Member's Car Journals Car journals by our members. |
06-16-2013, 05:47 PM | #1 |
Drives: Asphalt Scion FR-S
JDKane's Asphalt FR-S
Engine: AFE Takeda Intake Delicious Tuning Flex Fuel Stg2 tune Jackson Racing oil cooler JDL radiator shroud PPE Engineering long tube EL header Raceseng Cam Plate Radium Engineering PCV oil catch can Radium Engineering ECU Bracket Shorai lithium battery STI AC delete Tanabe Medallion Touring CBE TRD oil sensor plate for temperature and pressure Drivetrain: Cusco engine mounts Kartboy transmission insert MTec clutch pedal spring MTec shifter springs MTec stainless steel clutch line Subaru 3/4" clutch slave TMW shifter carrier bushings Verus clutch bell cover Verus clutch fork Verus clutch pivot Whiteline KDT925 differential mount inserts Chassis and Suspension: Battleversion rear subframe inserts KW V3 Clubsports Turn In Concepts solid steering rack bushings TRD front strut brace TRD door stabilizer Brakes: Endless MX72 pads Perrin master cylinder brace Project Mu HC800 pads Stoptech stainless steel brake lines Tires: Bridgestone RE-71r 245/40/17 WedsSports TC105n 17x9 +35 Exterior: JDM underpanels Verus front splitter Verus rear spats Verus transmission tunnel cover Fluids: Motul Gear 300 ProjectMu brake fluid I don't have any high quality pics from Day 1, but these are the earliest. IMG_4507 by jdkane527, on Flickr IMG_4515 by jdkane527, on Flickr IMG_4495 by jdkane527, on Flickr IMG_4519 by jdkane527, on Flick Update December 21, 2013 (24k miles) Got corner balanced and alignment at West End. Alignment specs for camber were -2.5 deg for front, and without adjustments in the rear, -2.5/-2.7 (left/right) Toe was 0 in front, and rear 3/32" total toe in Update April 2, 2014 (29k miles) Started having condensation in driver side front headlight and rear tail lamp assemblies. Also installed TRD Quick Shifter kit. Retained the Perrin rear shifter bushing from earlier, and it is a little notchy, but over time should loosen up. I will be replacing the transmission fluid shortly, so that should help. Here is a pic of the current frankenstein intake setup: HKS Snorkel to Blitz drop in filter to Perrin inlet tube. HKS Intake Duct Installation by jdkane527, on Flickr Update March 6, 2015 (45k miles) Engine blew on February 13, 2014. Was experiencing rod knock so I towed the car to Longo Toyota. They were able to get it started and noted a lot of smoke coming out of the exhaust. Shortly after the engine seized. They're rebuilding the engine under warranty. So far they noted blown piston rings and broken connecting rod. Had to order a replacement short block and heads are off at the machine shop. Pics of the engine are in the latest post.
06-16-2013, 05:48 PM | #2 |
The shifter springs that MTec offers should have come in the transmission from the factory. During install, honestly could not tell the difference between the oem spring and MTec one by feel. Visually, they're different colors so that gives it away. Once it was installed, pulling left or right felt a lot stiffer, and once it goes into gear feels very solid. Overall another great modification to improve the feel of the car. The install guide they have is really straight forward and can be viewed here:
http://www.mtecind.com/diy/scion-frs...pring-install/ The painted spring was the one removed from the transmission. The new springs were just black. IMG_4970 by jdkane527, on Flickr IMG_4977 by jdkane527, on Flickr I purchased the SS clutch line as it was less than the other ones available, and I wanted to flush the fluid anyways. IMG_4986 by jdkane527, on Flickr
06-16-2013, 05:50 PM | #3 |
With the concern of oil temps getting out of hand during the summer, I invested in the Defi oil temp gauge to better monitor it to determine the necessity for oil cooling. I installed it with the ATI vent adapter from Rallysportdirect and got the gauge and oil temp sensor adapter from Micro Image. Following the Rallysport DIY, it was a breeze to tap into the wires and have it light up with the cluster lights. When the cluster is off, the oil temp gauge is bright red, but when you turn the lights on via the stalk, the red dims. It helps at night. Video of day/night transition can be viewed here:
http://www.flickr.com/photos/92964523@N02/9062161996/ 2013-06-02 18.11.16 by jdkane527, on Flickr 2013-06-05 00.12.00 by jdkane527, on Flickr 2013-06-05 00.12.15 by jdkane527, on Flickr 2013-06-05 00.12.15 by jdkane527, on Flickr
The Following User Says Thank You to JDKane527 For This Useful Post: | TemeCal (06-17-2013) |
07-30-2013, 06:00 AM | #4 |
Just installed the MTec stainless steel brake lines with Endless MX72 pads. It was a good time to change the fluid since it was getting dirty as well.
