#3249 | |
/scion
Drives: '13 86 M/T
#3250 | |
It'd be foolish to argue that they don't interplay, that two cars with identical spring rates but different everything else would handle completely differently from each other. But as posted elsewhere, spring rates are kind of the roughest knob to turn in relation to handling balance. Yeah, the 400lb/in springs on Tarmac 2's don't necessarily handle the same as 7kg/mm (~390lbs/in) on Fortune Auto's all else being equal. But the bias should be close, you would follow similar paths to optimizing grip given either starting point. That might be the key, spring rates are a starting point. Damping has an optimum value based on all the other factors so it really isn't a tuning tool unless you're removing grip to get balance, which is slowing the car down, I think this also applies to bump stops. Tires are generally chosen based on application so once you have your head in that space the differences are usually negligible unless your ruleset is wide open like a DD/Track car which will have a guy on stock 7" chasing down a guy with 18x9's, but in that scenario outright speed probably isn't the top requirement. From what I understand it'd be pretty foolish to choose spring rates and damping based on the cheap parts that are easily changeable like roll bars and alignment. The question is doubly tricky because how 'stiff' the suspension is is not a linear relationship, 300 lb springs f/r will handle differently than 600 lb springs f/r even though the 'balance' is the 'same'. It's interesting I've been watching spring rates on this platform and it seems like you can make anything work with some effort, lots of different philosophies, equal rate springs f/r seem to be rather popular and some are evem recommending stiffer fronts (I remember CSG once suggested 7k/6k for autox vs. 10k/12k for track). Given how the car pushes completely stock I'm also surprised so many are selling equal rates front and rear. So far I'd say alignment is more important than spring rates when it comes to balance, I cranked the front up to >-3.2 degrees and left the rear at stock <-1.5 degrees and I had a drift machine I couldn't hang onto, move the front camber down to <-2.7 degrees and I've got understeer rivaling an economy car. Huh, I seemed to have convinced myself to your point but I'd be asking about alignment first and then spring rates second, the rest of the variables should be relatively adjustable to get the final desired result and things like tires and bushings can be compensated for without a ton of effort. Oh and don't forget style and skill ![]() ![]() For clarity I don't have first hand experience in a road racing/autox/track environment, but hopefully that'll change over the coming months. |
#3251 |
#3252 | |
#3253 | |
#3254 |
/scion
Drives: '13 86 M/T
#3255 |
#3256 | |
/scion
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." Thanks, I think I found my sig quote. ![]() ![]() btw, pads should hold up fine for future use, right (I've done it before on less damage)? |
#3257 | |
Late braking means slower corner entry speed |
| The Following User Says Thank You to CSG Mike For This Useful Post: | LOLS2K (12-10-2015) |
#3258 |
Drives: 2013 WRB BRZ 6MT
Not sure how it's contradictory but I'm no expert and may not be understanding the correct terminology. Maybe you can help me understand?
Basically, it's my understanding that RR Racing front brake kits have similar brake torque to the stock front brake system which would retain oem brake bias but their rear brake kits have increased brake torque over stock which I understand would move brake bias to the rear. RR Racing says that the car benefits from increased rear bias so instead of getting the rear kit, I was wondering if it is a good idea to run a more aggressive pad in the rear which should have the same effect. |
#3259 | |
Now, would you want MORE rear brake bias, given that experience? The stock bias is designed to optimize braking distance, while within the range of the EBD. Moving that bias will take you out of the EBD's range, and a static rear bias with dynamic rear grip (wing) just doesn't mix well, imo. |
#3260 | |
Drives: GT86, 22 BRZ
#3261 |
Drives: Toyota GT86
Any body here rocking the jdm gas pedal?
I really would want one too make the hel toe some more placenta. So is it worth it and did it do the job better? I have had several knee surgery and it's a pain in the as too heel to whit the oem pedal, so everything that that doesn't mean I have to twist around the knee more is a bonus |
#3262 |
Drives: 2015 Series.Blue BRZ
I have the Cusco pedal. 100% worth it. Makes rev match down shifts so much easier.
Sent from my MotoE2(4G-LTE) using Tapatalk
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
