#3417 | |
The best way is to practice in a safe environment until correcting something like that becomes completely intuitive and doesn't require thinking about corrective action. Wet and/or snowy pavement are great as well if you can find any.
#3418 | |
Drives: anything you let me
See if your local track / car clubs are offering skid pad / car control clinics. They will usually pair you with an instructor which speeds up the learning curve, and the surface will be properly prepared (wet/soap/etc.) to allow you to easily induce skids at slower, more controllable speeds. Then build from there. Last edited by Uplink; 01-11-2016 at 05:22 PM. Reason: Spelling. |
| The Following User Says Thank You to Uplink For This Useful Post: | wparsons (01-11-2016) |
#3419 | |
Drives: 2013 BRZ Limited M/T
| The Following User Says Thank You to Bramick For This Useful Post: | wparsons (01-11-2016) |
#3420 |
driving smoother faster
Drives: Sold
Brake fluid comparison chart:
https://www.lelandwest.com/brake-flu...ison-chart.cfm Last edited by dp1; 01-19-2016 at 02:28 PM. |
| The Following User Says Thank You to dp1 For This Useful Post: | DocWalt (01-17-2016) |
#3421 |
Drives: 2013 Firestorm FR-S
Posted this in the wheels/tires section, but figured I'd share here too:
I'll be taking delivery of my new wheels in the next couple months (5-6 months is such a long wait time ) And In the meantime I'm debating tires. The car will be daily driven and taken to a decent number of track days throughout the year, hoping to do at least one a month for this season. The wheels are 17x8 +35, and I'm currently debating between 225/45 and 235/40 ZII*. I prefer the meatier/wider tire with the 235, but in a discussion with a US rep from the company he mentioned that with the +35 offset I may have fitment issues with a 235, I imagine he was referring to rubbing issues, and have to run a 225 or 215. The car will be lowered around 1" on coilovers, and I will also have camber plates and new LCAs installed at the same time. Currently thinking of running between -2 to -2.5 camber in the front and -1.5 to -2 in the rear. From folks with similar sized wheels out there who daily and track, would you expect there to really be any issues running a 235/40 tire? What benefits and drawbacks might there be to either size?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#3422 | |
![]() From what I've heard, coilovers actually give you more clearance. Guys with 255's have needed to go CO for fitment. |
#3423 | |
#3424 |
| The Following User Says Thank You to Uplink For This Useful Post: | Shark_Bait88 (01-20-2016) |
#3425 | |
"17x8 35 offset which is lightly aggressive size. you may required narrow size tire which is 215 or 225 wide size and rolled fender and suspension kit to make lowered and negative camber. if you go to slam lowered and super negative camber then you can fit wide and lower offset however you can not drive daily with wider than this size of wheel. so this is aggressive size but still you can drive daily."
#3426 | |
Not because of fitment, but because you'll get better respone out of the tire. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#3427 |
Is that because the only tires I can find in that size are r-comps? lol
#3428 |
Typo! 225/45/17
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Shark_Bait88 (01-20-2016), Ultramaroon (01-20-2016) |
#3429 |
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | CSG Mike (01-20-2016) |
#3430 | ||
Drives:
edit=your width won't be the same, the location of the outside shoulder should be the same. Quote:
Ignore everything I said above and just run this size. Or get two sets of rims/tires.
"Fuck, you've gone completely sideways, man."
~Raoul Duke Gas is pretty cheap considering you're buying liquid explosive dinosaurs. ![]() Last edited by Campo; 01-26-2016 at 04:13 PM. Reason: width =/= shoulder location |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
