Drives: 2013 BRZ Limited - WRB, MT
FS: MacBook Pro 13inch mid 2010
Selling my mid 2010 13 inch macbook pro. It's in physically good condition minus a small blemish on one of the bottom corners and normal wear around the exterior
2.66ghz core2duo 4gb RAM full specs at http://support.apple.com/kb/SP583 - EDIT: pulled a hard drive cable out of a newer macbook pro at work and it now works fine. The hard drive is still good. - Battery holds approximately 75% of it's original capacity and recently showed "needs service" but no longer does when booted to an external drive with the OS installed - Power adapter works but sometimes the indicator light doesn't come on. There is no warranty Accepting offers Last edited by abutterman; 06-14-2013 at 06:03 PM. |
EDIT: fixed the hard drive issue. The hard drive was actually fine. it was the flex cable that went bad. I pulled one from a newer macbook pro and it works fine. the screw holes to secure it didnt line up but it's tucked under the hard drive itself anyway and it plugs in fine so it's now up and running.
#3 | |
Drives: 10 series FR-S & Matrix S
| 2008 Black MacBook | Trojan_SC | Miscellaneous | 6 | 07-11-2013 06:34 PM |
