go_a_way1
Old 05-08-2014, 06:41 AM   #1107
Originally Posted by solidONE View Post
You guys destroy brakes... Do you guys ramp up the brake pressure and trail off, or just stomp it then trail off entering turns?
I gradually increase and decrease brake pressure. Too little and too gradual, apparently. I've only managed to fade my stoptech pads once coming into the skidpad at SoW going CCW.... ONCE!
Always ramp up. Depending on the car, you have to trail off as your velocity decreases (aero).
solidONE (05-08-2014)
Old 05-08-2014, 03:00 PM   #1108
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
After having read about how Michellin PSS's, while great street tires, don't hold up well to track sessions, what would be a good street tire that holds up well and is reasonably good for standing up and running decently on the track?
I'm looking at doing the occassional track day every few months or so, say maybe 6 times a year or less. I'm an apartment dweller and don't exactly have room for a spare set of wheels/tires, and don't want tires that the track will wear out quickly b/c they don't handle track heat cycles well.
How well do Nitto NT05's perform in 225/45R17's on a 17x8 rim? Good tire for both track and DD/corner carving?
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Pokeguyjai (05-08-2014)
Old 05-08-2014, 03:06 PM   #1109
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I ran pss on my sti doing some very aggressive track days and didn't have any issues with premature wear. They wore better than most other street/track tires I've used over the years.
They also have great rain evacuation for the street.
Mike
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
Pokeguyjai (05-08-2014), SirBrass (05-08-2014)
Old 05-08-2014, 06:02 PM   #1110
ddeflyer
I am not really sure what the set of dynamics were, but on my PSS tires I thought they were really sticky at first and then not so much at the end of my second track day. I suspect it was from heat cycling them but I am not really sure. That day I got them greasy twice and then they didn't feel the same in the last session. I might also have just overheated them.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 05-08-2014, 06:38 PM   #1111
AZP Installs
Mike
Did about 8 track days on them and 20k miles, weren't worn and grip was acceptable for track use. They aren't Race Tires but for a dual purpose they were fine.
-mike
The Following User Says Thank You to AZP Installs For This Useful Post:
Old 05-08-2014, 06:41 PM   #1112
SirBrass
SirBrass's Avatar
-mike
Good to note. What about NT05s, just b/c I'm curious and have heard good things about them as both a street tire and a track tire.
Old 05-08-2014, 06:43 PM   #1113
AZP Installs
NT05 never really worked well on subies (not BRZ/FRS) in the past, they were great on my corvette buddy's cars but any subie guys I've seen at the track that had them said they weren't great.
-mike
Old 05-08-2014, 06:43 PM   #1114
Bridgestone RE11/RE11A, or Yokohama AD08R.
I'm not a fan of the NT05; they grease out early. They do, however, stay consistent once they grease out.
ATL BRZ (05-08-2014), SirBrass (05-09-2014)
Old 05-08-2014, 06:44 PM   #1115
You probably had a combination of getting used to the tire, and severely overheating the tire, damaging the remaining rubber.
Old 05-08-2014, 07:05 PM   #1116
ddeflyer
That would not surprise me. It was also the first time I ever got tires greasy (this was on my fifth ever track day, second in the BRZ).
The Following User Says Thank You to ddeflyer For This Useful Post:
CSG Mike (05-08-2014)
Old 05-08-2014, 07:06 PM   #1117
kavanagh
Fat on Corn Syrup
We have ~9k miles and 4 track days on our PSS and they're still good for probably another 8-9k and maybe 3-4 more track days.
I did however chunk them a bit on my first track day by not warming them up enough before trying to put power down out of the exits.
I wish I had something to compare them to, but I'll probably go with Mike's recommendation on the AD08R next time just to compare.
Here's after 4 track days
The Following 3 Users Say Thank You to kavanagh For This Useful Post:
CSG Mike (05-08-2014), SirBrass (05-11-2014), Tye300 (05-08-2014)
Old 05-08-2014, 09:54 PM   #1118
ddeflyer
I have AD08Rs now for my track tires (225/40R18 on 18x8.5 pf01 rims). So far I am liking them but between my skill change, rim change and now (very mild with only bolts) alignment change, I don't think I can comment on the difference between the tires. I am enjoying them though; I feel like I am getting quite a bit more traction out of them. One down side (could also have to do with the rims being 18 vs 17) is that they seem noisier than the PSS.
CSG Mike (05-09-2014)
Old 05-09-2014, 12:15 AM   #1119
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That "boogering up" of the rubber is pretty normal for track use isn't it? My RS-3 looked worse (more boogered up) than that after a day at buttonwillow.
Old 05-09-2014, 01:23 AM   #1120
kavanagh
Fat on Corn Syrup
Totally normal. This pic was actually taken after driving home from the track and then out to dinner, which removed a lot of the marbles that were there at the end of the track day.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) -- General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) -- General Topics 20 01-10-2012 10:54 AM
