#4243 |
Drives: 2013 Subaru BRZ Limited (WRB)
#4244 | |
driving smoother faster
Drives: Sold
Check out some common options at http://www.ft86club.com/forums/showthread.php?t=84188 Look into Nitto NT01 and Maxxis RC-1 for dry and Dunlop Direzza Z2 for dry and wet, aside from what you tried. Common wet choices are Michelin PSS and Conti DW, neither as good in the dry as RE-11 or RE-71R. |
| The Following User Says Thank You to dp1 For This Useful Post: | strat61caster (11-07-2016) |
#4245 | |
I'm aware of the options, but looking for solid feedback from firsthand experience. I didn't think the NT01's were any better than the RE-71R or RE-11, they've been around quite a while. Have you actually used all of those tires on the track? What are your thoughts about how they compare to each other? Also, really looking for feedback on R-Compounds like the Toyo R888 as well. ![]() edit: Reading through the link, thanks... edit 2: Looking a lot harder at the NT01's. I think the Maxxis RC-1's are out, as they might be a little too extreme and the car will see rain. I guess it comes down to how many track days I could get out of them. The RE-71R's wore down VERY fast. Last edited by Apex_BRZ; 11-07-2016 at 11:37 PM. |
| The Following User Says Thank You to Apex_BRZ For This Useful Post: | dp1 (11-07-2016) |
#4246 | |
Drives: Sold
Got a track related question? I'll try to answer.
My experiences: - Toyo Proxes R888 like specific pressures and wear unevenly if they are outside the camber/pressure "happy place" - only tried them on Lotus Elise. Very good compound but never again since Toyo RA1 and Nitto NT01 and Maxxis RC-1 are available in our sizes. Some swear by them so take my comments with a grain of salt. - Nitto NT01 were awesome - they provide very good stick and allow for some serious hooning without loosing it. They will wear if pushed hard. This tire may save you where you should not be saved ![]() - Toyo Proxes RA-1 work very well for me. Wear like iron and behave predictably at the limit. Great for rain when new and get faster in dry as they wear. Likely will heat cycle out before they wear out. Heard that Maxxis RC-1 like clean lines and require some skill to keep in check at the limit if driver is not smooth. I see that as a great learning tire for advanced driving with plenty of tread and without crazy stick that hides many mistakes. Similar performance in hot temps as NT01 but faster in colder temps. I will get them for next season in 235/40-17 on 17x9 rims. Last edited by dp1; 11-08-2016 at 06:30 AM. |
| The Following User Says Thank You to dp1 For This Useful Post: | zdr93523 (11-07-2016) |
#4247 | |
Drives: Sold
#4248 | |
Drives: 2013 BRZ Limited
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | dp1 (11-07-2016) |
#4249 | |
RA1 is your answer. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | zdr93523 (11-09-2016) |
#4250 |
Awesome, thanks guys! The car will see rain, but I think they'll be good enough. I have a lot of experience with my other car in heavy downpours and very wide R888's. Seemed to do "good enough". Still something to consider though. Any word on the newer R888R's yet?
The Maxxis RC-1 really sound great, but I can't see going with those. They really look like slicks with a couple grooves cut in them. I mean, there is no design at all for water evacuation where the other tires at least have a chance. While I hold a line really well and am a very smooth driver, I'm still learning and can make mistakes. They might be more than I'm looking for right now. Maxxis RC-1
#4251 |
Student Driver
Drives: 2016 Subaru BRZ Limited
Somewhat off topic, but do you have a recommendation for a good home racing simulator setup? Looking to spend in the hundreds (low hundreds if possible), not the thousands.
#4252 | |
Drives: 2013 Firestorm FR-S
Thrustmaster would be a step up in quality, but also price. Wheel/pedals are sold together, but the shifter is a separate purchase. Then of course there's Fanatec, but you're wayyyy over budget there. I use the G920 for FM6, DiRT, and iRacing (the occasional times I decide to temporarily renew my subscription for a month) Built a pretty sweet setup for it too. ![]()
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | Prmspen (11-09-2016) |
#4253 |
Drives: '23 BRZ Limited
What do you want out of the simulator? Fanatec seems to have dropped their more entry-level, you might look around and see if you can find a retailer with old stock.
Even their Porsche GT2 wheel and pedals, I thought, felt noticeably better than G27 setup. And for about $75 more. But I also ran iRacing on 3 27" monitors. But I believe iRacing now has some support for the Occulus Rift. Asseto Corsa, etc, all suck as racing sims but are more "fun." iRacing has much more realistic physics, but aren't as pretty. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | TofuJoe (11-09-2016) |
#4254 | |
Drives: Toyota 86 GTS Auto
But in iR I had to learn to predict; you cannot really react. By the time you'd react it's too late. AC is more forgiving; you can react & correct. iR is inherently more oversteery - every car wants to spin - whereas AC seems more neutral, even understeery ( but most tin-tops should be that way out of the box ). iR is also a _lot_ more expensive (read: about 10 times or more), and what you get for your money is not much IMO, unless you want to seriously compete online with random people. Organised leagues exist for AC as well.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
#4255 |
Student Driver
#4256 |
Don't forget about Project Cars. I feel the order of things as far as realism would be more like Asetto Corsa, then Project Cars being better yet. IRacing is highly debated as being the best.
| The Following User Says Thank You to Apex_BRZ For This Useful Post: | Prmspen (11-09-2016) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
