#4761 | |
Drives: White BRZ
Also I am considering a more track dedicated car for local tracks That is a little faster. VIR is an hour from my house and I will drive there more than anywhere else. What are good choices in the 15 to 20 range? I am looking at e46 m3, mustang gt, c5 corvette. I would like to have a well balanced car that won't kill me on wearables or kill me dead. Thanks Derek |
#4762 | |
Drives: Subaru BRZ
This may be a useful read. |
#4763 |
Drives: Track preped NA FRS
Im not Mike, or a driving instructor, Im just a guy who tracks a lot and likes to go fast. Anyways, seeing as you didnt get an answer to this, ideally you arent looking for even tire temps, you are looking for an even spread of temperatures with the inside hotter than the middle, which is then hotter than the outside. Say for exemple 180F inside, 170F middle and 160F outer when measuring with a probe pyro right after a hot session. So I would put those camber bolts in, since you will get more tire life AND faster times by doing so.
| The Following 4 Users Say Thank You to Icecreamtruk For This Useful Post: |
#4764 | |
Drives: Fr-s
I run in the 28-30 psi hot range.
| The Following 2 Users Say Thank You to redlined600 For This Useful Post: | strat61caster (10-05-2018), Takumi788 (10-05-2018) |
#4765 | |
The question is what's the best streetable track tire right now? It's been awhile since I've looked and I'm curious too, Hankook, Dunlop, Maxxis, Nitto, Michelin? |
| The Following User Says Thank You to strat61caster For This Useful Post: | Shark_Bait88 (10-05-2018) |
#4766 |
Drives: 2013 Firestorm FR-S
If you're aiming for a learning tire and participating in 86 Cup the SX2 is pretty solid. I also really enjoyed my ZII* when I had them. Help up well to being used for DD, autox, and HPDE. I'd imagine the RT615K+ wouldn't be bad either.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#4767 |
Drives: Fr-s
I think he's referring to the Hoosier R7, which is a race tire.
| The Following User Says Thank You to redlined600 For This Useful Post: | Takumi788 (10-05-2018) |
#4768 | |
Senior Misanthrope
Would definitely get them again, but I'll probably try the RS4s next. |
| The Following User Says Thank You to kch For This Useful Post: | strat61caster (10-05-2018) |
#4769 | |
JHerbert Racing
Drives: 2013 Scion FRS
I am a track guy but I love to autocross too.
#4770 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Surprisingly no one talks about Toyo RRs or R888R. I used both of them last year and liked it a fair bit. Consistent, durable (to heat cycles) and worth running for a season. Lutfy PS: Anyone coming to Summit for 86 cup?
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
| The Following 2 Users Say Thank You to lutfy For This Useful Post: | strat61caster (10-05-2018), Takumi788 (10-05-2018) |
#4771 | |
Oh btw, my new splitter completely solved my rear downforce problem, I even had to add quite a bit of angle back to balance it out. I dont know if you are allowed to do what I did, but if you are it will make your car faster for sure. |
#4772 | |
The R7 run wide, are lower hence better gearing. The RR fades a little after first few cycles (I ran them at Summit Point in Nov of last year sticker and they were still slower than used R7 but much easier to drive at the limit). I will have to test things out on my end too. I ran the rear wing pretty low and realized that my front splitter may be a touch pointing up (vs angled down for downforce duh!) will be toodling at Summit Point soon. Bottom line if everyone is on a similar tire and someone shows up with Hoosier's, R7 driver will take the crown Assuming similar level of competency/prep etc.Lutfy PS: BFG R1 are in the same league too BTW.
| The Following User Says Thank You to lutfy For This Useful Post: | Icecreamtruk (10-05-2018) |
#4773 | |||
Back on topic, I can't wait to hear what's out there these days, last I was paying attention the RS3 V2 was the best all-rounder for 200TW but with Hankook and Dunlop and Maxxis and Falken upping the ante and now that I care less about having a 200TW tire it'd be nice to know what the current ringer is. Quote:
![]() I've heard great things as well, I've got Firehawk Indy's as my current low grip tire, depending on where I spend car-time next year the next set might be closer to 200TW depending on price and performance. Last edited by strat61caster; 10-05-2018 at 05:17 PM. |
#4774 | |
Replacement OEM Sachs dampers can be found lightly used for very cheap! |
| The Following User Says Thank You to CSG Mike For This Useful Post: | nikitopo (09-11-2020) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
