#2619 |
#2620 |
Drives: Scion FRS
Got a few questions:
-How much would I benefit from an oil separator? -Would you recommend running a 5w20 race oil for just the track weekends or would it be better to stick with street oil? If street oil should I go with a thicker weight or the recommended 0w20? - I'm running on the track with the priority of getting good car control, I've noticed you've said don't worry about lap times and turn off TC/VSC for people with that goal, but would something like Aim Solo to look at the line I'm taking be beneficial or not? I'm using the FRS as a weekend warrior, running a stock setup except for upgraded brakes and will be adding a oil cooler/regulator (the one that subaru's forester and STI comes stock with). I'm looking to just do mods that will help the car deal with the wear from tracking, and know I won't be able to prevent all the wear. But any recommendations to help the car deal with the track that I might be missing would be helpful. Thanks |
#2621 | |
Crawford AOS is a great piece and inexpensive insurance without the issue of a catch can and remembering to empty it. Aim Solo DL is a great tool and can double as a gauge setup or work along side the P3 Cars gauge setup. You can share data and get pointers. For oil we run Motul 300v 5w30 on track and as a summer/warm climate oil and alternate with 0w20 Motul 8100 with 3000-5000 mile intervals. We can help set you up with any and all of these products and have an intro offer on the AIM Solo products right now as well. Mike |
| The Following User Says Thank You to AZP Installs For This Useful Post: | Racecomp Engineering (04-20-2015) |
#2622 | |
Going to a 5w-20 would yield little if any benefit on track while detrimenting your cold start wear. It is the second number that will help when the car is running hot while the first is about thickness at cooler temperatures. Race oils tend to be on the thicker side of the spectrum of weights allowed for a spec while energy conserving (what alot of the street oils are and what our cars are supposed to have) will be on the thinner side. Going with a race oil should do better at high temperatures compared to an energy conserving oil of the same weight while reducing your fuel economy and power slightly (more energy used pumping the oil). Theoretically race oils should also hold up better under track temperatures while having a greater film strength, but in general if you are going to be going to the track on a regular basis you want an oil cooler so things stay more nominal. Note that changing oil type may affect your warranty coverage. Adding a oil cooler almost certainly will affect your warranty coverage and could in theory detriment your engine's life by reducing oil pressure (oil coolers produce a pressure drop). I haven't heard of any oil coolers being linked to this but it is possible.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2623 | |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
How are you sharing data between the two? Using one of the aux sensors on the p3 gauge or an OBD splitter? At what ambient temps do you guys recommend the switch to 5W-30? So far I've been switching to Redline 0W-20 prior to the track day and then driving it to 3k miles before switching back to OEM for daily driving. My last track day I was creeping up to 250-255 and the summer FL heat will be here soon Thanks for your help! Sent from my iPhone using Tapatalk
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
#2624 | |
Any ambient temps that you see in FL the 5w30 should be fine except if you aren't tracking it in Dec-Feb. My Project BRZ resided in So-Flo this winter with 300V 5w30 in it as we did 2 track days at Homestead and it will be returning next week up here for the summer track season. -mike |
#2625 | |
-mike |
#2626 | |
For the cold cranking viscosity test, a 0W is tested at -35C for and a 5W is tested at -30C.http://www.pqiamerica.com/coldcrank.htm One advantage that a 5W will have over a 0W within the same grade is that it is a more stable oil since it will contain less viscosity modifers (and more stable oil pressure as the oil is used). If you compare Red Line, their 0W oils contain some viscosity modifiers while their 5W oils contain none. |
#2627 |
Anytime I give advice about modifying that relates to the engine I like to give that warning. You never know who that person will be that doesn't think things through and then screams bloody murder because something goes wrong.
#2628 | |
In terms of the viscosity modifiers, if you are seeing thermal breakdown of your oil then you are in trouble no matter if you are using a 0w or 5w. Frankly, trying to deal with temperatures high enough to substantially degrade a race oil's viscosity modifiers by changing oils winter cranking viscosity is like putting a band aide on a dismembered limb; yes, you might want a band aide at some point but you really need to deal with the greater issue (ie you need an oil cooler)! At the temperatures where a race oil's viscosity modifiers starts to rapidly degrade you are probably seeing extremely thin oil and causing rapid damage to the engine. Our cars run the oil hot but modern oils are designed to deal with that for short periods of time. These are street cars after all and most of the use they will see will be normal street use with a burst of track time (compared to a race engine which sees only extreme use and is properly warmed up every time, etc.).
#2629 | |
It sounds like you need an oil cooler, more than changing oil weights. Changing oil weights is a band-aid. The oil cooler is the real solution. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | the new guy (04-22-2015) |
#2630 | |
A quality race oil will work just fine on the street. Worry more about getting proper cooling for your oil, rather than the oil itself. Any quality full synthetic will get the job done with a proper change interval. A full data acquisition system will allow you to pinpoint exactly where/how you can improve, and also give you a way to catch errors you would otherwise not recognize. The Solo DL allows for you to see exactly what your driving inputs are (gas, brake, steering), and you can see the result of each input or combination of inputs (lateral g, longitudinal g, yaw rate, speed, acceleration, etc.) CSG also offers a remote data analysis service if you need your logs analyzed for you. |
#2631 | |
#2632 |
Got a track related question? I'll try to answer.
True in regards to viscosity modifiers since each oil is blended differently and companies don't always give you very much info. Motul and Red Line are good at providing more details than most companies if you call or email them. Red Line usually does recommend the lowest viscosity in the manual, but you can always email them and ask if their 5W20 has any advantages over their 0W20.
The other big advantage of a 5W20, IMO, is less NOACK volatility (evaporation) than the same brand 0W20. It's hard to find NOACK from some brands, but Red Line, Amsoil, and Pennzoil list theirs. Red Line 5W20 NOACK 8% High Temp High Shear 3.0 Red Line 0W20 NOACK 9% HTHS 2.9 Amsoil SS 5W20 NOACK 6.3 HTHS 2.7 Amsoil SS 0W20 NOACK 10% HTHS 2.7 Pennzoil Ultra Platinum 5W20 NOACK 10.5% HTHS N/A PUP 0W20 NOACK 12.5% HTHS N/A Note that the maximum NOACK volatility allowed for an API/ILSAC certified oil is 15% so you can see most of these are well under the maximum (PUP 0W20 is up there though), with the 5W-20's being best. For comparison the maximum NOACK to meet the Mercedes oil spec is 10%. NOACK is measured at 482F/350C so it's intended to test oil at the extreme temps that some parts of an engine could see. At the track, I'd definitely take a lower NOACK over a higher one. Probably less of a factor though if you're talking strictly race/street oils like Red Line or Motul 300V those since their numbers are so close and much lower than pure street oils. Last edited by bluesubie; 04-21-2015 at 06:32 PM. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
