| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: WRX
Commiting Blasphemy...I should know this
I am taking a BRZ on a driveway test today. Just out of curiosity, what would be the easiest and cheapest way to raise the car 1 inch?
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
To avoid bottoming out entering/exiting the driveway?
Move. You can always install some coilovers and raise the car 1" over stock, but it'll look dumb. Not cheap, though. If your driveway is a rolled curb/gutter you can buy this junk: ![]() problem solved.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
Drives: 2010 BMW M3, 2013 Subaru BRZ
Stock height you can angle anything and be fine... I am fine even with a 1 1/2 - 2 inch drop.
NASA SpecE30 Racer
The easiest way would be not buy the BRZ and stick with the WRX. As mentioned, at stock ride height I never found a driveway that I couldn't get up without scraping if taking it at the proper angle.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: 2013 Subaru BRZ Limited LR
Put 18's on it? (I think it comes with 17's ?)
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
My work entrance has a steep incline that is all gouged up from cars scraping. My BRZ can tackle it straight on no problem. My '03 WRX wagon with a softer stock suspension (and a bolt on rally innovations bar) will scrape if I go too fast head on (ie 6mph instead of 3).
If you can angle, you should be fine in most cases. I angle over speed bumps - not bc it doesn't clear, but bc when both wheels on the same axle drop at the same time, there's more suspension compression and it can "thunk" if you go too fast (ie 3mph vs 1!). OP - are you looking to ride 1" taller all the time, or just negotiating one entrance? Solution could be as mentioned to put ramps over that extrance, or a more complex solution might be some sort of air bag suspension that would allow you to raise and lower your car on command. (Not sure if they make it for our cars or how they affect handling.) |
#1362
Drives: 2014 Ice Silver WRX
back in, assuming it's a driveway lol.
Senor Member
Drives: ME CRAZY
get bigger tires
Drives: BRZ(sold), STI
Drive in with a lot of speed, brake hard, release just before the kink so that suspension unloads just as you go over it
![]() Seriously though, you're gonna be fine. |
#10 |
Drives: Silica BRZ 6MT
You could try backing in depending on what your parking situation is...you may want to get a back=up cam but it'd be better than raising the height.
#11 |
Drives: Subaru BRZ LT
Need pictures to properly asses.
| The Following User Says Thank You to DantKR For This Useful Post: | Squishy86 (06-16-2013) |
#12 |
#13 |
Drives: 2013 FR-S Ultramarine
All this talk about wheels... You're supposed to compensate for the wheel diameter by changing the sidewall height so that the speedo doesn't change. If what you want is more clearance changing the wheel size is the wrong way to do it.
#14 |
Drives: Slowww
Raise the car more... oh lordd
| Blasphemy! I know, but I need some help! | slizoth | BRZ First-Gen (2012+) — General Topics | 9 | 08-14-2012 03:45 PM |
