#3235 |
Drives: 2013 FRS
What pads would you recommend for the rears? Rr racing b20 up front, assume stock rotors in back. Stock power on kw v3.
#3236 |
Drives: '13 FR-S Whiteout
#3237 |
#3238 |
Front vs. rear...
Maybe time to go back to Winmax or try Carbotech haha. These came with the kit though. |
#3239 |
#3240 |
/scion
Drives: '13 86 M/T
#3242 |
Yes, I have the stage iv front and stage i rear kit. So I get to use the same size pads front and rear. It is actually very nice. When I get pads I like, if the fronts still wear fast I just put the rear pads up front and buy new rears.
The brakes do feel very well balanced. I admittedly don't have a ton of experience with a ton of different braking systems, but I have enough seat time in this car to know. I can also attest to the fact that this kit (as well as the AP kits) is so much better at heat management and is well worth the cost in the long run. |
#3243 | |
#3244 |
#3245 |
/scion
Drives: '13 86 M/T
#3246 |
Drives: GT86, 22 BRZ
I've got a question around spring rates (apologies if it has been asked before).
The stock rates are something like 2.3KG front and 3.3KG rear, making the rear about 50% stiffer than the front. It seems most aftermarket coilovers are running the same rate front and rear, or very similar rates. eg. 6kg/6kg, 8kg/9kg, 8kg/7kg. Its certainly not 50% heavier on the rears like the stocks. Doesn't this change the balance of the car towards much more understeer? Or are you gaining a lot more front grip with the coilovers via the other improvements (greater camber etc) and negating this? |
#3247 |
Drives: 2013 WRB BRZ 6MT
I've read a lot of people complain that the BP20s don't last and seem to wear faster the farther you get into them. I'm planning to get the RR Racing sport front kit but I don't plan to run BP20 pads.
RR Racing claims stock bias is retained with the front kit but recommends running their rear kit to move bias to the rear vs OEM. I don't plan to get the rear kit so with that in mind, it looks like I may want to consider running a more aggressive pad in the rear? I was thinking of trying something like Carbotech XP8 in the front and XP10 in the rear, would this be advised or should I use similar compound front and rear? Note that I don't have any aero at all, not even a spoiler. |
#3248 |
Dismember
Drives: 2013 Red Scion FR-S
Suspension works as a system between dampers, springs, tires, inflation, valving, settings, bump stops, roll bars, bushings, etc. You cannot just look at the spring rate of one setup and compare it directly to a completely different setup. You should look at the total product. Please, correct me if I'm wrong.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
