86WORX
go_a_way1
Old 05-12-2015, 02:44 PM   #2703
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
So I recently had some issues at the track with my brakes and wanted to see if anyone can give me any idea of what it can be.
My Current Setup:
KW V3 Coilovers
Project Mu Club Racer Brake Pads Front & Rear
Endless Brake Fluid
Enkei RPF1 w/ Hankook RS3 Tires
At Buttonwillow mid first session the front straight i start braking before turn #1 and i feel my brake pedal pulsating but the brakes are still holding but i get that pulsating feel and hear a grinding type noise. In any other turn the brakes are working perfectly fine no problems. Only on turn #1 would this happen all day at the track.
Some other info about me and my car.
I am a beginner and dont have much experience racing so i dont do the pedal dance. Possible being ABS kicking in? But no lights are flashing or anything while braking. This is also the first time i been to buttonwillow. I have used these brake pads twice before at streets of willow and never experience any problems but this was the first time i had the rpf1's and rs3's compared to using stock tires in the past if that makes any difference.
Thanks in advance for any help.
ExxelDistributions is offline   Reply With Quote
Old 05-12-2015, 02:53 PM   #2704
My Current Setup:
KW V3 Coilovers
Endless Brake Fluid
Which car were you in? I was there...
It sounds like it is probably ABS.
Old 05-12-2015, 03:13 PM   #2705
CSG David
CSG David's Avatar
Yep, my bad. Edited my post, flat horsepower, decreasing torque curve. Nothing is stopping me. That is my plan. 14 psi at 4000 RPM and as I reach my horsepower limit I start bleeding off the boost to produce a flat horespower curve.
I like where this is going.
Old 05-12-2015, 04:47 PM   #2706
ExxelDistributions
I was with the red FR-S. I was thinking it can possibly be the ABS but I have never experienced that before for explain racing at Streets of Willow or Big Willow never had a issue like that.
Old 05-14-2015, 08:38 AM   #2707
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
@CSG Mike I'm planning my first track day for this summer. Exact location is tbd based on work schedule. Somewhere in the Birmingham/Atlanta region. My car is basically stock. My question is in regards to tires. I'm currently on 246/40/17 hankook v12 eco 2. A buddy recommended having a new set ready after hitting a small local track. For a total novice would u recommend using my 17x9 rays 57 extremes or the stock wheels and what tires would u suggest? Of course being my first event I'm not looking to set records just improve my skills. Thank you in advance.
2ndgenhachi is offline   Reply With Quote
Old 05-14-2015, 08:38 AM   #2708
2ndgenhachi
245*
Old 05-14-2015, 01:32 PM   #2709
If your tires have at least 5/32" tread left, you most likely won't need new tires.
At this point, it won't really matter which tires you run, but if you're not planning on ever using your stock tires again, then you might as well put the wear and tear on those.
Old 05-14-2015, 01:36 PM   #2710
JS + BRZ
Drives: 2010 MS3
Hi Mike,
A quick question. Does a bucket seat lower the seating position? The top of my helmet is almost touching the ceiling and it gets a bit uncomfy after 3-4 sessions. I can live with it but I may considering getting a new seat later this year.
Thank you!
JS + BRZ is offline   Reply With Quote
Old 05-15-2015, 01:10 PM   #2711
philooo
Drives: 13' Scion FRS Track car
what's the user feedback on the willwood 6 piston brake kit for track use ?
It is a bit cheaper than the AP kit, larger rotor...
everybody here seems to be picking the AP kit, but willwood looks pretty nice as well on paper.
philooo is offline   Reply With Quote
Old 05-16-2015, 12:22 AM   #2712
Originally Posted by JS + BRZ View Post
Hi Mike,
Thank you!
It sure can, but keep in mind you'll be compromising your airbag.
JS + BRZ (05-17-2015)
Old 05-16-2015, 12:22 AM   #2713
Not something I'd run on my own car.
Old 05-16-2015, 06:03 PM   #2714
ZionsWrath
Thanks
ZionsWrath's Avatar
Maybe larger not thicker.
Check this thread comparison
http://www.ft86club.com/forums/showthread.php?t=27300
The Following User Says Thank You to ZionsWrath For This Useful Post:
Teseo (05-16-2015)
Old 05-16-2015, 08:42 PM   #2715
Teseo
Drives: frs
Very interesting, anyone tried this combo:
-stock calipers
-Aftermarket Discs
-Aftermarket pads
How feels on the track and street also
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (05-16-2015)
Old 05-16-2015, 09:24 PM   #2716
juliog
juliog's Avatar
Drives: 86
-stock calipers
-Aftermarket Discs
-Aftermarket pads
Rotors won't make a difference on the street. My stock rotors were grooved after many track days, so I decided to upgrade to slotted ones to see if they improved cooling or extended pad life. Had DBA 4000 T3 Slotted rotors for ~9 months, with ProjectMu Club Racer pads, and later 999. RBF660 and SS lines, no fade during 20 minute sessions at the track, but pads were only lasting 4, maybe 5 events. Eventually upgraded to AP Racing Sprint BBK for costs reasons (marginally more expensive pads yet 2-3x the life).
One thing I liked about the DBA rotors was the heat paint markings, mine indicated rotors temps between 850F-1000F, which according to DBA meant I should upgrade my brake system:
If your driving conditions force the Orange paint to change to yellow then you should consider more a specialized high temperature pad compound, review the car setup or alter your driving style.
juliog is offline   Reply With Quote
The Following 2 Users Say Thank You to juliog For This Useful Post:
CSG Mike (05-17-2015), Teseo (05-16-2015)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) -- General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) -- General Topics 20 01-10-2012 10:54 AM
