| View Poll Results: What F/E numbers are you seeing and why you think that it is what it is | |||
| Under 20mpg: I've yet to use a gear past 4th |
3 | 1.96% |
| 20~25: City driving / heavy foot |
37 | 24.18% |
| 25~30: I don't understand: I don't tach it out past 4k?! |
66 | 43.14% |
| 30~35: I enjoy the occasional fun, but usually I'm taking it easy |
44 | 28.76% |
| 35~40: Rule of 10's - 10 under the speed limit or 10' off the rear of a semi |
3 | 1.96% |
| Voters: 153. You may not vote on this poll | |||
#43 |
Drives: FR-S MT
How does not driving keep your MPG high? I understand if it was "hours per gallon".
#44 |
Drives: Scion FRS Ht Lva(AT)
The average mpg readout is resetable with press and hold. So if you have never reset it, it will show lifetime average and as such be less sensitive to very good or very poor occurances of FE.
I reset every tank, so I can get a better idea of how driving circumstances for that tank impact the observation on the readout and the calculation results from the tank fill. My lifetime is 7.6 l/100km(30.9mpusg) so far after 23 fills, worst tank was 9.33(25.3), best 5.0(47) based on tank fill calculations. Short trip city driving in winter produces the worst observations as would be expected. What I find questionable are the observation where folks consistently report 30-35mpusg MT with near 100% city driving, and foot to the floor! I suspect there may be very differing opinions on what folks consider to be city driving vs. highway driving. But I also believe MT has a little better city FE than the AT, while it is pretty much accepted that the AT is better on the hwy due to gearing. |
#45 | |
Drives: FR-S MT
I think there is something about the on-off nature of the dual fueling system that reduces mpg under the kind of rural/small town conditions you described. The system seems calibrated to flatten the torque curve, not to maximize mpg under conditions where you are changing gears and revolutions - even gradually. |
#46 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
#47 |
Drives: DGM BRZ 6MT
I think he meant that usually he does not drive to work, since the short driving commute would bring down his mpg, but drives other times
| The Following User Says Thank You to TM For This Useful Post: | Mister (06-16-2013) |
#48 |
Drives: Firestorm 6MT Scion FR-S
I'm pretty pleased with this, considering 80-90% city driving.
![]() 2013 Firestorm 6MT Scion FR-S |
#49 |
Drives: 2013 FRS
30.5 to about 33.0 mpg's ( taking I66 and I495 ) and the occsional back street's (hilly) on the way home at night.
Ive also use luca's #10576 Ethynol treatment and have been using it on all my vehicle's for the past 3 yr's and when I dont use it Ive seen my mileage drop. |
#50 | |
Drives: FR-S MT
#51 | |
Drives: 2013 FRS
If I forget to pour it in Im under 29 mpg's 1 ounce per 5 gallons ( usually 10.5-11 gallons per fill up ) Looking at my reciepht's from when I 1st got the car last june to now Im seeing 28.59-29.75 back last june-sept when I 1st got it and was breaking it in ( 1st manual ) and leaving rockville md during rush hour traffic at night . And from oct/november 2012 when my hours got changed to earlier in earlier out Im seeing 30.3 , 30.46 , 30.99 , 30.94 , 31.2 and a few 32.26 and way better when I go in at like 5am and and on 495 at about 2pm . Id say 31.0 to 31.5 is a baseline and I always have a pen and bottle of luca's stabilzer in the door pocket for water bottle's. Average tank range has been 355 , 363 , 359 Ive tried to get family to run the Luca's stuff but they seem to be lazy and when I ask them about the mileage there like duh! Last edited by kbi; 06-16-2013 at 05:14 PM. Reason: pricing |
#52 |
Drives: Firestorm FRS
It keeps it down because I avoid such short drive. If I drive to work every day at 0.8 miles in each direction, my gas mileage is horrible per tank. By biking/walking I save the car from such short drives and my MPG for a tank is considerably higher.
#53 |
Drives: Toyota FT/MT 86
Hi I'm really worried about fuel consumption on my new FT 86 , I'm in argentina. So this version it's the same as SCION FRS. I'm getting around 25 litres every 100km where it should be around 7.8 for every 100km .
I've got the manual version , am I driving badly. I enabled the G on feature which tells you the proper timing to shift the gears. I pressume I might have a bad batch. Can you guys help me out. I've already used a 1/4 of the fuel tank and I've done 30km max. What should I do? |
| Why isn't the fuel economy better? | White Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 495 | 10-28-2019 09:21 AM |
| First Hwy Run... Fuel Economy Report | PNW FRS | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 06-10-2013 11:04 PM |
| Fuel economy | ozne99 | BRZ First-Gen (2012+) -- General Topics | 48 | 12-11-2012 01:55 PM |
| Optimistic fuel economy? | nubbster927 | BRZ First-Gen (2012+) -- General Topics | 15 | 07-05-2012 09:50 PM |
| Fuel Economy | Lexicon101 | Engine, Exhaust, Transmission | 38 | 02-22-2010 04:50 PM |
