Old 04-28-2016, 01:50 AM   #309
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Originally Posted by FRSBRZGT86FAN View Post
Dude you're not listening or comprehending at all, you take that MODULE in the bottom and the gps antenna plugs into that and the wiring harness connects that module to the OEM head unit read the first post slowly.
Finally!! I got it. I was confused by the part# lol.
Things i need to do.
Buy those 3 items,GPS antenna, prius V module, and the wire harness.
Take off my oem module and replace prius V module,,plug this and that,,put it back on.
Right?
FR-Sky is offline   Reply With Quote
Old 04-28-2016, 02:27 AM   #310
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Right?
Correct on everything except the last part
Make sure you buy "3M DOUBLE SIDED VHB TAPE" otherwise you'll need to buy those C brackets, simply put the tape all over the side of the module without the stickers.
ALSO:
There won't be an OEM module, it just slides underneath the head unit follow the tutorial in the first post as well as this video ignore the repinning and wiring electrical stuff he says he's installing a rearview camera at the same time the module is plug and play no cutting or splicing:
[ame="https://www.youtube.com/watch?v=A1vH6DmfhZ0"]losmt2 - 2015 FR-S factory navigation module install - YouTube[/ame]
The module in question is used on all 2012-2015 Toyota vehicles for the most part, it was used with those head units to enable navigation and entune. That's the only difference between a car without navigation and one with navigation, it has that module, brackets and that antenna and harness
ALSO the purpose of buying the prius V head unit was specifically just to save you money, those head units are cheap as hell and are pretty common in several years of toyota vehicles, the problem is buying that module alone tends to cost a shit ton of money but the prius v head unit does not.
My post here elaborates more:
http://www.ft86club.com/forums/showp...&postcount=293
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
FR-Sky (04-28-2016)
Old 04-28-2016, 03:07 AM   #311
FR-Sky
FR-Sky's Avatar
In the video, there is the metal mounting plate, and looks like its holding pretty well.
why do I need 3M ?
Old 04-28-2016, 03:17 AM   #312
FRSBRZGT86FAN
why do I need 3M ?
I was assuming you weren't going to buy the mounting plates but here is where you can buy them like I did:
http://www.partznet.com/oe-toyota/pt59100140
use the coupon code partznet10 when you can
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
BabaYaga (02-11-2017), FR-Sky (04-28-2016)
Old 04-28-2016, 03:25 AM   #313
FR-Sky
FR-Sky's Avatar
thanks for super detail tutorial and explanation....
I wish i can give you 1000000000000 thanks....
p.S already contacted a few local craiglist for prius V module!
Old 04-28-2016, 03:32 AM   #314
FRSBRZGT86FAN
MAKE SUPER SURE IT HAS THE MODULE:
You are looking for the module on the bottom that I circled with the numbers 9 10 and 11, the ebay link I sent you had the incorrect version:
AGAIN
The module is that lower portion with 3 circles labeled 9 10 and 11
MAKE SURE IT HAS THAT AND DON'T BUY IT OTHERWISE
THE MODULE ITSELF WILL LOOK LIKE THIS WHEN HEAD UNIT IS FLIPPED OVER:
http://www.ebay.com/itm/12-13-14-Toyota-CAMRY-SIENNA-PRIUS-RAV4-Bluetooth-Module-Gracenote-Extension-Box-/121360922829?hash=item1c41acb8cd:g:QAkAAOxyPKNTl0f 7&vxp=mtr
If you can't find it you should just buy the module from the above ebay link, that's been sitting there for a few months in fact it was up there since I did my install but I didn't buy it because I got the prius V module for cheap. If you're really interested hit up a local junkyard they may have prius head units and not much traffic from people so you should be able to get a deal for it.