They are priced in the middle of the market, and feel pretty solid. Time and mileage will tell though, and they carry a 3 year warranty. Excuse the cell phone pics, will snap pictures with a better camera in the day time to include in a review of the pads.
08-16-2013, 10:41 PM | #6 |
Unsprung Weight.
Drives: GBS BRZ, S70 T5, 2002 tii
Fight on!
08-17-2013, 04:37 PM | #7 |
Fight on fellow trojan! :happy0180: What year did you graduate?
08-17-2013, 05:50 PM | #8 | |
Unsprung Weight.
Your car looks great! |
12-11-2013, 02:31 AM | #9 |
Haven't posted to the thread in a while, got TC105ns, RS3s, KW Clubsport coilovers, and Cusco engine mounts since.
Here was a random snap I took today haha. Apologize for the dirty car, haven't been able to wash it since Buttonwillow this past weekend. Will wash the car this week and take better pictures. Random Snap by jdkane527, on Flickr
The Following User Says Thank You to JDKane527 For This Useful Post: | TemeCal (12-11-2013) |
12-22-2013, 03:19 AM | #10 |
Got corner balance and alignment at West End on Friday. Toe hadn't been adjusted since coilover install and was greatly corrected. Turn in has improved and rotation feels controllable.
Took it for a drive through the Malibu Canyons today, and will be going to Buttonwillow tomorrow.
12-22-2013, 08:31 PM | #11 | |
Drives: 86
The Following User Says Thank You to TemeCal For This Useful Post: | JDKane527 (12-22-2013) |
12-22-2013, 10:33 PM | #12 |
Thanks! I was able to shave 3 seconds off with only change being coilovers. The car settles faster, but I still need to get the damping tuned. I feel more confident with the setup, but need more practice to use it to the fullest.
The Following User Says Thank You to JDKane527 For This Useful Post: | TemeCal (12-23-2013) |
12-23-2013, 11:34 PM | #13 | |
Drives: Firestorm 6MT
12-24-2013, 09:16 PM | #14 |
I wasn't too happy with how the Perrin MCB setscrew marks the master cylinder.
Set screw marks by jdkane527, on Flickr I found the screw size to be M12x1.75 and 30mm long. Here is a link to the McMaster part: http://www.mcmaster.com/#92123a145/=pyd6lx Set screw comparison by jdkane527, on Flickr The McMaster set screw has a swivel head so it does not mark up the surface it is tightening against. One downside is that it is an alloy steel, and not stainless steel. Corrosion resistance isn't critical since I live in Southern California. The screw threaded up fine, and the end result: New set screw installed by jdkane527, on Flickr
Similar Threads | ||||
Asphalt Frs, | gusbarragan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 72 | 12-09-2016 12:12 AM |
FT/IL asphalt FR-S bumper for your asphalt BR-Z front cover | asphalt_fr-s | Exterior Parts (Aero, Lighting, Etc.) | 0 | 06-04-2013 10:34 AM |
Asphalt MT FR-S | Area51 | Cars for Sale/Trade | 1 | 05-14-2013 05:22 PM |
Got my Asphalt! | killa.sushi.robot | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 06-30-2012 01:02 PM |
Asphalt 6MT FR-S | Symbiont | Southern California | 22 | 06-06-2012 07:47 AM |
