Old 08-22-2013, 07:20 PM   #43
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Hm, might have to put the Raybestos on the consideration list, as I was planning on Cobalts for the next set.
Where are you getting yours from?
smbstyle is offline   Reply With Quote
Old 08-22-2013, 07:53 PM   #44
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I've seen the same with the DTCs...
Your description of the Raybestos sounds almost exactly like my favorite pad.
However, from scouring the interweb, I cannot find that Raybestos cuts this pad in the D929/D1539 backing plate (BRZ/FRS/WRX)....yet
Sorry guys.
Doesn't mean it's not doable. You'd have to call a Raybestos (or retailer) and have the compound cut for your backing plate. That's actually what we had to do with the D373 plate (CRX) when we were originally sourcing them.
Give Raybestos a call and tell them you want to try their pad and making the pads available for the BRZ/FRS/2008+ WRX would be a good business decision.
http://www.raybestosbrakes.com/magno...e/contact.html
They can also get info about the power/weight/tire of your car and recommend the right compound. The ST43 might be ideal, or maybe the 45s, with 42's in the rear.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
CSG Mike (08-22-2013)
Old 08-22-2013, 10:23 PM   #45
SpeedLab
Drives: White
Yowzas! - $400 dollars?!?!
SpeedLab is offline   Reply With Quote
Old 08-23-2013, 01:01 AM   #46
Anaxilus
Drives: They have four wheels
Would be nice if they price pieces that could be sold separately. Atm, only the sealed back plate catches my attention.
Anaxilus is offline   Reply With Quote
Old 08-23-2013, 09:15 AM   #47
SpeedLab
Drives: White
These weren't always this pricey - Quantum Ducts - http://www.lapponline.com/index.php?...roducts_id=186
My guess is they have something that would fit with minor modification. I believe they used to be $65 or so.
With the right plates, you should be able to put together something cheap:
Backing plates - Pre-made: ~$90ish
DIY backing plates (use flanges, cut a hole in stock dust cover -
$40 - http://www.summitracing.com/parts/aaf-all42160
NACA duts - $17/each - http://www.summitracing.com/parts/hre-re206/overview/
From the looks of it, you can get away with using the cheaper ducting with a lower heat rating (Routing wouldn't be extremely close to high heat) - 120" for $52 - http://www.summitracing.com/parts/aaf-all42150
All in around $130 dollars for a DIY option.
The Following User Says Thank You to SpeedLab For This Useful Post:
swift996 (09-03-2013)
Old 08-23-2013, 09:42 AM   #48
smbstyle
smbstyle's Avatar
Honestly I thought the spindle plates would be the easy part before I purchased this kit, but take a close look at the area when you get the wheel off next time; the wheel speed sensor locating and wiring makes it extremely difficult to use a typical spindle duct.
The Following User Says Thank You to smbstyle For This Useful Post:
Touge Factory (08-23-2013)
Old 08-23-2013, 09:43 PM   #49
wparsons
wparsons's Avatar
Are the @Touge Factory spindle ducts available separately?
flickr
Old 09-03-2013, 10:51 AM   #50
ATL BRZ
Driving Coach
ATL BRZ's Avatar
The TF brake ducts fit perfectly with the Perrin Oil cooler kit for anyone wondering...
The Following User Says Thank You to ATL BRZ For This Useful Post:
Touge Factory (09-03-2013)
Old 09-03-2013, 11:27 AM   #51
swift996
swift996's Avatar
Shouldn't those fit the BRZ since they use the same rotors?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 09-03-2013, 11:41 AM   #52
smbstyle
smbstyle's Avatar
The wheel speed sensor location is the issue.
Old 09-03-2013, 12:46 PM   #53
SpeedLab
Drives: White
A little modification and anything can fit. Just need to be creative.
Sent from my Nexus 4 using Tapatalk 2
Because it didn't break does not mean it's track proven.
Old 09-03-2013, 01:46 PM   #54
smbstyle
smbstyle's Avatar
go for it! let me know how it works.
Old 09-26-2013, 02:02 PM   #55
rice_classic
Good news guys.. It looks like the ST43 and ST45 from Raybestos are now available for our cars!!! Go to Porterfield:
http://porterfield-brakes.com/search.php
SCCA T4 - FRS
Deep Six (09-28-2013)
Old 10-08-2013, 02:50 PM   #56
smbstyle
smbstyle's Avatar
Update:
So I now have 5 total track days on this setup (TF Brake Cooling Kit, OEM rotors, Ti-shims, Hawk DTC-60 pads, Motul RBF600 Fluid), 2 days at Barber and 3 days at Sebring, and here is how everything is looking so far.
OEM dust boots still look new, OEM rotors have the normal heat checking they did after the first day, and have not developed any large cracks or delamination. DTC-60 pads are wearing about 1.5/32" a day (front) and 0.5/32" day (rear).
Don't mind the rust looking crud built up on the calipers; just a result of running race pads in the rain, and didn't bother cleaning it off yet.
The Following 6 Users Say Thank You to smbstyle For This Useful Post:
Anthonytpt (01-24-2014), ATL BRZ (05-06-2014), clintavo (10-09-2013), normancw (02-21-2014), Pat (07-16-2014), Touge Factory (10-08-2013)
Search this Thread:
Advanced Search
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 08:01 AM
Wheel Directory: Vossen VVSCV3 19x8.5 +32 / 19x10.0 +36 mike@vossen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 106 01-18-2015 02:36 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 07:04 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 02:33 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 02:37 PM
