#4481 |
Drives: Fr-s
Ha, you're right. I owned a Miata too long.
#4482 |
Driver
Drives: 2013 Whiteout FRS
I wont be back at the race track for another month.
Im going to sand the rotor and get some new brake pads. Will see if it happen again. |
#4483 | |
Without knowing Canadabuck prices new rotors are like $40/ea USD and turning down old ones is like $20/ea, probably worth it if they're at half life or more. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | dattran86 (05-26-2017), Icecreamtruk (05-29-2017) |
#4484 |
Drives: Subaru BRZ
I recently installed single exit exhaust for weight saving. if I remove all the spare/jack from the trunk for tracking purpose (never did before), is that a bad thing? in the sense that, this will move the weight distribution more to the front, despite the weight lost, thus increasing oversteer?
#4485 |
Drives: 2023 BRZ
You'll be fine. Any negative handling effects will be more than offset from the lighter weight.
| The Following User Says Thank You to Pat For This Useful Post: | strat61caster (07-04-2017) |
#4486 |
Drives: FR-s
what oil cooler "kit" for the track?
#4487 |
Drives: 2014 BRZ
I’ve seen excellent results from both the Perrin and Jackson Racing. Prefer the Jackson Racing for the extra capacity (and reuse when switching from NA to thei SC; the Perrin didn’t have the capacity for the SC).
| The Following User Says Thank You to Sleepless For This Useful Post: | CSG Mike (07-05-2017) |
#4488 |
Drives: '15 BRZ
OK, here's a tricky one regarding the issue that a wider wheel/tire combo will be slower around a track than a narrower one (on stock power).
So I did a test... 4 runs, 2 in each direction, same (straightish) road, logged with 10HZ external GPS on Harry's Lap Timer from 90 to 170 km/h. 18x8.75 XXR527's 245/40 18 Nexen NFera SU1 14.58 & 14.58 seconds in 1 direction and 14.29 & 14.34 seconds in the other then switched to the OE wheels on 215/45 17 Michelin Pilot Sport Cup2's 14.72 & 14.65 seconds in 1 direction and 14.41 & 14.44 seconds in the other So the runs were done on the same road, less than 1 hour between the runs, same weather etc. The weight of the XXR527 should be the nearly the same as the OE wheels, maybe slightly less. However since the Cup2's are one of the lightest tires around, I'm pretty sure the overall 17" combo weight was smaller, however I have not weighed them. So there was no noticable difference, if anything the narrower 17s were slower. Can anyone explain, why? |
#4489 | |
To see a difference in weights/widths/rolling resistances you'll need to keep it <90 kmh and it'll be best if you have multiple accelerations in your 'test'. |
#4490 |
#4491 | |
#4492 | |
Drives: '15 BRZ
Thanks! |
#4493 |
Drives: '22 BRZ
I went from the stock 215 Primacies to 245 RE-71Rs and exited the final corner of a local track 10mph faster. I got to the other end of the straight and was only 1-2 mph faster than the 215s. That's a huge amount of speed to give up on every straight.
#4494 |
Drives: Track preped NA FRS
Do you recall how long was that straight?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
