#1009 | |
Drives: FR-S Whiteout
You MUST be a Jedi master... Will you adopt me? Note to self* I WILL throw away stop watch... I WILL buy hot cake I WILL slow down Track out Constant but shifting force No coasting Moar gas moar faster "Slow in, Fast Out" One section at a time Hit berms Don't pinch off corner Winner, winner, chicken dinner Thank you @CSG Mike and contributors for another excellent thread. Carry on sirs.
| The Following 3 Users Say Thank You to solidONE For This Useful Post: |
#1010 | |
![]() Everything he says makes sense and is what I have been trying to do, but unsuccessfully. I think I'm really going to have to slow it down significantly to practice the line first in order to figure it out. Getting the car straight enough for hard braking is the tough part. Your mind's instinct for self preservation is another part....
2013 Subaru BRZ
#1011 |
@CSG Mike, have you gone flat out through turn 4 at MRLS yourself? I guess it's possible if people can go through turn 8 at Thill flat out, but it takes some skill and balls.
Turn 4 is where everyone loses their car, so some caution is needed. Jeff, I would try turn 8 at thill flat out first before you try turn 4 at MRLS. Turn 8 at thill, IMO is easier to pull off
2013 Subaru BRZ
#1012 |
Drives: Some rust bucket
Any preference on metal or rubber valve stems?
Metal makes it easy to check tire pressure readings because it's stiff. However, metal seems more fragile as it could snap off. Not sure how that could happen though on the track. Rubber seems more durable as it allows some flexing but makes it harder to read tire pressures. |
#1013 |
Off Topic
If they're not hot by the time you get to the track, wrap them in aluminum foil and leave them on the intake manifold for a while.
| The Following User Says Thank You to gramicci101 For This Useful Post: | solidONE (05-01-2014) |
#1014 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
"If you're already not going where you want or need to go, why would you want to go there faster." Especially if in so doing you've already moved through anxiety and into fear, where the really bad choices get made when things begin to go pear-shaped. |
#1015 | |
Also, turn 8 at T-Hill is FUN! Really need to be steady to take that one at speed though because suspension loading is pretty important to staying in control. That said, T-Hill turn 9 is even more fun!
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | orthojoe (04-30-2014) |
#1016 | |
More than anything, it's just properly placing the car. Start by entering with just a lift, and then decrease the lift as you keep going. If you drop 2 exiting, don't try to save it; that's how people end up in the wall when they hook across. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | orthojoe (04-30-2014) |
#1017 | |
#1018 | |
2013 Subaru BRZ
#1019 | |
Drives: 2013 BRZ Ltd. MT
I found a site showing the laptimes at Laguna Seca. The top two times were set by Pobst and were a couple seconds slower than the Stiglet's time. Is the Stiglet's time a record? Do his tires (tyres in his case) make his time ineligible? In any case, that was an impressively quick lap. His accent alone is worth a bit of time, I would think.
#1020 | |
In the wet, it is a good idea to choose a higher gear than one would use in the dry; you'll probably be both quicker and safer. |
#1021 | |
Fastlap is for stock cars only |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Porsche (05-01-2014) |
#1022 | ||||||
![]() How old are you? Quote:
![]() We're just trying to help you see that there are other more useful ways of measuring progress in the beginning. Focusing on speed and the stopwatch results can actually IMPEDE your progress as a beginner. First get it done RIGHT. THEN try to do it right, progressively faster. I think you'll make better progress that way, and it is certainly much SAFER that way. You gotta live to tell about it, right? ![]() Quote:
From the apex onwards you want to be unwinding your steering while simultaneously feeding in more throttle. Remember: Your throttle is not a switch, not ON/OFF. ![]() When I want to go faster, I say to myself, "Smooooth it."
| The Following 4 Users Say Thank You to Porsche For This Useful Post: |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