OR MAKE AN OFFER ON THIS ONE ASAP!!!:
http://www.ebay.com/itm/12-13-14-15-...VW4Ym8&vxp=mtr
Also I'll place this info here I posted before:
Anyone wanting to do this mod should know the main module can be found in a lot of Toyota vehicles with the premium navigation or some sort of tech package WITHOUT THE JBL AUDIO PACKAGE from 2012-2014 in fact this is a list of all the used head units you can try to find that has this in there photos ask the ebay seller to take photos of all the sides of the head unit to confirm they have a harman unit with the part numbers PT296-47120, PT296-47130, PT296-47140:
2012 - 2014 Toyota 4Runner
2012 - 2014 Toyota Avalon
2012 - 2014 Toyota Camry(Including 2014.5)
2012 - 2014 Toyota Corolla
2012 - 2014 Toyota Highlander
2012 - 2014 Toyota Land Cruiser
2012 - 2014 Toyota Prius(Plug-in, Base, C, & V Models)
2012 - 2014 Toyota RAV4(Base and EV)
2012 - 2014 Toyota Sequoia
2012 - 2014 Toyota Sienna
2012 - 2014 Toyota Tacoma
2012 - 2014 Toyota Tundra
2012 - 2014 Toyota Venza
If anyone is interested these are the parts and prices most were bought from eBay only one item was purchased from Toyota dealership directly:
12 13 14 TOYOTA PRIUS RADIO CD NAVIGATION SCREEN MAPS GPS APPS HD TESTED F32#059
$180
TOYOTA CAR NAVIGATION UNITS GPS ANTENNA 09 <- requires trimming, no one has given a part number of the antenna that's OEM and doesn't require trimming, I look around and it seems very pricey somewhere in the range of $50-$200
This aftermarket one was $14.99
PT591-00140 Brackets
$15
PT296-47120-AB Wire Harness - needed to connect the navigation module to the head unit itself bought directly from Conicelli Toyota in Conshocken PA online at there website partznet.com
$29.62
The grand total is $241.56, much much much cheaper that just the module on eBay currently for around $400, and way way way less than buying it directly from Toyota for arounds $1000-$1200 depending where you're located.
Old 04-28-2016, 12:24 PM   #315
FR-Sky
FR-Sky's Avatar
are u sure this will work? cus i just make an offer!!!!
Old 06-12-2016, 02:26 PM   #316
chucho061910
chucho061910's Avatar
Drives: 2013 frs 10 series 2382
I bought everything and installed but it won't work. I have a 10 series frs with head unit pt546-00140 and bought navi pt296-47139. Got the gps antenna, harness and brackets but when I hit the map button still says need to go to dealer to upgrade need help
Sent from my SAMSUNG-SM-N920A using Tapatalk
chucho061910 is offline   Reply With Quote
Old 06-14-2016, 09:32 PM   #317
camelflage
Drives: pinto power
Put a 2014 touchscreen in my car today. Found a prius radio with nav for $100, so it and the brackets, harness, GPS antenna on the way.
How are people handling the vin issue for entune nowadays?
Sent from my HTC6500LVW using Tapatalk
camelflage is offline   Reply With Quote
Old 07-28-2016, 01:14 PM   #318
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
i tired to update mine but nothing happened. i followed the same steps as the website that was posted on here to download the file. I am not sure if it could be the usb port or what. I did notice that before when i had the original radio it worked but as soon as i swapped it out to the one everyone is switching them to it stopped working. any ideas? thanks
FRS-HHH is offline   Reply With Quote
Old 08-03-2016, 12:25 AM   #319
FRSBRZGT86FAN
Make sure the connector for the USB port is plugged into the module correctly
As for the VIN issue, that's the main reason I bought the prius V head unit to pull the module out of, most sellers on ebay sold them for $150 or lower and it came with the VIN number of the car it was pulled out of. So I simply plugged that vin number into the entune app.
Old 08-04-2016, 12:22 AM   #320
camelflage
Drives: pinto power
yeah, forgot to update, I used the vin from the prius head unit.
The Following User Says Thank You to camelflage For This Useful Post:
FRSBRZGT86FAN (08-04-2016)
Old 09-17-2016, 08:42 PM   #321
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
[QUOTE=FRSBRZGT86FAN;2719698]Make sure the connector for the USB port is plugged into the module correctly
i have pulled the usb out to check and it seems to be connected. i cant seem to reach to see if the dash itself is connected properly to the usb but from what i can see it is. i have put the usb in and nothing happens. i have followed the toyota instructions and no go.
Old 09-18-2016, 09:45 AM   #322
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
@FRS-HHH did you plug the usb wire into the radio or the Entune module? If it's the radio it won't work ! You must plug it into the entune module.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
New Scion Standard Radio for 2014 NedVargar Electronics | Audio | NAV | Infotainment 45 06-13-2013 10:00 PM
WTB: Pioneer Premium Audio radio/head unit tech4pdx Canada Classifieds 2 04-14-2013 08:31 PM
Sirus Radio on Stock head Unit wtout86 Electronics | Audio | NAV | Infotainment 3 11-20-2012 03:22 PM
Fitting the radio plug into aftermarket head unit GC GTS Aero Kit Electronics | Audio | NAV | Infotainment 1 10-29-2012 06:41 AM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 08:42 PM
