant to slam ur vehicle at the sacrifice of handling performance. KW V3s are not meant to be slammed. |
| The Following 3 Users Say Thank You to TOPEC For This Useful Post: |
#18 |
Upper mounts came today, put them together. Here's a picture of what they look like set to 25mm drop rear and 28mm drop front (based on measurements for highest recommended setting, which is 20mm drop). There's definitely no pre-load on the rear main springs, and only a tiny bit on the fronts. With the front adjustment all the way down there was still room to compress the helpers more (I adjusted it all the way down to make it easier to get the mounts on properly).
#19 | |
Drives: 2013 Raven FR-S
#20 | |
http://www.kwsuspensions.com/extras/...Q/35258004.pdf It states the max distance between upper knuckle hole and spring perch is 95mm, and the other specs say the minimum drop is 20 mm. I went with 87mm from upper knuckle hole to spring perch. Not sure if the T2's have the same length helper spring, but if it's thinner then you'd be lower at the same perch height. All that said, on the higher resolution image I count 16 threads.
#21 | |
The T2 springs are much stiffer than the V3, not sure if the length is different but assuming the spring length is the same the car (w/ T2) will sit higher with the same spring perch location, same helper, and same top hat. |
| Guys/Gals who installed KWV3 install these washers? | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-14-2013 02:35 AM |
| Best way to remove OEM struts/springs | taimysho0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 06-07-2013 04:21 PM |
| will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 11:41 PM |
| Question for HOUSTON Fr-s owners and/or to be owners | enjoi23 | Southeast | 2 | 08-30-2012 10:48 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 04:12 AM |
