86WORX
go_a_way1
Old 02-09-2016, 05:52 PM   #3487
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by OkieSnuffBox View Post
You may want to double-check this year's rules.
I thought last year it was changed to "You can only run E85 if it comes from the factory as a Flex Fuel, or is stated in the manual you can run E85"
Looks like tt rules still state any retail e85 under no points mods. unless I'm missing something.
Old 02-09-2016, 07:25 PM   #3488
OkieSnuffBox
Drives: '23 BRZ Limited
Ok cool. I just read through as well and didn't see any gotcha's.
I could have been imagining that change, or maybe it was an SCCA change to Auto-X rules.
EDIT: yep it was the SCCA, sorry for the mixup on my part:
Street and Street Touring® category vehicles will use fuel which is “Federally
approved for use on public highways.” This includes the pump fuel
known as E85, but does not allow racing-type fuels which are available at
service station pumps. Fuels comprised of more than 15% ethanol may
only be used when specified by the manufacturer (e.g., in the owner’s
manual for flex-fuel vehicles)
Old 02-09-2016, 07:31 PM   #3489
ka-t_240
The car was underclassed in TTD to begin with, IMO
You think it should be in TTC? What would it take for an NA BRZ to actually compete in that class?
ka-t_240 is offline   Reply With Quote
Old 02-09-2016, 08:26 PM   #3490
I always thought it should be a TTD** personally.
I think I could build a class winning TTC BRZ, given the right budget and freedom, along with the requisite driver. I've assisted in many TTD builds, and the ones who have been willing to spend the funds are *COMPETELY* dominant within their regions. That may have been a contributing factor to the changes...
Short version: good dampers, brakes, appropriately sized tires, header, tune, and weight reduction if available (varies by driver and setup, whether the car is caged or not, etc.)
Old 02-09-2016, 10:07 PM   #3491
Uplink
Uplink's Avatar
Drives: anything you let me
Honestly, depending on the track, might not need too much at all.
For reference, in bone stock trim + 245 Direzzas and PFC08 pads in HPDE Instructor groups, I'm 3-5 seconds from a win or podium at Thompson according to the TTC NASA NE times. Wouldn't take more than a better set of tires & brakes and maybe a little more downforce to fix that.
Conversely, on the Glen where the top 3 cars are M3's with crazy legs, I'm 5 seconds off podium but 10 from first. There it would depend on how much power to weight you can adjust. The 9 corners simply aren't enough to make up for how long you can put the pedal to the floor on a track that big. (Yes, there are 11 'corners' but the esses and 4 are flat out so there's nothing really gained by a nimble car over a powerhouse.)
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
CSG Mike (02-10-2016)
Old 02-10-2016, 12:15 AM   #3492
ka-t_240
I know I need to loose points to make TTD, I need to debate if I want to spend the money for some of it or just deal with it and go to TTC. Sourcing a trunk is part of it as I have a BRZ limited.
Car currently is not caged. I have been looking into a 4 point roll bar with a seat/harness/hans combo.
Current Setup:
  • 17x9 RPF1 w/ 245 RE71R
  • Tomei El Header, stock OP, Berk Catted Front, Invidia Catback, Grimmspeed Crank Pulley and Intake. OFT w/ E85 tune.
  • RCE T2, RCE F/R Sways, Perrin Steering lockdown, SPC RLCA,Whiteline subframe and diff inserts and rear endlinks
  • BRZ Limited Trunk
  • Debating 4.56 Final Drive
What I need to Ditch to make Points:
Intake, Crank Pulley, Rear Spoiler, RLCA/Endlinks, Strut Bar
The Following User Says Thank You to ka-t_240 For This Useful Post:
Old 02-10-2016, 12:52 AM   #3493
Uplink
Uplink's Avatar
You might wind up hamstringing yourself trying to cut points to back down a class. You're effectively picking handicaps to 'make weight' in a class that other cars could have added mods to get to.
A good baseline for your decision could be to see what times you're running on tracks with your current setup and compare them with the results sheets from TTC/D. If you're not crushing D don't drop a class. If you're somewhat competitive in C maybe you could look to max out mods for that class.
The Following 2 Users Say Thank You to Uplink For This Useful Post:
Campo (02-10-2016), CSG Mike (02-10-2016)
Old 02-10-2016, 01:20 AM   #3494
ka-t_240
I will be running with NASA Central. One Track I am about 6 seconds off TTC, and should be 1-2 for TTD. The other I around 1 second off TTD lap record, and there has not been a TTC car, and then then I have one new track on the list that I have no seat time at.
NASA Great Lakes runs a couple of the same tracks, but their times seem to be way out of date.
Intake, Crank Pulley, RLCA/Endlinks, and spoiler make minimal performance difference. I can adjust the camber by raising the car a bit which will also allow me to use the factory endlinks in the back or adding the Whiteline camber bushings.
Old 02-10-2016, 02:28 AM   #3495
I love this discussion.
Carry on gentlemen.
Uplink (02-11-2016)
Old 02-10-2016, 09:56 AM   #3496
redlined600
Drives: Fr-s
IMO all the Midwest tt-d records I could fine are either not updated or really weak (which makes me think they just aren't updated).
Old 02-10-2016, 10:40 AM   #3497
Pat
Pat's Avatar
Drives: 2023 BRZ
Carry on gentlemen.
This.
I'm considering TTD for next year. But it will depend, in part, what it takes to keep the car in TTD.
Old 02-10-2016, 10:49 AM   #3498
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
Originally Posted by Pat View Post
This.
About 19 points.
VADERR is offline   Reply With Quote
The Following 2 Users Say Thank You to VADERR For This Useful Post:
Campo (02-10-2016), ka-t_240 (02-10-2016)
Old 02-10-2016, 11:16 AM   #3499
Icecreamtruk
Drives: Track preped NA FRS
Not related to autocross but rather for time attack. I was in the same dilema of finding myself at the very bottom of a class. I was undecesive of what to do, drop a class by handicapping myself, or maxing out current class. When I checked the times I realized, that my current times, that were near bottom of my current class were only middle of the pack of the previous class. So I decided to max out current class (exhaust, drop-in filter, tune, brakes, shocks, 100TW R compounds). Competition starts in april, lets see if it pays out (will be able to tell as soon as they open the tracks, since I will practice before competition day this time around).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 02-10-2016, 11:47 AM   #3500
enivid
enivid's Avatar
Drives: WRB JR BRZED
Since this might be the very last year of TTD/C and for sure TTB, I would be cautious about buying new parts since most of those rules could be gone in TT4/TT5.
enivid is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) -- General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) -- General Topics 20 01-10-2012 10:54 AM
